View Poll Results: Pump orientation, facing forward or facing backwards?
Pumps facing backward 16 43.24%
Pumps facing forward 21 56.76%
Voters: 37. You may not vote on this poll
Reply
Thread Tools View Mode
Old 27th Nov 2012, 17:53   #241
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Squigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the Dremel
Gots me a new toy today
Since i am not making my own bezels i wont be useing the hinge system I was working on, so got a triple monitor stand
Am really happy with the stand, wont be using the bottom foot on the desk as it will be incorporated to the piece i turned before, but can handle both portrait and landscape modes easily without to much fussing
the bezel in landscape is much better, as the monitors have a slightly thicker bottom bezel
still on for starting final build on the desk this weekend *happy dance*
__________________
Ω Omega Desk Ω
Squigly is offline   Reply With Quote
Old 27th Nov 2012, 18:01   #242
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Nice
Waynio is offline   Reply With Quote
Old 27th Nov 2012, 22:52   #243
Bladesingerz
Supermodder
Bladesingerz's Avatar
Bladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the Dremel
Very nice Squigly! Looking forward to the next update!
What wall mount is that if I may ask?
Bladesingerz is offline   Reply With Quote
Old 28th Nov 2012, 05:24   #244
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Originally Posted by Waynio View Post
Nice
Thanks gents!! Blade its actually a desk stand, the foot of the stand wont be used in final build though, you can see it here
__________________
Ω Omega Desk Ω
Old 1st Dec 2012, 16:17   #245
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Ok so i was all *happy dance* about getting a major update done today.. Was expecting my parts back from the powder coaters, unfortunately due to some power outages they had had recently they were further behind that i thought.. so not even a single part was delivered back...
So all I could really do was finish work on the screen stand mount, Since the intention was to use a 76mm diameter pipe for the central stand when i was planning my own screen cases. Now the problem was the central stand for this new system works off a 36mm pipe, much smaller than my original 76mm, and I didn't really want to throw that piece i had machined away..
So this is how the stand is by default, I needed to remove the large foot piece to incorporate it into the previous stand
And the stand that i had machined before, you can see the 3 grub screws i had put in that were to hold the original 76mm pipe, that flat pieces near the bottom slot between parts of the frame, and the bottom plate is bolted on to secure it to the frame.
So what I ended up doing (as luckily I still had some material left over) was machining a piece with a 76mm OD and a 36mm ID :cool: I also added grub screw to that so i could secure this plug onto the main pipe and then use the original grub screws to secure the plug to the main stand... I also machined some other area's to make the two fit together nicely
I also added a slot into the pipe for cables for monitors, keyboards etc to be routed into the main case
Ok so these are the parts now for the main stand
To illustrate, the plug secured to the pipe with 3 grub screws
And the plug secured in the main stand
So was happy i could at least find a solution to the new screen stand, I am also officially on leave until next year :shaky: so should the powder coating be completed i will be around in a flash to pick it all up!!!
Thought I would also include some shots of the screen stand as it is by default, screens are set in landscape for now.
I really like the arm system on this stand as it fits the desk theme pretty well (view from back)
well.. thats about it then till i get the all important call...
__________________
Ω Omega Desk Ω
Old 1st Dec 2012, 16:20   #246
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
This monitor stand is awesome. What model is it?
Edit: I'm an idiot. Thanks.
elAwesome is offline   Reply With Quote
Old 1st Dec 2012, 17:05   #247
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
Indeed a lovely stand!
To bad they aren't available here in Holland :/ (I think)
__________________
Preparing: Raz3r D3sk
Finished : L3p Parvum - Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 5th Dec 2012, 13:10   #248
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Thanks guys!! l3p im pretty sure you could get it there, as far as i know its not a local brand ;-)
Right so no word from powder coating, but I did get a call from the nickle plating place was amped to pick them up, now they were all sealed and I only got a look at the waterblock plates and all seemed good.. anyways i got home and eagerly unwrapped the pipes.. at first glance it looked as if they had sanded the pipes even though i had polished them to a mirror finish.. was LESS than impressed.. anyways I got the buff out and just tried with the drill machine.. luckily they buff to a nice smooth finish so may have just been the coating process.. I am really hoping so.. will pop into the workshop 2morrow so i can buff them properly on the lathe..
anyways here you can see the finish i got from them on the right and the pipe on the left i buffed a bit, must say the buffed pipe is looking rather yummy.. hopefully they all turn out nice and mirror..
So anyways back to the block, as a reminder the block was originally copper and acetal as can be seen here
the plates fresh back from nickle
And mounted
I really like the look now and will fit in so well with the build
Will do an update 2morrow with the polished pipes...
