Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 28th May 2012, 17:44   #41
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
They sound gorgeous, worth the money just for that in my opinion.
May have to look into getting a set.
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Splooshiba
My flickr - My blog it'sfilmnotmovie
GeorgeStorm is online now   Reply With Quote
Old 28th May 2012, 17:47   #42
longweight
GIFted
longweight's Avatar
longweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpitlongweight is almost as Godly as yodasarmpit
I will let you know how I get on with modding mine, need to buy a Dremel and a small vice now!
longweight is online now   Reply With Quote
Old 28th May 2012, 17:49   #43
GeorgeStorm
Mm, I'm not a massive fan of the look, so wonder if thick PBT caps have a similar sound/feel or not. May have to look into it.
__________________
Old 28th May 2012, 17:50   #44
longweight
GIFted
longweight's Avatar
I think the noise comes from the material and the weight so think PBT caps might not do it.
Old 28th May 2012, 20:28   #45
hamza_tm
Mod Master
hamza_tm's Avatar
hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.hamza_tm is the Cheesecake. Relix smiles down upon them.
They honestly do sound fabulous. Imagine those on a buckling spring..
__________________
Whisper quiet gaming: 2500k@4.4Ghz | P67a-GD53 | Vengeance 8GB 1600Mhz | Force3 120GB | M4 256GB | WD15EARS 1.5TB (Icy Box USB 3.0) | BenQ XL2411T 144Hz (no moar IPS xD) | X-Fi XtremeGamer | Corsair 550D | GTX680
CM Storm Quickfire Rapid MX Brown (Filco caps) | Steelseries Xai (yay) | Sennheiser PC360 | Steelseries 9HD
hamza_tm is offline   Reply With Quote
Old 28th May 2012, 21:02   #46
longweight
GIFted
longweight's Avatar
Heh
Well when I get my aluminium caps I will do a full typing test on the Filco with browns and the Noppoo with blues
Old 28th May 2012, 21:05   #47
KidMod-Southpaw
Making You Feel Old Since 2010
KidMod-Southpaw's Avatar
KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.KidMod-Southpaw is the Cheesecake. Relix smiles down upon them.
Originally Posted by longweight View Post
Heh
I cannot wait! Also, if I don't like blacks, I'm straight away putting down interest for your Noppoo with blues!
__________________
Project Logs: Refraction - Steampunk Flash Drive
Silverstone PS07 - Asus M4A88TD M EVO - AMD X6 1055T - Asus 7790 Cu 1GB - 8GB Corsair Vengeance - Xonar DG - M4 128GB - Frio - Antec 650W - Dell U2312HM X2 - Poker MX Red - Sennheiser HD 598 - IcyBox3219 (WD Red 1TB X2)
"The fear in my eyes when my lass almost opened contacts, and with the name Alessandro, yours comes up very near the top." - Blazza181
KidMod-Southpaw is offline   Reply With Quote
Old 28th May 2012, 21:06   #48
longweight
GIFted
longweight's Avatar
That sale depends on me finding a white Filco TKL ninja with blues :P
Old 2nd Jun 2012, 14:29   #49
longweight
GIFted
longweight's Avatar
Some much better images of the aluminium key caps have been added
Old 3rd Jun 2012, 22:51   #50
Jester_612
"Jammy..."
Jester_612's Avatar
Jester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for presidentJester_612 should be considered for president
I figure you are one for exacting standards, so you'll want to update the layout section with the ` key being grave accent I think.
__________________
- Jes Vindeqx
i5 2500k @ 3.97Ghz on stock
EVGA GTX 670 FTW @ 1275 Mhz
Jester_612 is offline   Reply With Quote
Old 4th Jun 2012, 06:40   #51
longweight
GIFted
longweight's Avatar
So it's called the grave key? Rep for you my friend! Thanks!
Old 4th Jun 2012, 08:39   #52
Nexxo
There is no rep for awesomeness.
Moderator
Nexxo's Avatar
Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.Nexxo is the Cheesecake. Relix smiles down upon them.
Yup; you have:
grave accent (accent grave): è
acute accent (accent aigu): é
circumflex accent (accent circonflexe): ê
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust
"Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust
Nexxo is offline   Reply With Quote
Old 4th Jun 2012, 09:34   #53
longweight
GIFted
longweight's Avatar
Thanks Nexxo
Old 21st Jun 2012, 20:02   #54
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
I have just looked through this thread, and from what you have said Sir Longweight BROWNS are the best choice for those new to mech keyboards. I am in the market for one xD
I am ot a very good typer. I can't touch type or really look at the screen whilst I type at least on a keyboard. Too many years using a laptop. I'd prefer full size rather than a smaller keyboard.
Price wise I am willing to take the higher end price. Will be coming from a Cyborg V5. Which is an ok keyboard.
One question with any of these mechanical keyboards would i be able to press multiple keys at once?
And which manufacturer would you recommend?
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
MrDomRocks is online now   Reply With Quote
Old 21st Jun 2012, 20:04   #55
longweight
GIFted
longweight's Avatar
I would always recommend Filco as a first board, great quality and lovely to look at! Cost is around £120 for a full size board with browns, would you need UK layout?
Most mechanicals have NKRO so you can press as many keys as you want, quite a few cheaper boards don't though so it is always worth asking before buying!
Is £120 too much?
Old 21st Jun 2012, 20:06   #56
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Is £120 too much?
£120 isn't too much and I was thinking Filco having read the Mech KB Thread at least partialy in the past.
UK Layout is preferred XD
__________________
Old 21st Jun 2012, 20:08   #57
longweight
GIFted
longweight's Avatar
The ninja version is awesome!
http://www.keyboardco.com/keyboard_d...sp?PRODUCT=932
Old 21st Jun 2012, 20:14   #58
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
I was just looking at that website Probably going to buy it at the weekend xD
I like to give things time before I go out and buy them. Simply as I am controlling impulse buying.
I bought my SSD at 3am because I decided I wanted one. Oh and Diablo3 the other day another impulse buy.
__________________
Old 21st Jun 2012, 20:28   #59
longweight
GIFted
longweight's Avatar
I know the feeling! I spent £100 on caps this morning, that was meant to be my weekend money!
Old 21st Jun 2012, 20:33   #60
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
Opps I will spending money out of my savings which I will then replace. As I have a job I can justify it!
__________________
Reply
Tags
cherry, filco, keyboard, mechanical, wasd
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
