#81 |
What's a Dremel?
Looking forward to full assembly
#82 |
Multimodder
Thank you guys, I'm very honoured!
#83 |
Multimodder
#84 |
Multimodder
Some work as well this morning.
I fixed the folds of the panel inside the frame of the motherboard and I must say you've got an array millimeter. I drilled a hole in the front as below, so it is completely fixed to the case. Now that the structure is more firm, and ready to accommodate the various glasses, especially in the square box inside where there will be the glass with the support for the two Laing. Now go enjoy the photos! ![]() ![]() ![]() ![]() ![]() ![]() Finally, I repositioned the new trim package 2 mm thick, practicing new holes where needed. Having doubled the thickness of the trim package, I got a considerable increase in strength bulkhead diminished in part because of the rectangular cutouts for the windows. ![]() To conclude, I encountered a small problem: the panel where you see the rectangular slit front, I interfere with the closing of the door. I have already thought about how to fix it. In the lower part of the case, will practice one hole to insert well bulkhead and in the upper part of the panel in order to thread the coupling of the same to the homes. Tomorrow morning I'll work and you'll understand better what I mean. [FONT=Verdana][/FONT][FONT=Verdana][/FONT]
#85 |
Multimodder
at the start when i look at this project i think - he insane :P
all those fittings, all this stuff he gonna have in this case:O but now when its coming closer to the end it looks really nice.. i cant wait for you to throw more updates in my face... happy modding
#86 | |
Multimodder
Ok, I think that in this period I have more time instead of the month when I started the mod. Now I can show you ups quick like an eagle ![]() So, stay close to my WL and enjoy yourself! |
#87 |
Multimodder
Well guys, I'm back.
I have almost completed the installation of all parts in stainless steel, I need only the panel and the little frame of the front bulkhead. Sorry for the poor quality of the photos, but I've done with the iPhone in the middle of the dark garage. Before I applied the tape to sign myself the path to be cut with the Dremel, after the cut, I applied the small panels, one inside and one outside. I already made a test with glasses, but I have not photographed ... I'll suffer a bit '. ![]() ![]() ![]() ![]() ![]() Next time...
#88 |
Multimodder
Christmas is near, and my wallet cry after this beatiful things that I bought yesterday...mmm...Zotac GTX670 2GB and Corsair Dominator 3x2 GB CL8 1600 Mhz.
The mod continue tomorrow, because is a public holiday in Milan, so no job [FONT=Verdana][/FONT] more mod Keep follow me guys, I'll show you orange emotions with this mod!!! Stay tuned!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#89 |
Multimodder
My sponsorship
#90 |
Never stuck with stock@Hotmods.net
Subbed.
This log needs more views! I looooove the use of real glass you italians put into your builds. Reminds me slightly of Corsaronero's test bench with the green glass from Murano. Excellent.
__________________
Best regards, Nutman Project: Nutman - Sponsored by: Coolerkit - Specialtech - EK Waterblocks |
#91 |
Multimodder
Thank you Nutman!!!! Thank you very much!!!!
I hope that this mod will be more beatiful than 800D that I made some months ago. |
#92 |
Multimodder
[FONT=Verdana]Good morning guys, I finally finished the assembly of the water tanks. I'll show you all the materials that I used for the water tank. In a first option, I wanted to put silicone between the glass cylinder and the steel support, but aesthetically, It was very bad. So I decided to put white gaskets in place of silicone. Using the gaskets, I'll can clean the water tank, without disassemble it. [/FONT] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
__________________
DAVE'S MOD My GBW Obsidian 800D - My Glass & Steel Orange Graphite 600T - CM Cosmos II Modern Facebook Page & WEBSITE https://www.facebook.com/Dave2010Techarena - http://dave2010techarena.weebly.com/ |
#93 |
Addicted to modding.
Thats a sweet looking res, fits in with the build perfectly.
Cant wait to see this finished. We need moaaar |
#94 |
Fenrir The Wolf
That reservoir looks great.
Did you welded those mounting brackes or you just used screws to connect two metal plates? |
#95 |
Hypermodder
Looking verry good
!/follow !
#96 | ||
Multimodder
Thank you Kenny!!!
__________________
#97 |
Multimodder
Oh man i ve got no words to say,i really like your mod,and the reservoir is the best....well done
#99 |
Multimodder
Thank you guys, I'm very happy to read this words to me!
Today, I make the other reservoir, one for the cpu loop and the second for the vga loop. Stay tuned, I'll continue next weekend!!!
__________________
#100 |
Multimodder
__________________
| Thread Tools | |
| View Mode | |