__________________
Ω Omega Desk Ω
Old 5th Dec 2012, 13:14   #249
Sarakon
The German
Sarakon's Avatar
Sarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run Crysis
Originally Posted by Squigly View Post
What building is that in the background. It looks so familiar, just can't quite place it.
Other than that, the piping looks really good. Assembly time must come faster
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M
World Of Tanks: Sarakon | BF3: SarakonGT
Sarakon is offline   Reply With Quote
Old 6th Dec 2012, 15:34   #250
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Tell me about it!!! Its apartments in Sandton, forget the name of them
Ok so headed into the workshop to get the pipes properly buffed and to what they should be, As mentioned before i am using a lathe to assit me here, so have the buff in the chuck and then hod the pipes by hand, can get a little tricky and the pipes get SUPER hot, even with welding gloves on..
Spent most of the day polishing the pipes, really wanted them to have a nice mirror finish, and after a full day of toasty hands, this is the result..
A little closer
Ahh but wait... what is that, that the pipes are resting on????
yup, thats all the parts back from the powder coater on the dining table (da wife gave me a look for doing that ) Took a break today from polishing to walk over to the powder coater, they are across the street from the factory luckily just to check in to see how it was going, to be pleasantly surprised that it was all finished and I could collect :dance: unfortunately I had to leave the frame back at the workshop but arranged for it to be delivered tomorrow so i can build away over the weekend
__________________
Ω Omega Desk Ω
Old 6th Dec 2012, 15:48   #251
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Where/How did you get the block nickle plated? Was it copper before?
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 6th Dec 2012, 18:53   #252
mal
What's a Dremel?
mal's Avatar
mal has yet to learn the way of the Dremel
Squig,
When you get to it could you post how you bleed your system? I too am planning a desk type build, and am not looking forward to tipping such a large piece of furniture to remove air bubbles.
Mal
mal is offline   Reply With Quote
Old 6th Dec 2012, 21:09   #253
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Yup i had them coated, they were copper before, I used a local company here that also did my copper pipes
Originally Posted by mal View Post
Squig,
Mal
Will do bud, I normally find the bubbles tend to sort themselves out after a day or so, but will be sure to post any "special" attempts I have at bleeding
Ok so first of the final images, been a long time coming so just a few teasers for now
more soon
Squigs out
__________________
Ω Omega Desk Ω
Old 6th Dec 2012, 22:04   #254
l3p
www.^.nl
l3p's Avatar
Ohhhh boy .. Can't wait!
__________________
Old 6th Dec 2012, 23:36   #255
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
The plating on those pipes looks top notch .
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 6th Dec 2012, 23:41   #256
dotdrew
Minimodder
dotdrew's Avatar
dotdrew has yet to learn the way of the Dremel
The plating on those pipes looks fantastic after buffing, can't wait to see it all put together.
dotdrew is offline   Reply With Quote
Old 7th Dec 2012, 01:29   #257
Waynio
Waynio's Avatar
The pipes polished up real nice congrats & can't wait for the final shots.
Old 7th Dec 2012, 13:56   #258
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
can't wait to see it all together. this wait is gonna be as bed a christmas eve!
__________________
Project: RAt MoD - Update 16th June '13 - Deliveries of the Banned
i5 3570K, ASUS Maximus 5 Gene, Gainward GTX 670 Phantom, 4GB 1600MHz G.Skill RipjawsX CL6,
Modded Antec Kuhler 620, Enermax Revolution 1050W, WD Raptor 150GB , Antec P182
How to Get a FREE (sort of) Hard Drive and Other Small Parts
The_Crapman is offline   Reply With Quote
Old 7th Dec 2012, 14:31   #259
The_Gnu
8-bit addict
The_Gnu's Avatar
The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.The_Gnu is a hoopy frood who really knows where their towel is.
Sweet buffing going on there.
I have to say I'm a bit jealous at the moment, getting parts back from treatment is like christmas. Sharpen your screwdriver, fill up the fridge with beverage of choise and have a nice weekend of assemblying.
Awsome project, and rep + for doing a desk with a pretty challenging shape.
__________________
Project: ProtoHype (paused)
Project: GET A LIFE (Complete)
Project: Widescreen Projector(Complete)
Guide: How to brush Aluminum
The_Gnu is offline   Reply With Quote
Old 10th Dec 2012, 09:58   #260
bluc
Supermodder
bluc has yet to learn the way of the Dremel
MOAR UPDATES. !!
Sent from my Nexus 7 using Tapatalk 2
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
bluc is online now   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
