Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th May 2012, 12:33   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Enermax Fulmo GT Review
Able to fit multiple water-cooling radiators, does this super-sized, fan-filled case make the grade?
http://www.bit-tech.net/hardware/201...mo-gt-review/1
brumgrunt is offline   Reply With Quote
Old 24th May 2012, 12:59   #2
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
It looks pretty good, but I'd rather buy the Elysium and spend £25 on a decent fan controller.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|16GB|256GB M.2|500GB SSD|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Old 24th May 2012, 13:05   #3
SpAceman
Supermodder
SpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpitSpAceman is almost as Godly as yodasarmpit
I would have liked to see some extra temp stats for the cooling after moving those two fans. Surely it would have been easy enough to fit into the review. CPUs and GPUs get overclocked in reviews to test how well they can be tweaked to perform better. Why cant a case review have something so minor and obvious as moving those two fans?
__________________
i7 4770K | Asus Z87-Pro | 16GB Gskill DDR3-1866 | EVGA GTX 760
Silverstone Raven RV02 | Coolermaster V8 | Crucial M4 256GB | Corsair TX750
Dell U2412M | LG W2253TQ | Ducky DK9008 Pro PBT MX Cherry Greens | Naos 7000 | Logitech X-540 5.1 | Logitech G930
SpAceman is offline   Reply With Quote
Old 24th May 2012, 14:04   #4
lilgoth89
Captin Calliope
lilgoth89's Avatar
lilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyanlilgoth89 is a Super Spamming Saiyan
4x 180mm fans ?? someone needs to get 4 air pens on this board for some INSANE cooling
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850
lilgoth89 is offline   Reply With Quote
Old 24th May 2012, 14:12   #5
aLtikal
1338-One step infront of the pro's
aLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming Saiyan
yeah It would be good to see the temps with the 2 side fans moved to the front. If your worried about skewing the results then just post it in the forums, surly its worth doing as I wonder if its the only case in its class that offers that capability, so it would be silly not to explore its potential.
__________________
aLtikal's Rig...
| Antec P182 | Q6700 @ 3.1Ghz| Abit AB9 Pro | 5770 1Gb Vapor-X | 4GB 800mhz Geil BlackDragon 4-4-4-12 | XtremeMusic | Z-5500's | MX-518| Samsung 2232bw 2ms 1680x1050|
aLtikal is offline   Reply With Quote
Old 24th May 2012, 14:25   #6
HHawk
What's a Dremel?
HHawk has yet to learn the way of the Dremel
Quick question:
I read the following from the review:
"Enermax has likely used the same OEM manufactuerer as Xigmatek's Elysium, so both share a very similar, spacious internal layout."
Does this mean that the sidepanel from the Enermax would also fit on the Xigmatek? I would be grateful is someone could answer this for me?
Thanks.
HHawk is offline   Reply With Quote
Old 24th May 2012, 14:33   #7
bullseye
Who dares wins
bullseye has yet to learn the way of the Dremel
How is this a Grand Tourer? Does it come with wheel barrow attachments.
bullseye is offline   Reply With Quote
Old 24th May 2012, 14:38   #8
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
£183 is still a staggering amount of money to spend on a case.
The TJ07 is only £7 more at Scan
http://www.scan.co.uk/products/silve...x-ssi-(w-o-psu)
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 24th May 2012, 15:22   #9
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Time to go and see if OC3D.net have done a review as TTL normally reviews them with Rad's in the places that they are able to be put.
Good review but not the case for me to replace the poor old Cosmos 2 Ultra that is really not Watercooling Friendly or no where near as friendly as the Xigmatek Elysium.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 24th May 2012, 18:39   #10
docodine
killed a guy once
docodine's Avatar
docodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for president
Looks like a CM 690
docodine is offline   Reply With Quote
Old 24th May 2012, 19:09   #11
Kacela
Minimodder
Kacela has yet to learn the way of the Dremel
If I ever bought one of these monsters, the first thing I'd do is repaint those cheap looking, and almost case-ruining, silver plastic strips - they are distractingly tacky... I'll stick with my similarly-sized Lian Li for now.
