Reply
Thread Tools View Mode
Old 2nd Jun 2012, 16:30   #21
Bladesingerz
Supermodder
Bladesingerz's Avatar
Bladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the DremelBladesingerz has yet to learn the way of the Dremel
Ooh, interesting mod you got there man .
What will happen with the radiators? Will they remain visible? Or will they get some sort of fan covers?
Bladesingerz is offline   Reply With Quote
Old 3rd Jun 2012, 00:12   #22
bluc
Supermodder
bluc has yet to learn the way of the Dremel
I dont think I will cover them I like be able to see my hardware they will of cause have the fans on top. Which I am going to mod so I can control the colour of the led in them via the dmx interface.
bluc is online now   Reply With Quote
Old 3rd Jun 2012, 05:37   #23
bluc
Supermodder
I have started working out my water loops. I am new to water cooling and am wondering if it would be OK to use these http://www.gammods.com.au/store/inde...roducts_id=501 and tee them off in lowest point in each loop for drainage plugs. Besides possability of trapped air anything else I need to know about?
Old 3rd Jun 2012, 21:52   #24
bluc
Supermodder
Got the bolts for the rads sorted. Anyone buying the metric bolts don't go by the Swiftech site you need m3 x .5 bolts not m3.5 cheers
__________________
Got the mod bug bad project dmx lighting overkill http://forums.bit-tech.net/showthread.php?t=231790
Old 3rd Jun 2012, 22:49   #25
Bladesingerz
Supermodder
Hold on, this is your first water cooling project?! You start big
Those ports you linked, I've seen them in a couple of projects as fill ports but never as drain ports, but it might work as one, I don't really see why not?
Old 3rd Jun 2012, 23:06   #26
bluc
Supermodder
yes first watercooled pc. I bought the radiators and got cyberdruid from extreme systems forum to build the res for my first scratch build case, which was a mountain mod type cube. But there was some major design issues with tube routing so watercooling never eventuated. This time however watercooling was top priority.
I figured I could put 4 of these fill ports through bottom panel ( one for each loop) and run a tee line to them straight in front of pump making it easy to drain.
All good then I can cross another thing off my to do list
__________________
Old 9th Jun 2012, 11:24   #27
bluc
Supermodder
Can anybody point me in the direction of piggy back 4 pin moles connectors have checked on performance PC's but they don't seem to sell them. Ones like these
__________________
Old 9th Jun 2012, 16:55   #28
Reconnec7ed
Minimodder
Reconnec7ed has yet to learn the way of the Dremel
Originally Posted by bluc View Post
Can anybody point me in the direction of piggy back 4 pin moles connectors have checked on performance PC's but they don't seem to sell them. Ones like these http://forums.bit-tech.net/album.php...ictureid=27484
Watercooling UK
All different colours including UV relative ones too
Reconnec7ed is offline   Reply With Quote
Old 9th Jun 2012, 21:42   #29
bluc
Supermodder
Originally Posted by Reconnec7ed View Post
Watercooling UK
I can see the normal ones but I cant see any of the double/ piggy back ones on that page?
__________________
Old 9th Jun 2012, 22:56   #30
SuicideNeil
I'm insane, not stupid.
SuicideNeil's Avatar
SuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpitSuicideNeil is almost as Godly as yodasarmpit
http://www.ebay.co.uk/itm/4-Pin-Mole...item5ae524ac3e
Not 100% certain that's a pass-through connector though- your next best option is:
http://www.ebay.co.uk/itm/Power-Adap...item4d005af542
and just shorten up the wires & shrink/sleeve them together maybe...
__________________
ASUS P8Z77-M PRO | INTEL CORE i5 2500K @ 4.3GHZ | EVGA GEFORCE GTX 670FTW | CORSAIR VENGENCE DDR3 1600MHZ 2x 4GB | SAMSUNG SPINPOINT F3 1TB | TITAN FENRIR | ACER PREDATOR | WIN 7PRO x64
SuicideNeil is offline   Reply With Quote
Old 9th Jun 2012, 23:27   #31
bluc
Supermodder
I will keep looking but thanks for the help. I want to use them for lighting really need the pass through ones to achieve what I am aiming for cheers.
Edit: pretty sure this them http://www.directron.com/passthru.html
__________________
Old 12th Jun 2012, 09:30   #32
bluc
Supermodder
Wondering if someone smarter than me can explain something to me. The acrylic I am using has a constant temp of 80 degrees Celsius which I am told means it will handle a constant temp of 80 degrees celsius with no deformation. I have also been told the led light strips I am getting run at Max 60degrees Celsius when on full. Now do I need to take into consideration the ambient temp when looking at the acrylic deformation point or not. Trying to work out if I should use heat shielding between the led strip and the acrylic panels. The led strips I am getting use the 5050 smd led .Cheers and thanks in advance
__________________
Old 12th Jun 2012, 11:11   #33
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Not joking about lighting overkill this will be something else for sure, those are some extremely high temperatures for computer lighting.
Hope someone who knows what you want to know sees your question, there will be someone who knows on here, they just need to see your question. I don't know though.
Waynio is offline   Reply With Quote
Old 12th Jun 2012, 11:15   #34
bluc
Supermodder
yea I'm sick of dull lifeless lighting
__________________
Old 13th Jun 2012, 22:21   #35
GamerIDGoesHere
www.^.com
GamerIDGoesHere's Avatar
GamerIDGoesHere has yet to learn the way of the Dremel
Looks great! Can't wait to see the final pictures, nice use of acrylic too .
- Dan
GamerIDGoesHere is offline   Reply With Quote
Old 13th Jun 2012, 22:40   #36
bluc
Supermodder
Thanks will be a slow build as I have limited funds but I will get there eventually
__________________
Old 15th Jun 2012, 07:57   #37
skitzab1
Multimodder
skitzab1's Avatar
skitzab1 has yet to learn the way of the Dremelskitzab1 has yet to learn the way of the Dremelskitzab1 has yet to learn the way of the Dremel
same prodblem at the mment with moving but looks great so fare
skitzab1 is offline   Reply With Quote
Old 15th Jun 2012, 10:35   #38
bluc
Supermodder
Thanks I just about have the wiring harnesses worked out just waiting on cash to buy the lights wire and crimp tool /plugs and other stuff I need. What is the done thing with moles pins crimp or solder? Wish I had the cash to design a case buy everything I need and build non stop start to finish that would be great.
__________________
Old 18th Jul 2012, 01:32   #39
bluc
Supermodder
Ok Finally been able to do a Bit more on my case. I made the reservoir mount . I printed my drawing on a4 printer 1:1 scale stuck it, cut around it with a jigsaw then finished it on a disc sander.
This is the first time I have made anything from acrylic and first time I have used solvent capillary welding… I think it shows I had two overruns with the glue I will get stuck into it with the buffer and polish when it is fully cured . The two edges with the defects are hidden anyway so not too worried. Over all fairly happy with my effort . Tomorrow I will be placing an order for my led strips and some other stuff. Hopefully it won’t be too long till I have more updates cheers
__________________
Old 19th Jul 2012, 19:51   #40
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.mnpctech is the Cheesecake. Relix smiles down upon them.
This is a KILLER idea! love the res too
mnpctech is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
