#1 |
Administrator
bit-tech Staff
VIA announces APC 8750 Raspberry Pi competitor
VIA has announced the ARM-based APC 8750, a neo-ITX machine clearly inspired by the Raspberry Pi.
http://www.bit-tech.net/news/hardwar...via-apc-8750/1 |
#2 |
Minimodder
It seems like a pretty decent device, and at $49 its not that much more than the Pi,comes with android,so its a bit more user friendly than the Pi, whether they can get it to the market quick enough is another story.
Raspberry Pi is still almost impossible to get, so this might make a dent in the market. Lets just hope the community can get behind it and offer some good homebrew goodness over and above the android it allready has. |
#3 | |
I'm a cat, not a furry.
About the PSU.....
From what I have gathered, the RPi just uses a miniUSB port for its power. This uses 12V. So, you might be able to plug it into your case with an extra 12V header. I think I just found the board for the LCD in the side of my case.
__________________
#4 | |
WIIGII!
bit-tech Staff
The Pi will run on any 5V power supply capable of feeding it 500mA on the unlikely-to-ever-be-released Model A or 700mA on the Model B. That's more than a PC's USB port can offer, even after negotiation - which the Pi doesn't do. You could probably build a Molex-to-microUSB adapter and power it straight off the PC's PSU, though.
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter bit-tech news correspondent, Custom PC columnist I'm a filthy freelancer! Hire me! |
#5 |
Supermodder
Gareth, I think AmEv was suggesting running the VIA APC off of a 12v header - not the Pi.
__________________
Antec 300::OCZ 700W ModExtreme PSU::Asus P6TD Deluxe::i7 920::6gb OCZ 1866::Titan Fenrir::1Tb F3 Spinpoint, 1Tb F1 Spinpoint::Sapphire HD5770
#6 | |
WIIGII!
bit-tech Staff
Not sure why, really, as your interpretation makes a lot more sense!
__________________
#7 |
Multimodder
Not sure this comes close to the R-Pi - more expensive, twice the size and no 1080p!
__________________
Intel Core 2 Quad Q6600 @ 3.5GHz (9*390) - Asus P5k Premium Wifi-AP - Palit GTX460 - 4x1GB OCZ Reaper DDR2-1066 - Lian-Li PC-7 Seasonic S600 PSU - Corsair F60 SandForce SSD - 80GB, 200GB, 500GB, 2TB HDDs - 2 DVD Burners Microsoft Windows 7 Ultimate x64 |
#8 |
WIIGII!
bit-tech Staff
More USBies, a VGA output, faster processor (although undoubtedly slower multimedia) and a sensible mounting system, tho'. (I still prefer the Pi, mind.)
__________________
#9 | |
You're right. I didn't quite continue my train of thought.
Seroiously, though, this might make for a decent Linux box for an HTPC.
__________________
#10 |
будет глотать вашу душу.
Now if they were only smart enough to have added 4x sata at that price... these things would be amazing if it had disk support.
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx | creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270 |
#11 |
Supermodder
IIRC, this uses a quad-core CPU. A bit of a step up from RPi.
#12 | |
WIIGII!
bit-tech Staff
__________________
#13 |
Supermodder
It runs android..... :\
__________________
"The essence of the contemporary monetary system is creation of money,out of nothing,by private banks’ often foolish lending..." - Martin Wolf,Financial Times,9th November 2010 Intrigued? Find out more at www.positivemoney.org.uk |
#14 | |
...And you can put Ubuntu, Mint, RH, W8RT on it if you'd like
__________________
#15 |
breaker of things
They are working on a Unbuntu style OS for the Pi but to be honest the Pi is designed more with schools and learning involved with things like the GERT board on the way it can be used perfectly for small robotics projects. Plus its true aim was to get the UK coding again which is something many people myself included have lost.
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW |
#16 |
WIIGII!
bit-tech Staff
Windows RT won't work - it's only for OEM use with a small number of partner companies' SoCs, and this ain't one of 'em. As for the others, they'll only work if VIA opens the bootloader - otherwise you're stuck with whatever version of Android they choose to give you (2.3 currently, with no mention of any planned upgrades.)
I'm waiting to hear back about the bootloader. There are already several "Ubuntu style" distros for the Pi - I used Debian in my review (on which Ubuntu is based) and there's also a Fedora Remix.
__________________
#17 | |
Soylent green is horses!
![]() So being slightly less negative, looks an interesting bit of kit but it's a shame if it's android exclusive and only capable of 720p -- I suppose if it's popular enough *nix hackers will break it so it can run custom distros.
__________________
Event-horizon: i7 2600K @ 4.5 @ ~1.3v | 16Gb Corsair Vengeance @ 1866 9-10-9-24-2T | 2 x 580 1.5Gb (SLI) 772/1002 | Asus P8P67 Deluxe | Crucial M4 256Gb | Spinpoint F3 1TB | Corsair HX1000 | ZM-MFC1 Fan controller | XSPC Dual res | 2 x DDC 18W | Black ice stealth 360 | ThermoChill PA120.4 | EK Supreme HF Nickel | 2 x EK 580 Plexi | 7 x Scythe Gentle Typhoon 1450RPM | Modded TJ07 |
#18 | |
breaker of things
Also not sure if im loosing the plot but im sure i saw something about windows 8 possibly having Arm support on the mobile version though spec wise im not sure if its going to be compatible.
__________________
#19 |
WIIGII!
bit-tech Staff
Windows RT is Windows 8 for ARM - but it won't work on the Pi, or the VIA board. It's designed to be pre-loaded on tablets (and possibly one or two laptops) featuring chips from Microsoft's partners, which include Nvidia and Qualcomm. It won't be available to download, or to buy at retail, and it won't install on any device it hasn't been specifically designed for - even if it uses a near-identical ARM processor.
__________________
#20 |
DemonHighwayman
Does it have a GPS unit ? I tried looking at your link for info Gareth but it's broken.
__________________
Main Rig:Case: CoolerMaster Cosmos S, Motherboard: Asus M4A785TD-V Evo, CPU: AMD Phenom II X6 1100T, RAM: 8Gb 1600Mhz Corsair Vengeance GPU: XFX ATI 5870, Primary HDD: 128Gb Kingston SSDNOW 200, Optical Drive: LG Super Multi Blue HTPC:Case: Gutted out VCR, Motherboard: Asus AT5IONT-I, CPU: Intel Atom D525 @ 1.94Ghz, RAM: 4Gb 1333Mhz Kingston GPU: Nvidia Ion 2, Primary HDD: Hitachi 500Gb, Optical Drive: NEC ND-6500A Laptop Drive |
| Thread Tools | |