Kacela is offline   Reply With Quote
Old 24th May 2012, 21:56   #12
KingSheepy
?lemerD a s'tahW
KingSheepy's Avatar
KingSheepy has yet to learn the way of the Dremel
Originally Posted by docodine View Post
Looks like a CM 690
I'm pretty sure it is one, even down to the tool-less 5.25" bays. I've seen a lot of cases that look like 690s, I reckon they're being dished out by some OEM and rebranded because there's stuff like it everywhere!
__________________
Phenom 955 BE | Freezer 7 Pro Rev. 2 | 870A-G54 | 2x4GB DDR3 | 4850 512MB | WD 1TB | CM690 | OCZ 500w
KingSheepy is offline   Reply With Quote
Old 24th May 2012, 22:48   #13
N17 dizzi
Mod Amateur
N17 dizzi's Avatar
N17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming Saiyan
N17 dizzi is offline   Reply With Quote
Old 25th May 2012, 01:33   #14
Tulatin
The Froggy Poster
Tulatin's Avatar
Tulatin has yet to learn the way of the Dremel
I've never really been much of a fan of the Fulmo, or it's variants. The plastics and top I/O features just make it feel like an upscaled 690 II at a much bigger price.
Mind you, the Fulmo Basic is definitely cheap, but then you have to add your own fans.
Tulatin is offline   Reply With Quote
Old 25th May 2012, 04:42   #15
penryn 2 hertz
I'm not a science fiction writer...
penryn 2 hertz's Avatar
penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.penryn 2 hertz is definitely a rep cheat.
Looks like a CM 690
My thoughts exactly...
__________________
“The atoms of our bodies are traceable to stars that manufactured them in their cores and exploded these enriched ingredients across our galaxy, billions of years ago. For this reason, we are biologically connected to every other living thing in the world. We are chemically connected to all molecules on Earth. And we are atomically connected to all atoms in the universe. We are not figuratively, but literally stardust.”
― Neil deGrasse Tyson
penryn 2 hertz is offline   Reply With Quote
Old 25th May 2012, 07:38   #16
fluxtatic
Supermodder
fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.fluxtatic is the Cheesecake. Relix smiles down upon them.
To me, it looks like the bigger brother of some of the Dell Optiplex boxes we have at the office. That is to say, no thanks.
fluxtatic is offline   Reply With Quote
Old 25th May 2012, 08:05   #17
alpaca
llama eats dremel
alpaca's Avatar
alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.alpaca is a hoopy frood who really knows where their towel is.
I'd like some results with the fans moved somewhat to the front. And if you're at it, it would be mighty nice to just run a test with all fan mounts filled, just so you can say: its horribly loud, and the cooling is only a bit better, but its HOVERING....
__________________
my English may not be as good as I think it is...
alpaca is offline   Reply With Quote
Old 25th May 2012, 15:45   #18
sloth1969
What's a Dremel?
sloth1969 has yet to learn the way of the Dremel
I have this case am in process of building a water cooled unit with a 360 up top with a 240 vertical next to the hdd cage and a 120 on the bottom. Will be posting photos when finished. Only on complaint which they moved the motherboard up a bit so you could stand the power supply on it's side like the TJ11 so I could have a bigger read on the bottom
sloth1969 is offline   Reply With Quote
Old 26th May 2012, 10:49   #19
ev1lm1nd666
Multimodder
ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!ev1lm1nd666 - it's over 9000!!!!!!!!1!1!1!!!
I know this is a minor gripe guys, but I've read a lot of case reviews where you have berated the manufacturer for not fitting more fans (yes, i agree they should be berated at least a little for it). As a lot of us would fit extra fans in our cases anyway, would it be possible to fill every fan space available and add that to the temps graph?
I know I prefer to have more fans and have them run slower than have only 2 or 3 and run em on high for example...
That way, we can see the true cooling potential for the cases.....
__________________
AMD FX 4100 @ 4.6Ghz, ASUS M5A97 PRO, EVGA GTX 560 Ti @1Ghz 2200Mhz Mem, 8Gb Corsair Dominator DDR3 1600, Corsair CX600 PSU, Antec 300 Case, Samsung Multyi DVD Drive
ev1lm1nd666 is offline   Reply With Quote
Old 26th May 2012, 10:52   #20
ev1lm1nd666
Multimodder
Also, if you use the same fans for all reviews, we get even more comparable results as not all fans are made equal.....
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
