View Poll Results: Pump orientation, facing forward or facing backwards?
Pumps facing backward 16 43.24%
Pumps facing forward 21 56.76%
Voters: 37. You may not vote on this poll
Reply
Thread Tools View Mode
Old 10th Jul 2012, 10:47   #101
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Squigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the Dremel
Originally Posted by Waynio View Post
And there's one of the neat things that can be done with lathes again some things simply need a lathe but for the few things I'd use one for I can't justify the cost of 1, not yet anyway.
Awesome piece made there.
Unlucky on the first pci/io back piece, I never did get around to perfecting the bending method for a 1mm panel version, made some smaller bending fingers for the different sections of bend though, before perfecting that I started using 5 layers instead to make a solid one after seeing a billet 1 piece one on a project called Limey & fell in love with the idea which translates to multiple layers brilliantly.
Thanks Wayne, funny you should mention billet 1 piece.. after bending the failed plate it was my first thought!! luckily (or unluckily) i didn't have a piece of ally in the workshop that would have worked.. but that put me back in line to do it properly..
Originally Posted by The_Crapman View Post
mmmmm, lathed....*droooool*
Plexi centre looks great too. Maybe overlaid with some alu with the same/similar designs to the leg?
Thanks Crapman, was really happy with the way it turned out.. and a nice suggestion about some layers there.. will definitely look into it!!
__________________
Ω Omega Desk Ω
Squigly is offline   Reply With Quote
Old 10th Jul 2012, 10:58   #102
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
If you can do it do it mate.
Billet PCI/IO is so.
Just make absolutely sure your model is very very correct so it isn't a waste.
Waynio is offline   Reply With Quote
Old 10th Jul 2012, 11:08   #103
bluc
Supermodder
bluc has yet to learn the way of the Dremel
You get my vote your quality workmanship amazes me bummer with the io shield
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
bluc is online now   Reply With Quote
Old 10th Jul 2012, 13:13   #104
riekmaharg2
has finished Blue Horizon
riekmaharg2's Avatar
riekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremelriekmaharg2 has yet to learn the way of the Dremel
I just discovered this mod on MOTM, you got one of my votes, the design is very cool, and that spindicator is awesome
__________________
Scratch Builds
Silent Fiberglass PC
Completed * Blue Horizon * - 2012
riekmaharg2 is offline   Reply With Quote
Old 10th Jul 2012, 14:54   #105
Sarakon
The German
Sarakon's Avatar
Sarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run CrysisSarakon can run Crysis
It looks clean and nice and blue would suit it perfectly and you should go with the plexi midplate.
__________________
Obsidian 650D | Asus P8P67 EVO | Intel i5 2500K | OCZ Vertex 4 | Corsair Vengeance 16GB | MSI GTX 660Ti PE OC | Cooler Master 850W Silent Pro M
World Of Tanks: Sarakon | BF3: SarakonGT
Sarakon is offline   Reply With Quote
Old 12th Jul 2012, 07:49   #106
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Im going to try using a plain sheet again, but bending the profile first and then cutting the inserts out.. if it fails again though i will go with a billet.. will try track down a CNC milling machine first though to try reduce the chance of error of doing it manually on the mill.. Im probably going to be replicating the hinge system for my screens with billet pieces.. went yesterday to pick up my order and they only sent 1 hinge (i thought it was a set of 4) which was really surprising based on the cost of a single hinge.. but of course being a mod junkie the first thing i did was wrip the hinge apart to see how it all works and see if i could replicate it myself
Thanks bluc, truly appreciate the vote and kind words!! Hopefully v2 of the plate works out
Thanks riekmaharg2, still seeing if i can tweek the spindicator to work of CPU usage rather than HDD usage.. Im a complete noob at arduino boards but this could be a great opportunity for me to practice
Thanks Sarakon Im thinking of using both actually, and then cutting a design into the plexi for a "lighting" effect.. think it will bring a little life to the center of the build.. still working on some concepts there..
