#41 |
Do you even mod, bro?
Dude, I'm really loving this. What tubing and fitting are you going to be using? Even though you mentioned that you weren't up for it, I actually think black tubing and silver compression fittings would look great against the silver interior. What reservoir? XSPC do a dual 5.25" one that fits a MCP350/355 and ships with either a silver facade.
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG |
#42 |
dat steak
I've got a res in the post, and all shall be revealed in due course. Suffice to say, there will be no compression fittings
#43 |
dat steak
Nothing much, but I've reinstalled one of the 5.25" mounts, as its actually perfect for my needs.
![]() I'm yet to decide if I want to rebuild the panel, but it currently has exactly the right amount of space to mount my 3.5" dump HDD, and an SSD or two. ![]() Currently mocked up with duct-tape. ![]() While my reservoir is still in the postal system, the next step is manufacturing two stealthing panels, in red - which I've already begun, but a little is better than nothing. |
#44 |
Acrylic Heretic
Go at your own pace, m8. It's not a race! Bays are perfect for HDDs especially if you don't plan on using an optical drive. It's amazing how much space opens up after those get ditched.
__________________
Latest Builds: LilyPC - in progress • BIO-A10 - MotM Jul. '12 |
#45 |
dat steak
Good news, reservoir arrives on Friday after a lovely trip through the British postal system. horray.
#46 |
dat steak
I've wanted one since the days of socket 939, so I bought one..
![]() ![]() I may swap it out for a nickel plated version one day, but this will do nicely. |
#47 |
dat steak
![]() ![]() Working out the mounts was a pain. They should really supply a small diagram with the packaging. ![]()
#48 |
sabertooth 990FX
is that... an update?
__________________
http://forums.bit-tech.net/showthread.php?t=249950the big thing |
#49 |
dat steak
![]() One hole for an aquatube. ![]() Hole saw I used was ever so slightly too small, but I'll file it out tomorrow ![]() ![]() ![]() Hides the rear fan and the top radiator and fans, exactly how I wanted. ![]() And how it should look with the Aquatube in. Aces! |
#50 |
Multimodder
Very cool.. Love that the window follows the midplate.
__________________
Project Carbon Apple |
#51 |
dat steak
Some WC bits arrived:
![]() ![]() An MCP350 with an XSPC top. I will probably replace this with a white EK one in due course. ![]() And a Heatkiller 3.0 in white - very nice indeed, and the mounting systems seem greatly improved since my EK Supreme a few years back. |
#52 |
↓ Don't trust that face!
OOOOOH! Leave the hole that size and make notches that fit the screws!
We're due some bewbs here...
__________________
#53 |
dat steak
For those (seldom) few of you who are interested, I've moved back into a new flat in London, and that means little room to move, let alone to mod..
So, here's how things look at the moment: ![]() ![]() (Please appreciate ghetto wire jump-start power switch) It basically needs a new mid panel section and cable sheathes, then some WC'ing and paint and were done. Which is easier said than done actually. |
#54 |
dat steak
I wanted an Aquaero, and Korvus was selling one at a good price, so picked it up.
![]() ![]() It'll be mounted in the front, but seeing as I don't have any 5.25" mounting rails, I need to think of something..
#55 |
sabertooth 990FX
i guess you have a challenge at hand
__________________
#56 |
More duct tape!
__________________
#57 | |
May contain traces of sanity.
Interested seeing how this shiny shiny shiny project goes along.. *not a corvid. nope.*
__________________
Current Rig: Intel 3570K | Asus Z77 Sabertooth | 8GB Corsair Vengeance 1600 RAM | Crucial M4 120GB SSD | 2TB Seagate Barracuda 7200 | EVGA GTX680 SC Signature Editon | Asus Xonar D2X | Corsair HX850W | Fractal Design Define XL R2 (Black) Cooled by: Aquaero 5 Pro | Alphacool NexXxos XP3 | Alphacool Monsta 240 | Laing D5 ------------- Current build
#58 |
Go Mankz! Back on the modtrain!
What happened to the drive bays?
__________________
#59 |
dat steak
They were, for want of a better term 'hocked' out a while back.. Don' have any 5.25" devices bar the Aquaero, so no need for them really.
#60 |
How about mounting it vertically, in the roof facing upwards!?
__________________
| Thread Tools | |
| View Mode | |
