Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 29th May 2012, 11:18   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Nvidia GeForce GTX 690 4GB overclocked to 1,547MHz
A liquid nitrogen fan has pushed Nvidia's dual-GPU GTX 690 4GB to world-record levels of performance.
http://www.bit-tech.net/news/hardwar...-overclocked/1
brumgrunt is offline   Reply With Quote
Old 29th May 2012, 11:51   #2
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
Those 960's cost like 999 euro a piece and he has two of them and torturing them is very brave. 28.812 is just jaw dropping!
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 29th May 2012, 12:23   #3
enciem
Multimodder
enciem's Avatar
enciem has yet to learn the way of the Dremel
It would be a reasonable cooling solution if you had a butler. Should have tested with the CPU under LN2 as well mind.
enciem is offline   Reply With Quote
Old 29th May 2012, 13:40   #4
Niftyrat
Dremel overpriced like EA games
Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.Niftyrat is the Cheesecake. Relix smiles down upon them.
But what frame rates do you get in games? I.e. arma 2 etc.
Niftyrat is offline   Reply With Quote
Old 29th May 2012, 14:04   #5
dunx
ITX is where it's at !
dunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysisdunx can run Crysis
DDR5 in GHz....
dunx
__________________
Gigabyte Z87x OC-Force - i7-4790k @ 4.3 GHz - 16 GB Crucial Ballistix Tracer Orange/Blue DDR3 @ 1600 MHz - 256 GB Plextor SSD x2 - 6x WD Caviar Black 1TB SATA III HD's - GTX 970 x2- GTX 780 - Titan Black - Coolermaster 1250W PSU - Lian Li PC-D600 - 3x Noctua NF-A14 fans - custom water-cooled - Alphacoool 420mm rads in white - XSPC CPU block and D5 pump - Griffin Powermate x2
dunx is offline   Reply With Quote
Old 29th May 2012, 14:31   #6
Arghnews
Multimodder
Arghnews has yet to learn the way of the Dremel
Lol, if you had a butler...
Arghnews is offline   Reply With Quote
Old 29th May 2012, 15:50   #7
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Wonder what drivers they used, as the newer drivers limit the overclock capabillity of the card and the beta ones don't.
Still a cracking score but I wonder what a single GTX 680 could be taken too
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 29th May 2012, 21:31   #8
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
Zero FPS at 5760 x 1,600, as the 690's launch driver doesn't work at that res in ARMA 2!
Baz is offline   Reply With Quote
Old 30th May 2012, 07:02   #9
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
fill the room with no-longer-liquid nitrogen as the liquid evaporates
The room is already full of gaseous nitrogen! Okay, 78%-ish full. If you ran this setup for a very long time in a very small space, you might want to ensure adequate ventilation to ensure the oxygen content remained sufficient and wasn't displaced by nitrogen, but otherwise the byproduct of this is completely harmless.
__________________
mclean007 is offline   Reply With Quote
Old 30th May 2012, 10:09   #10
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
Define 'very small'!
Gaseous nitrogen in a non ventilated space is EXTREMELY dangerous. It is very slightly lighter than air and will therefore create pockets of gas at ceiling height in a heartbeat. While 'Air' contains a lot of nitrogen it also contains O2 and if this 20% (ish) of O2 is pushed out with nitrogen then...
Sleepy sleepy - not wakey wakey.
You can be knocked unconscious with zero warning symptoms. It's not unheard of for people in labs to be killed like this... and then someone goes to help... and they fall over... and someone else goes to help...
Guinevere is offline   Reply With Quote
Old 30th May 2012, 14:22   #11
mclean007
Officious Bystander
mclean007's Avatar
Yes, I appreciate all of that, which is why I said you'd want to ensure adequate ventilation to ensure your O2 content wasn't displaced by N2, resulting in asphyxia and possibly death.
Obviously locking yourself in a barely ventilated room with a container of boiling LN2 (particularly one whose boil rate was accelerated by being connected to a heat source like a heavily OCed PC...) for an extended period would be a bad idea, but simple precautions would eliminate the risk.
As for "define 'very small'", well I have no idea how much LN2 you need to cool a pair of highly OCed dual GPU graphics cards (and perhaps a CPU too), but the boil rate can't be too outrageous. Bear in mind that the boiling nitrogen is still very significantly below ambient temperature, so it will sink rather than rise, notwithstanding that its molar mass is lower (and so it is less dense at equivalent temperature and pressure than air) - this is why you get the characteristic waterfall of vapour flowing over the edge of a container of boiling nitrogen. It will then mix with the air, so you shouldn't get appreciable pockets at ceiling level. If anything, pockets will form at floor level, so you'd want to watch out for family pets if you had this installed in your house :-)
I'd suggest an oscillating room fan to mix the air with the boiled N2 combined with an extractor to draw in fresh air would be perfectly sufficient.
__________________
Old 30th May 2012, 14:35   #12
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
1.9ghz is the highest a 680 has been took
EVGA forums dude had them at that under ln2
rollo is offline   Reply With Quote
Old 18th Jun 2012, 02:33   #13
ARKAEAN
What's a Dremel?
ARKAEAN has yet to learn the way of the Dremel
I have read all over that no matter the cooling used, there are problems with the VPMs or some major issue on gtx-X90s so that it is essentially impossible to overclock dual-GPU cards much beyond the gtx-X80 base clock. If people are getting over 1.5gHz with LN2 I would think it would be possible to achieve a stable clock around 1250mHz with water cooling..
It is clear that two gtx-X80s are always better than a single gtx-X90, but with liquid cooling I'd hope two gtx-690s would certainly be better than four gtx-680s, especially if the dual-GPU cards had twice the VRAM of a single gtx-680.
I really need to figure this out. I was about ready to buy two EVGA Classified GTX-690 Hydro Copper cards as soon as they drop.
ARKAEAN is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
