| View Poll Results: Pump orientation, facing forward or facing backwards? | |||
| Pumps facing backward |
16 | 43.24% |
| Pumps facing forward |
21 | 56.76% |
| Voters: 37. You may not vote on this poll | |||
Thread Tools | View Mode |
#261 |
has finished Blue Horizon
Cant wait to see those pipes installed they look awesome
#262 | ||||
MODfiend.. ~twitch~
Ok so been busy with the build since last Friday, been a hectic few days but machine is finally back up and busy posting from it now, Alas the glass company let me down and didnt deliver yesterday (or today for that mater) so still not 100% done.. but lets start at the beginning shall we.. So Friday of course I had all the pieces back from the powder coater, I needed a few more cables and to pick up all all important :mdpc: package (A big thanks Nils!!!) ![]() So started pretty late Friday afternoon, wont go step by step as there are over 150 images of the build alone ( a big thanks to my dearest wife for being my photographer during all of this) but started with mounting some panels ![]() ![]() could then start with a few components slowly but surely ![]() first of the rear tubing ![]() jumping ahead a bit now, got the mobo in, and all cards as well as most of the front tubing in ![]() ![]() then got busy with a few more panels ![]() time for that monster 1080 radiator, this is a shot of the little power distribution board i had made up before from some vero board ![]() and mounted on the panel ![]() Then in the desk ![]() of course MDPC is adding its special touches everywhere ![]() an innards photo of the two temp sensors and cd bay ![]() I also painted in the logo on the CPU block like i did the GPU blocks ![]() first drive mounted ![]() storage drives done ![]() back to finishing off the piping ![]() got the pumps mounted ![]() MAN DOWN!!!!! nope just busy connecting up some cables for the drives, but at this point it I was feeling like the desk was winning a bit![]() Of course all cables were nicely sleeved, went with shrikless for all points, love this stuff!! ![]() more panels mounted... ![]() and finally last piece of the waterloop in, the flow meter.. was a happy momnet! ![]() got the top panels and screen mount prepped and installed ![]() ready for screens ![]() ![]() then got the cable routing panels covered ![]() ![]() ![]() After a slight snag where i need to get a 90 degree adaptor for one of the screen cables as its JUST to short, had to change the screen rotation for the moment, also got the front plexi and front panel mounted ![]() front UV leds mounted ![]() then it was crunch time... time to fill the loop and do a leak test, just one small leak in the back ares where my muppet self didnt tighten the one connector so an easy fix with minimal spill.... luckily!! ![]() after a 24hour leak test with pumps on full power i turned them down and was time t power it up, these are the temp sensors on the radiator btw.. ![]() so this is it for the moment... ![]() Still to do: Phone and hound them to bring the glass (mount glass) lolz also need to mount the back panel and get the 90 degree adapter for the screens... and that's bout it!!! Will of course do a bunch of final shots when its all ready, as well as a vid of the LED breathing effect As always thanks for checking in peeps Suigs out... needs me a nice cold beer and some rest!!
__________________
Ω Omega Desk Ω |
#263 |
MD of Mutant Zombie Armies Inc
Looking incredible already. Dam those glass people denying us the finished article!
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts. |
#264 |
Budget? What budget?
Un-frickin-believable. This could be my favorite build ever. The first class craftsmanship and attention to detail are simply incredible! Amazing!
#265 |
www.^.nl
Indeed really good looking!
I remember the times laying under and on top of the desk connecting the wires/tubes
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#266 |
Fenrir The Wolf
Wow. Beautiful. Well done,mate.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#267 |
Terminating People Since 1980....
So when are you going to build me one
that's beautiful work such amazing detail
__________________
The Rig: i7 3770K @ 4.6Ghz/ Asus Maximus Gene V/ 16Gb Corsair Vengeance (Red) / 120Gb Kingston V+200 SSD / Asus HD7970 / Corsair AX850 / CM Storm Trooper / Mionix Zibal 60 / The Water: EK Supreme HF CPU Block / EK 7970 CSQ GPU Block / XSPC H2O 750 V4 / 2 x 240mm AlphaCool NeXXXos UT60 RADs / The Project: Antec TwelvOrange |
#268 | |
The German
We want to see the completed desk!!
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M |
#269 |
I know what a dremel is...
I think you might consider put your hdd's on horizontal or vertical position.
I did the same thing on my project (45 degrees angle) and one disk failed last week. |
#270 |
I'll get my stomping boots...
__________________
#271 |
Supermodder
Squigly man, I've been waiting for those final shots ever since you start your project and I must say you didn't fail to impress me. Everything looks so good and amasing, very well done good sir!
Already one of the best desk builds out there. Yup I said it! |
#272 |
Keep calm & mod on. =)
Looking awesome Squigly, looking forward to the final shots of this beauty.
#273 |
Pipebender
Very nice Squig.....makes me want to build one now....
#274 | ||||||||
MODfiend.. ~twitch~
![]() Thanks so much Pranja!! Quote:
![]() Quote:
I'll meet you there, we can leave some imprints in some foreheads ![]() Quote:
![]() lols, me thinks you could out-build me any day, would lurv to see you take on a deskbuild!! ok so as mentioned no glass again today, but i did harass them and put some shoe polish up some rear ends.. so I was promised tomorrow, but honestly, heard that before... anyways a few more final shots, best I can do without the top glass for now.. will let the pics speak for themselves ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
Ω Omega Desk Ω |
#275 |
www.^.nl
Goosebumps!!!
__________________
#276 |
Supermodder
Very nice but turn on the lights lol
__________________
Latest Project: « «[ Little Angel ]» » (FINISHED!) Sponsors: *** Aquatuning | Atlas Informática | NZXT *** *** ProSilentPC | Seasonic | IzarMicro | E22 *** Follow me on Facebook! |
#278 |
The German
I like it a lot
I must come knock on your front door to see it IRL
__________________
#279 | |
MODfiend.. ~twitch~
lols, thanks l3p
![]() ![]() ![]() ![]() ![]() ![]() Also did a shot of temps, this was after about 2 hours of haven
__________________
Ω Omega Desk Ω |
#280 |
Really really nice desk rig & nice temps, I'm liking how that IO piece looks lit up, can't wait to have mine up & running, looks awesome,
hope they get you get that glass real soon too.
| Thread Tools | |
| View Mode | |
