| View Poll Results: Pump orientation, facing forward or facing backwards? | |||
| Pumps facing backward |
16 | 43.24% |
| Pumps facing forward |
21 | 56.76% |
| Voters: 37. You may not vote on this poll | |||
Thread Tools | View Mode |
#41 |
www.^.nl
I wasn't the first one with a desk build, however somehow I drove people mad I guess.
![]() All the people I know that also started a desk build are just like me so full of it and see so many opportunities ![]() I'm really enjoying this thread so much as it's a complete different design
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#42 |
Computer Technician
Subscribed! Can't wait to see more. You have a real talent!
__________________
SUI-OMEGA :: Intel i5-2500K | ASUS P8Z68-M Pro | Corsair Vengeance LP 8GB RAM | XFX 6870 1GB | WD Black 1TB HDD | Corsair Pro 650w PSU | Lian-Li Mini Tower :: |
#43 |
MODfiend.. ~twitch~
l3p you may not have been the first, but you were defiantly one of the first that built a desk that gives most the oooohhhlaalaa feelin when lookin at it!!
![]() Ok well got into the workshop as early as i could but still don't feel I managed to get much done.. Think i spent most of the time contorting my body into weird and wonderful positions trying to drill into some of the smaller corners.. Started off by finished up bending all the profiles, this should hopefully be the lot! ![]() Then started test fitting and drilling them ![]() And got the riv-nuts mounted, so far I think im a close to 130 riv-nuts used... me thinks final assembly once its all been powder coated is gonna take a while.. ![]() ![]() ![]() And finally mounted!! I must say this has brought the panels together nicely, am really happy with the result!! ![]() ![]() I took a break from trying to bend and twist myself into the smaller corners and started working on the screen mounts.. measured them up then filed down some aluminium angle profile to be bent into shape ![]() Bends came out pretty good, just used the vice and bent by hand since its nice and soft.. ![]() I will need to weld these up and then start working on the back plates for the screen case.. I will take some pics of the test fitting later for upload. after that i couldt draw myself back to the small corners so was looking for anything i could do instead ![]() So drilled out the button holes, and test mounted the button, for now there should be 3, power, reset and a lighting switch. ![]() so after that it was back to trying to drill in the corners, after a few smokes and staring at the corners i realised i actually didnt need a mount where i was trying to drill, with the support struts i was putting in it would give sufficient hold and i could simply mount a screw head, for asthetic purposes where i was trying to drill.. had to stop myself from doing a happy dance in the workshop when that little gem struck!! So got the other profile mounted and it worked out great!! ![]() So that was it for this week, will be doing some work on the screen cases during the week hopefully ![]()
#44 |
MODfiend.. ~twitch~
Decided to test the fitment of the screen frame I made up yesterday before I weld it up..
So this is the front frame, this will cover the standard bezel that is normally hidden behind the plastics ![]() Stripped down a monitor and.... it fits like a glove!!![]() I was a little concerned about the top of the screen, there is some components that stick up higher that the rest of the monitor, but the angle profile i got was perfect, will allow me enough clearance to mount the next piece of angle plate that will essentially connect the back cover to this front bezel ![]() All in all it fits really well, of course still some welds in the corners to finish it off, I will be making them black as well once all done. ![]() Also measured out the back plates I will need, so will get those during the week. The total bezel width is 10mm all round compared to the 30 of the plastic covers (50 on the bottom)
#45 |
Supermodder
Awesome stuff
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
#46 |
MODfiend.. ~twitch~
Thanks bud, wish I could spend more time on the build :-)
__________________
Ω Omega Desk Ω |
#47 |
Supermodder
Take your time mate. The more time you spend on it, the less likely you will make mistakes that could cost you, or could slow your build.
It's looking great, this will be awesome to follow (already subbed since your first post). Quality over quantity any day! Keep it up!
__________________
World record holder: 4.491.863 domino's toppled on the 13th of november '09! |
#48 |
Is the daddy!
