Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 30th May 2012, 08:57   #101
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
Bloody hell i guess some people are just that little bit crazy. You wouldn't catch me doing this. But gratz and a mod well done and nothing broken!!
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
MrDomRocks is offline   Reply With Quote
Old 30th May 2012, 08:58   #102
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
Good freaking work mate!
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is offline   Reply With Quote
Old 30th May 2012, 09:06   #103
N17 dizzi
Packet of mints and a Phillips head
N17 dizzi's Avatar
N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.N17 dizzi is the Cheesecake. Relix smiles down upon them.
Originally Posted by true_gamer View Post
Nice one mate! Big improvement on the temps.
Still curious as to why Ivybridge still runs so hot?
I do hope the Ivybridge-E is fixed from this issue, otherwise I won't be upgrading. Not that the upgrade from my 990X was a good step either...May have to hold off and not give into temptation.
Intel would be beyond stupid to release the bonafide enthusiast chip the same as these.
6 (or rumored 8) cores? It would melt.
The thing that was obvious yesterday is that my waterblock was really not going to help matters much. The heat isn't being transferred properly compared to sandybridge. Cost cutting might be the reason, or maybe they want more enthusiasts to buy the e version!
I am guessing the transistor change is another reason why its hotter..
__________________
Silverstone PS07B | Core i5 2500k @ 4.5 | Arctic Freezer i30 | Maximus V Gene | Corsair 8GB 1600Mhz | MSI GTX 670
| Crucial M4 256GB | Antec Truepower 650w | Dell U2412M | Qpad 3202 | Corsair M60 |
N17 dizzi is offline   Reply With Quote
Old 30th May 2012, 09:10   #104
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for president
Yeh, my temps are a little lower than yours and I'm at 4.6GHz with a bit more voltage...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 30th May 2012, 09:11   #105
Shirty
Good news everyone!
Shirty's Avatar
Shirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run Crysis
Intel will surely fix this to a large extent with a new stepping.
Kudos Dizzi, you're a braver man than I
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500
Why.
Shirty is offline   Reply With Quote
Old 30th May 2012, 09:19   #106
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
but deliver us from intel......
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts.
The_Crapman is offline   Reply With Quote
Old 30th May 2012, 09:27   #107
N17 dizzi
N17 dizzi's Avatar
Thanks for the comments. I hope I haven't given myself a rep as the hardware section nutcase! It was more a rebellion against intel's ivybridge crapness...
Anyone want to lend me a 680 to play with? I heard something about dd ln2
__________________
Old 30th May 2012, 09:49   #108
23RO_UK
Hasta Maņana
23RO_UK's Avatar
23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president23RO_UK should be considered for president
Originally Posted by Spreadie View Post
Nice one dizzi!
Brass balls the size of Canada!
To go one further a set of plums the size of water melons!!!
Great work dizzi +rep
23RO_UK is offline   Reply With Quote
Old 30th May 2012, 14:30   #109
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar has yet to learn the way of the DremelTyinsar has yet to learn the way of the DremelTyinsar has yet to learn the way of the DremelTyinsar has yet to learn the way of the Dremel
Read an interesting article the other day (link) which postulated that the increasing density of CPUs is part of what is killing overclocking. Basically, the hot spots are so tiny that it's getting tougher to get the heat away fast enough by any conventional method. Then there's also the fact that "All of Intel’s manufacturing prowess is turned towards building smaller chips that draw less power, not ultra-high-performing chips that sacrifice efficiency to hit skyrocketing performance targets."
Anyway, good job on the IHS removal.
__________________
"There are no ordinary people. You have never talked to a mere mortal." C.S Lewis - The Weight of Glory
Tyinsar is offline   Reply With Quote
Old 30th May 2012, 15:28   #110
Parge
Parge's Avatar
I disagree, OCing is better and easier than ever before. Maybe in 5 generations that'll be a problem.
