Reply
Thread Tools View Mode
Old 13th Jul 2012, 23:43   #61
abbas-it
We came, we saw, we mod, you awe!
abbas-it's Avatar
abbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysisabbas-it can run Crysis
Back is almost finished
hi guys, her are the last pictures of the RENEGADE rear side. the fan outlets are cut and have the same crossfire and sight pin look like in the front. the star wars door has its own vent with the chimney and the switch has its armour plates too. a few more little touches tomorrow and then i will start doing the inside. her are the pictures.
The top slanted plain emty part is for plot and paint, as a later feature. name date etc..
more to come
abbas-it is offline   Reply With Quote
Old 14th Jul 2012, 01:41   #62
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Holey moley, man! It keeps getting cooler. Where does Kenny Baker sit, though?
Cheapskate is offline   Reply With Quote
Old 14th Jul 2012, 09:40   #63
starbee
BRNO 4ever
starbee's Avatar
starbee has yet to learn the way of the Dremel
oh man...awesome...How much does it weigh?
starbee is offline   Reply With Quote
Old 14th Jul 2012, 11:54   #64
Balder
Calmer than a monk on morphine
Balder's Avatar
Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.
I'm guessing it's about somewhere above alot and a bit :O
It looks awesome though!
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem.
- Martin Luther King, Jr.
Balder is offline   Reply With Quote
Old 15th Jul 2012, 07:57   #65
abbas-it
abbas-it's Avatar
soon color will be coming into the whole game
, he is already inside, did you miss the post.
@ starbee and balder, yes that is indeed a good question. i will be weighing it soon too.
so far i would guess between 20 and 40 kilos, will weigh asap.
so hello again everyone, her is yet another update fron the RENEGADE front.
i have started another 3d-logo skull breakout shield for the front. it will have wings or some other miltary rank signs. its still not looking mean enough but it will with paint etc.. as you can remeber from the first post, RENEGADE, The Public Enemy used to be in the military before he rebelled against the whole system, but he still has his rank so thats why its also an important feature. apart from that you may or may not see the other differences, lots of earth wire railings and the anti scrape rods of stainless stell so that the monitor when opened does not get scrathed on the bach armour plate which covers its wires. the X-Y joystick for the primary weapon is also mounted.
as you can see in some of the pictures wheer i have started to dismantle the whole case, the rear pane can be removed in a whole taking the swing cover etc all off at once.
more to come
started the break down of the mock up for painting..
more to come......
Old 15th Jul 2012, 14:06   #66
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Waynio is online now   Reply With Quote
Old 16th Jul 2012, 11:50   #67
Black_Mummy_DK
Minimodder
Black_Mummy_DK has yet to learn the way of the Dremel
unbelievable. artwork. Can't wait to see it painted!!! mod on!
Black_Mummy_DK is offline   Reply With Quote
Old 17th Jul 2012, 00:10   #68
abbas-it
abbas-it's Avatar
hi guys and here are some more pics, i made a rear console so that i can easily access the led and gun x ycontroller from the back too. it has a plaque with handles too in the same dominat RENEGADE railing style, and will also have scription on in too when painted.
the plaques are sanded at 45 degress so that they are recognisable as plques and console covers and not the armour plates.
also made a plaque for the monitor too where i will also have scription. made a lot of railings and screw holes etc..
at the moment i am more or less just drilling hole and making tunnles and paths for the wiring because i am moving to my garage on the weekend for the first pain coats.
more to come..
Old 17th Jul 2012, 09:12   #69
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Damn I seriously can't wait to see this painted!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 17th Jul 2012, 10:27   #70
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Wow thats seriously something different to see!!!! Well done bro!
AnG3L is offline   Reply With Quote
Old 19th Jul 2012, 00:21   #71
abbas-it
abbas-it's Avatar
thanks guys, i am also curoius and eager to get some coats of paint on this one.
i fiddles around with the front shield or arms today, made horns for the skull and two swords too, not finished yet and will only look the way i picture them after files around a bit , puttyed and airbrushed but you can see where its going i guess.. here are the pics.
this weekend i will be shifting to my garage for the first coats of paint (i hope)
more to come
Old 19th Jul 2012, 11:35   #72
Teelzebub
Satan the one true God / Modarator
Teelzebub's Avatar
Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.
Amazing
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86
A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not
Teelzebub is offline   Reply With Quote
Old 19th Jul 2012, 12:49   #73
Shirty
Good news everyone!
Shirty's Avatar
Shirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run Crysis
I definitely voted right in May's MOTM, this is unbelievable!
Even the jawdrop smiley can't express my admiration for the workmanship here.
So I'll settle for the Dremel smiley instead:
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500
Why.
Shirty is online now   Reply With Quote
Old 19th Jul 2012, 17:27   #74
Blooddrunken
In Flames we Trust
Blooddrunken's Avatar
Blooddrunken has yet to learn the way of the Dremel
Too much awesome details in one mod. congrats.
Blooddrunken is offline   Reply With Quote
Old 19th Jul 2012, 20:30   #75
starbee
BRNO 4ever
starbee's Avatar
I like devil skull and swords. Really awesome project man. Paint it, paint it...joke, please do more cool details. good luck
Old 21st Jul 2012, 09:50   #76
abbas-it
abbas-it's Avatar
THE POOR RENEGADE
hi everyone and thanks for motivating me with your remarks and critics.
so after almost 1200 hours of modding this baby, its finally time to break
"RENEGADE, The Public Enemy" down
its heart breaking to see such a stronghold dismantled into a heap of wood, metal plastic and other rmaterials. but i can guarantee you, this will be the only downfall ever for the RENEGADE.
He will rise and shine in full colour and hopefully look bigger, better and more threatening than ever.
Its finally time to get some paint on this baby,
these pics are of the broken down parts. only now have i realised just how many there are.
i will prime everthing first and then sand it off, while the first coat is drying i will be doing the case interior design, so you will be seeing interior work as well as painting and wiring afterwards.
more to come
PS: its hard for me to believe that this will all fit together as a casemod afterwards when i see this pile of stuff here.
Old 21st Jul 2012, 19:52   #77
abbas-it
abbas-it's Avatar
RENEGADE PRIME
hi guys i have broken down the RENEGADE and here are the primed parts ready for sanding.
while they are drying, i will start the interior designing. its unbelievable how many parts i have created and they are not even all on the photos.
Old 23rd Jul 2012, 18:10   #78
starbee
BRNO 4ever
starbee's Avatar
very nice man...good luck with next progress
Old 23rd Jul 2012, 18:51   #79
Karrek
Multimodder
Karrek's Avatar
Karrek has yet to learn the way of the Dremel
wow. still interested in how much it weighs...
Good luck with the painting - I look forward to seeing your progress! great job!
Karrek is offline   Reply With Quote
Old 23rd Jul 2012, 23:04   #80
abbas-it
abbas-it's Avatar
I will weigh it as soon as its all stuck back together again, and believe me i am really curious whether all goes well in finding the right place for everthing. this one surely breaky all records for the amount of mad parts
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