Perfect monitor surround! Loving this alot now!!!!
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#49 | |
MODfiend.. ~twitch~
![]() Thanks, looking forward to finishing them off and tossing the nasty plastic!! |
#50 |
MODfiend.. ~twitch~
Small update
Managed to get both legs outside panels support profiles mounted today, didnt take any pics as its the same as last week really. I did spend some time this week working on a circuit i will be using for my lighting, its basically a 55 timer LED breather that allows me to control the "breathing" of the LED's in the case, all LED's will be connected to this, I may run 2 or 3 of them for different sequencing but will see.. Its just on a breadboard while i was testing so will have the PC boards made up soon. ![]() Here is a short vid of it in action.. Apart from the support struts I also ordered the Plexiglas for the front of the desk this week so got that marked up and ready for sum cuttin ![]() Got the basic shape cut out, still need to file it down for fine tuning the fitment.. that will take some time! ![]() So back in the corner half stripped.. good news is that i only have 3 more holes to drill for these panels whoooop whooop am ordering the remaining aluminium for the front and back panels so will hopefully start on those next week... and that will mean back to drilling holes again ![]()
#51 |
on air
like your design and your skill .
Keep going !!
__________________
[project log] Apple Cube |
#52 |
Mad Man Modder
Very cool revolutionary design. l3p going to enjoy this one.
#53 |
www.^.nl
I already am
__________________
#54 |
Keep calm & mod on. =)
So nice
sweet desk, nice curves, nice detail panels, bunch of things I like to see in a project all in 1. ![]() ![]() I agree with 1 of the comments in the MOTM thread, this one should be due. ![]() And cheers for pointing out the light breath mod, I'll have a go at implementing that, a lot better than plain none changing light. Oh forgetting the stars & rep.
__________________
Air Cube v2 and gaming tower (Fin Aug 2010) Stealthlow (Fin Sep 2011) Lean & Green - Modular Dual PC Paused Midlag Crisis Last edited by Waynio; 18th Jun 2012 at 21:57. Reason: Oh forgetting the stars & rep :D |
#55 | |
MODfiend.. ~twitch~
Thanks m8, doing the best i can before the baby arrives (less than a month to go, me thinks im not gonna Finnish in time)
lol, Thanks guys!!! Quote:
#56 |
MODfiend.. ~twitch~
Been working on the curcuit to controll the LED's, got some standard breadboard PC board to do the curcuit as apposed to etching an actual board, its going into a project box anyways :-)
Getting there slowly.. problem with using this type of PC board is that there are solid tracks across the underside that i need to cut or "break" at certain points.. made the build of the board a little slow and painful.. I decided to use some 3pin fan headers that i had laying around to get power to the board as well as connect the LED strips.![]() Amazing how doing a simple little circuit can turn my desk into a war zone!! ![]() Finally got the board done and working after a few trouble shooting items (tracks not being cut where they were needed) ![]() Here is a better video of the effects the board allows, flash in fade out, fade in flash out, pulse or breathing effect.. Then got it onto the project box and fed the cables through ![]() Done and ready to be mounted in the current rig till the desk is built :-) will do another vid tonight showing the effect. ![]() the more i think about it i think i am going to run a single board for all the lights.. if i add another for different sequencing on some lights i think im going to end up with a Christmas tree effect... ![]() Update with vid of it controlling the CPU cooler lighting Last edited by Squigly; 19th Jun 2012 at 17:46. |
#57 |
on air
It's remember me the light effect of my razer lachesis mice !
see here : http://www.youtube.com/watch?v=y85XuTDd2PU You must get one for your desk !!!
__________________
#58 |
Supermodder
Like the led lit water block very nice!
__________________
#59 |
Very nice tidy control box mate.
Will be a highly impressive lighting mod especially if you can run quite a bunch of LED's through it, looks great on the CPU cooler.
#60 |
Fenrir The Wolf
Is that 555 PIC?
| Thread Tools | |
| View Mode | |