__________________
Old 30th May 2012, 17:18   #111
Tyinsar
Tyinsar's Avatar
It would be interesting to see a chart of the history of overclocking. I suspect that, while the tools for overclocking have gotten better the results may not have. I remember changing one jumper to get my Pentium 166 to get 200, no voltage change, no fancy cooler, ... A 20% increase with zero extra parts. Most similar overclocks I see now almost require replacing the stock cooler, bumping voltage, ...
I, and the article I linked, could be wrong - manufacturers need to keep thier chips running within certain safety limits and that always means potential overclocking.
__________________
Old 30th May 2012, 17:20   #112
N17 dizzi
N17 dizzi's Avatar
Near 10 hours of prime @ 4.5 1.3v during the hottest part of the day in a closed box room which was stifling..
Under water this is going to be awesome!
Going to try a stress test at 1.28v, hopefully get them even lower
__________________
Old 30th May 2012, 18:32   #113
The_Crapman
Great work dizzi! maybe intel can pull their finger out and sort this asap!
__________________
Old 30th May 2012, 18:56   #114
bdigital
Is re-building his PC again
bdigital's Avatar
bdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpitbdigital is almost as Godly as yodasarmpit
Im amazed at the high temps of these chips (both before and after dizzis effort).
Im very pleased i decided to get a another sandy bridge rather than one of these because for me, those temps would be unacceptable. I shall only be using IB in builds where no overclocking is required.
Either way good work dizzi, was an interesting read.
__________________
My photography website: http://www.polarityphoto.co.uk Please share! || Follow me @polarityphoto on Twitter||
Check out my Apline White TJ07 - Case Mod and Water cooled build. http://www.flickr.com/photos/6188486...7631486959032/
bdigital is offline   Reply With Quote
Old 30th May 2012, 19:21   #115
N17 dizzi
N17 dizzi's Avatar
Those last lot of temps are slightly unfair or complete worst case scenario. I cut the air to the room when I shut the door and it was like an oven after 7 hours of being left. It dropped 4c when I came back in. Still not ideal but way better than it was before.
It was more about passing the stress tests after being modded..
Anyway, lets see what this does to it
__________________
Old 30th May 2012, 19:51   #116
YEHBABY
The Millionaires are back!
YEHBABY's Avatar
YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.YEHBABY is definitely a rep cheat.
You crazy!
Nice work dizzi, you are the new mod king
__________________
i7 2700K @ 4.6ghz // MSI P67A-GD65 // 8GB Corsair Vengeance LP // ASUS GTX580 DirectCUII // Samsung 830 256GB //
2x2TB Samsung F4EG // X-Fi Gamer // Corsair AX850W // Antec P182 // Thermalright Silver Arrow Cooler // Dell U2412M
HTPC: 2500K // Gene IV // 4GB Ram // OCZ 120GB // Be-Quiet! CM 580W // Silverstone GD08 // Synology DS209 4TB
YEHBABY is offline   Reply With Quote
Old 30th May 2012, 19:57   #117
NetSphere
Multimodder
NetSphere has yet to learn the way of the Dremel
Good going Dizzi. It's great that you pulled through!
Now you just need to buy some 3770k, apply liquid metal tim, sell on ebay. $$$
NetSphere is offline   Reply With Quote
Old 30th May 2012, 20:54   #118
N17 dizzi
N17 dizzi's Avatar
Originally Posted by YEHBABY View Post
You crazy!
Such praise! This is nothing compared to what some people do on the modding/project log forum but I appreciate it anyway mate
__________________
Old 31st May 2012, 13:28   #119
N17 dizzi
N17 dizzi's Avatar
After hearing that EVGA are late shipping out the 4GB versions of the 670 and overclockers being late on another order, I have been offered a 3 game bundle, free shipping and a small discount on 2GB 680 signature editions..
What do you guys think?
__________________
Old 31st May 2012, 13:31   #120
Parge
Parge's Avatar
Personally I'd wait on the 4GB version. There was a reason you chose that in the first place.
__________________
Reply
Tags
3770k, 4096mb, cpu silicon for my boobs, evga, gtx 670, insanity, mint ice cram, money > sense
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
