Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 31st May 2012, 09:16   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Dell launches ARM-based server range
Dell has launched Copper, a range of ARM-based many-core servers.
http://www.bit-tech.net/news/hardwar...-arm-servers/1
brumgrunt is offline   Reply With Quote
Old 31st May 2012, 14:05   #2
Byron C
This space for rent.
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
ARM for all!
I've always been a bit of a fan of RISC architecture; it always seemed to make more efficient use of clock cycles compared to x86. ARM-powered servers will be a godsend for power consumption and heat, not to mention space. One of these 48-core machines could easily be virtualised into multiple different virtual servers. I realise that you can do that with x86 machines, but the ARM version would use much less power. The article doesn't state how fast each core is, but I know the Cortex A15 can be pretty speedy. Allocate 4 cores per virtual server and - in theory - you've suddenly got one system providing 12 servers.
Any word on what the clock speed of the individual cores are, or what sort of cooling they need? It would be a pretty incredible prospect if they can survive high-load situations with passive cooling.
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 31st May 2012, 14:17   #3
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
1.6GHz - they're Armada XP 78460 quad-core chips.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 31st May 2012, 14:24   #4
Byron C
Byron C's Avatar
Wait...what? Quad-core chips? So one of these machines fully-packed with 48 SoCs has 192 processing cores available?
The mind boggles.
Again, yes I know you can do that with an x86 server, but I doubt that would fit in 3U. Plus an x86 server with 48 processors would eat gigawatts of power before it's even spent two minutes booting.
__________________
Old 31st May 2012, 14:39   #5
Byron C
Byron C's Avatar
Just found some more info on The Register when googling that chip. Apparently each sled, or server node, consumes 15W under peak load; it doesn't state whether that includes the hard disk power consumption, but assuming it does that equates to a total of 180W draw across 12 sleds at peak load. That's less than a PC from 5 years ago - hell, even 10 years ago. Not to put too fine a point on it, but...F*** ME!
__________________
Old 1st Jun 2012, 10:43   #6
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
processors based on ARM's Cortex-A15 'Eagle' IP in a 64-bit implementation
This is completely wrong. They're Marvell ARMADA-XP, not Cortex-A15. And they're ARMv7 so definitely not 64-bit either.
ch424 is offline   Reply With Quote
Old 1st Jun 2012, 10:48   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
My mistake: they have a 64-bit memory bus, but a 32-bit local bus - I just saw "64-bit." I'll correct the piece. The Cortex-A15 confusion came from Dell's less-than-clear press release in which it singularly failed to actually mention what chip it was using - you'd think if it really wanted to be seen as leading in a brave new market, it'd make a bit more information available at launch...
__________________
Old 1st Jun 2012, 11:02   #8
Byron C
Byron C's Avatar
Regardless of the specific chip being used, it's still a pretty damn tasty prospect.
__________________
Old 1st Jun 2012, 11:51   #9
ch424
Design Warrior
ch424's Avatar
Yeah, looks awesome! As you said, 192 cores in 3U!
Gareth, the Armada XP is the chip - Armada XP is a core, just like each of the Cortex series and the Scorpion/Krait CPUs in Qualcomm products. Good job on the fix - it's great that bit-tech does corrections, loads of websites are happy to fire and forget with news articles!
Old 1st Jun 2012, 12:48   #10
Gareth Halfacree
WIIGII!
bit-tech Staff
I realise that - but Dell's original launch announcement completely fails to name the chip or even the manufacturer - it just says ARM with no other details. I found out it was an Armada chip from Marvell itself and posted the update in the comments - but forgot I'd written Cortex-A15 in the article!
I'm always happy to update pieces if there's a mistake or new information - it does nobody any good to have misleading our outdated information published. That's the trouble with the web - everything lives forever..
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