__________________
Ω Omega Desk Ω
Old 14th Jul 2012, 13:19   #107
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Sup peeps
Well not really an update to the desk, more a life mod update
We were joined by our little angel on Friday morning.. Yes she's a Friday the 13th baby
Back to the desk soon enough
__________________
Ω Omega Desk Ω
Old 14th Jul 2012, 13:24   #108
tekonivel
Multimodder
tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!
congratulations!
tekonivel is offline   Reply With Quote
Old 14th Jul 2012, 14:04   #109
Shurika
Multimodder
Shurika's Avatar
Shurika has yet to learn the way of the DremelShurika has yet to learn the way of the Dremel
I congratulate from all my heart, happy dad!
__________________
sorry for my English
Shurika is offline   Reply With Quote
Old 14th Jul 2012, 14:13   #110
RebootTech
Budget? What budget?
RebootTech's Avatar
RebootTech has yet to learn the way of the DremelRebootTech has yet to learn the way of the Dremel
Life mod updates are WAY more newsworthy! Major congrats!
RebootTech is online now   Reply With Quote
Old 14th Jul 2012, 15:02   #111
Waynio
Waynio's Avatar
Now there's an awesome creation, congrats mate.
Happy fatherhood.
Old 14th Jul 2012, 15:32   #112
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
Congratulations!
__________________
Preparing: Raz3r D3sk
Running : L3p Parvum
Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 14th Jul 2012, 15:44   #113
Samaya
Lion Country
Samaya's Avatar
Samaya has yet to learn the way of the Dremel
Little ones are awesome. My 5 yr old is in the bath singing to herself and playing with dolls. Fantastic racket...
Congrats with your new born
__________________
READY!!! FIRE!!! AIM!!!
Samaya is offline   Reply With Quote
Old 14th Jul 2012, 16:08   #114
Sarakon
The German
Sarakon's Avatar
Congrats mate!!
__________________
Old 14th Jul 2012, 20:45   #115
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
congratulations !
KoSoVaR^ is offline   Reply With Quote
Old 15th Jul 2012, 08:01   #116
xtoxm
What's a Dremel?
xtoxm has yet to learn the way of the Dremel
Congratulations!
xtoxm is offline   Reply With Quote
Old 15th Jul 2012, 09:55   #117
Balder
Calmer than a monk on morphine
Balder's Avatar
Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.
Grats on the wee one!
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem.
- Martin Luther King, Jr.
Balder is offline   Reply With Quote
Old 15th Jul 2012, 09:56   #118
paz45
Supermodder
paz45's Avatar
paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.paz45 is a hoopy frood who really knows where their towel is.
Congratulations
paz45 is offline   Reply With Quote
Old 15th Jul 2012, 12:08   #119
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
Congratulations mate. You got yourself a cutie there! Hope mother and baby are doing well.
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts.
The_Crapman is offline   Reply With Quote
Old 19th Jul 2012, 15:05   #120
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
And on we go...
Yo yo peeps
A big thanks to tekonivel, Shurika, RebootTech, Waynio, l3p, Samaya, Sarakon, KoSoVaR^, xtoxm, Balder, paz45 & The_Crapman for the well wishes with the new baby, Mom and little one are doing very well and settled in at home.. as for my sleep patterns.. well yes those leave much to be desired (& I have no disillusions that this will be remedied anytime soon)
Been home all week but have had little to no time to work on the desk, changing diapers and catching up on sleep has been the order of most days.. But I decided to do some work on the scroll saw today and with the afford mentioned lack of sleep me thinks it may not have been the brightest of idea's... but I walked away with all my fingers in tact so all good.
I have been playing with ideas for the central section, where I was thinking either aluminium or plexi.. I have decided to go with the aluminium with some plexi designs.. started cutting some out and will see which I will end up using in the end
I laid out some templates on a off-cut piece of 5mm plexi i had lying around
Basic shape cut, now to give it some file lovin and then flame polish, my intention is to then light this up with some LED's that will be connected to the fader I built.
Will hopefully head into the workshop tomorrow to get some work done on the desk
__________________
Ω Omega Desk Ω
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
