Reply
Thread Tools View Mode
Old 3rd Feb 2013, 23:31   #161
Dave2010_TA
Supermodder
Dave2010_TA's Avatar
Dave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpitDave2010_TA is almost as Godly as yodasarmpit
Hey there!
I'm back with a couple of working days in which I started and almost finished the first loop of liquid cooling (cpu + ram + Aquaero).
I look forward to the times terrifying Aquacomputer I'm calling over and over again for the waterblock for the 670, which looks almost a month and a half.
Look at these pictures and if you have any questions, well Make it as you want!
Dave2010_TA is offline   Reply With Quote
Old 3rd Feb 2013, 23:32   #162
Dave2010_TA
Supermodder
Old 6th Feb 2013, 01:13   #163
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Looking great. The only thing I would change is the fitting leaving the radiator in that last pic, I'd use a 90, not a 45 to make it a bit more inconspicuous. Just my 2 cents.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 6th Feb 2013, 23:02   #164
Dave2010_TA
Supermodder
Hi!!!
That fitting is 45 because I must open the black grill; if I put a 90 fitting, I won't open the grill.
With the 45, the tube make a soft curve, instead of a "line".
Old 7th Feb 2013, 11:51   #165
The boy 4rm oz
Project: Elegant-Li
Ah I see, not a problem then.
__________________
Old 7th Feb 2013, 15:27   #166
Dave2010_TA
Supermodder
Old 8th Feb 2013, 00:17   #167
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Looks very, very nice.
If I had to complain about one thing, though, it would be that I think it's a shame that, since you fitted the pumps in there yourself, you didn't put the pumps right under each res, so the feed line from res to pump would be dead straight. It looks a bit "cheap" with the tubing bending slightly like that. That's all.
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 11th Feb 2013, 09:46   #168
Dave2010_TA
Supermodder
I'm back.
Between yesterday and today I completed the loop 100% cpu-ram-Aquaero-filter-rad expense.
I drilled well to the grill and the top of the case and I affixed the rubber seals that are used in the cabinet to run the cables from the mobo to the bulkhead behind the latter.
I anticipate that I have in mind a little something with quick release fittings that blacks will try to make sure you can still open the door behind the radiator, once installed the entire system.
Next, I opened the top to make room for fittings for refilling the trays.
I masked the cuts with the rubber glued on the edges of the cut.
Retrace all the primary loop: pump, wb ram, cpu wb, passive radiators, flow sensor, wb Aquaero, filter, tank, pump.
Evidence of lighting.
This morning I mounted the LED strip in the rear bulkhead, the glass panel behind the pumps and the "square" of glass on the bottom of the case.
The photos unfortunately do not return the exact effect real, why is not that a great photographer, indeed.
Old 11th Feb 2013, 09:47   #169
Dave2010_TA
Supermodder
[FONT=Verdana][/FONT]
Old 11th Feb 2013, 10:58   #170
k.3nny
Hypermodder
k.3nny's Avatar
k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.k.3nny is a hoopy frood who really knows where their towel is.
Awesome !
k.3nny is offline   Reply With Quote
Old 11th Feb 2013, 12:32   #171
Dave2010_TA
Supermodder
Thank you!!!!
Old 11th Feb 2013, 16:19   #172
Nutman
Nutman's Avatar
Yeah, it's OK. But I feel like you could have done much better with i.e. mounting some pass-through fittings instead of rubber grommets - like these ones:
http://www.aquatuning.us/product_inf...el-plated.html
Same goes for the reservoirs, where I think it would have been much nicer with some fillports instead of cutting out that big chunk of the top mesh. I do realise you didn't have much room to play with, though...
__________________
Old 11th Feb 2013, 17:04   #173
vanos
What's a Dremel?
vanos has yet to learn the way of the Dremel
Nice and clean...
vanos is offline   Reply With Quote
Old 11th Feb 2013, 17:23   #174
Father-Time
Multimodder
Father-Time has yet to learn the way of the Dremel
The glass effect is just STUNNING! and every time i see them res's i just drool!
I agree with nutman on the fill ports, though it looks like they will be hidden anyway....
Awesome skills and ideas too, well done!
__________________
Current Project : Server mod incoming!
Father-Time is offline   Reply With Quote
Old 12th Feb 2013, 13:50   #175
Dave2010_TA
Supermodder
Thank you guys, I thought about the top...suprise next days!!!!
Old 12th Feb 2013, 13:54   #176
Dave2010_TA
Supermodder
Finally the waterblock has arrived.
So you just have to take it apart ... I remove the stock heatsink, remove the dough present, a new paste and new pad and go!
I set also the backplate, which does not pierce it, I stuck with my famous powerful adhesive, placed at the head of the screws that secure the waterblock to the board: the estate is great and the aesthetic result also.
For reasons of space between the backplate and the heat sink on the motherboard, I lit the backplate, since I can not stuffing thick plexi, too bad.
Old 12th Feb 2013, 21:06   #177
Azariel
Multimodder
Azariel's Avatar
Azariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for presidentAzariel should be considered for president
Thats one gorgeous block...almost feels like a crime to hide it behind a shroud (although I also understand why you're doing that of course )
Azariel is offline   Reply With Quote
Old 15th Feb 2013, 19:27   #178
Dave2010_TA
Supermodder
Small package, but useful content.
The last connections to complete both loops: believe it or not, and if you remember the first pictures with a thousand thousand connections, I was able to use all of them, and a thousand thousand.
As I was advised by many, whom I thank, I opted for another method of connection for the passive radiators and their connection to the inside of the pc ... quick release couplings, in order to remove a bulkhead tomorrow that I had the need.
Thanks to all friends!
Old 15th Feb 2013, 21:01   #179
AverageNinja
Almost an EpicNinja
AverageNinja's Avatar
AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.
Looks amazing mate! And that case just swallows all that hardware easily eh? (NOT pun intended).
AverageNinja is offline   Reply With Quote
Old 18th Feb 2013, 00:09   #180
Dave2010_TA
Supermodder
Hello everyone, profitable weekend.
I completed 100% of the liquid cooling system and started sleeving the cables of aquaero and continuing with the cables for the graphics card.
For next weekend point sets all the LED stripe for lighting and finish all the sleeving.
I would say that lack only the painting of houses (orange opaque) and passive radiators (matte black).
See you soon!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
