Reply
Thread Tools View Mode
Old 31st May 2012, 11:31   #1
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Case Mod Project: "M A Y H E M" ....."Arrived Safe & Sound"
Posted Video of our "DiRT Showdown" Gaming PC Case Mod for AMD, revving up the FX-8150!
I love building theme based case mods! and I'm having a blast with "MAYHEM" aka "Dirt Showdown PC" which is inspired by Codemasters’ new DIRT spin-off racing game for AMD Giveaway on facebook. You can enter the giveaway here
I'll be modifying Fractal-Design's Artic White" Define R3 mid tower. This is my 4th time modding a Fractal-Design case. I really like the overall craftsmanship of their cases and their prices are easy on the wallet.
Fractal Design Define R3 White case, Only $99 at Newegg
Features:
Improved model over Fractal Design Define R3
Stunning front panel design
Patent pending ModuVent™ design - removable vents!
Pre-fitted with dense, noise absorbing material
Motherboard tray cut-out, allows easy access to rear of motherboard
Eight HDD-trays, with silicone mounting
Can accommodate up to seven 120/140mm fans, two supplied
PCI fan controller for 3 fans included
Easily removable front fan filters with clip-on holders for 120mm fans
Specifications:
Dimensions 207.40 x 440 x 521.2mm (WxHxD)
Weight 12.5 Kg
Motherboard Compatibility Mini ITX, Micro ATX and ATX
Power Supply Compatibility Standard ATX, can accommodate long PSUs
PCI/AGP Card Compatibility Full size (up to 290 mm long)
3.5" Drive Bays 8, all SSD compatible
5.25" Drive Bays 2, one bay converts to 3.5" for floppy or card reader
Roof Cooling Fans Space for two 120mm, none supplied
Rear/Side Cooling Fans Rear - space for one 120mm fan, supplied; Side - space for 140 or 120mm fan not supplied
Front/Floor Cooling Fans Front - space for two 120mm fans (both with filters), one supplied; Floor - space for one 120mm fan (with filter), not supplied
Expansion Card Slots 7, with sleek white painted brackets
Front I/O Ports 2x USB 2.0, 1x eSATA and Audio I/O
Accessories PCI fan controller, controllers up to 3 fans
Warranty 24 months
The "Dirt Showdown" PC will be powered by an AMD 8-core FX-8150 3.6GHz processor
It will be cooled with AMD's new Liquid CPU Cooler. Sapphire Radeon HD 7950 and Pure Black 990FX motherboard. 16GB of AMD "Performance Edition" Memory DDR3
First step I made was modifying the front door of the DefineR3 for an intake grill that looks very aggressive like the modified Derby cars. I used a Dremel cutting wheel to cut rectangular opening in bezel door.
Expanded Steel for the front grill was bent in bench vise.
Let's test fit the grill before making final adjustments.
The front grill fits perfectly. It will be epoxied onto the back side of the door, once the door is repainted.
I love the night driving stages of the game, which gave me idea of implementing mini halogen projector lights, that will reside behind the front grill.
1.5W Pair High Power LED "Eagle Eye" White Lamps. Power: 1.5W X 2, 110LM, 8000-10000K are available on Ebay in the states here
I fabricated mounting plates for the Mini Projectors located onto the edge of the Define R3 front bezel.
Mini Projectors behind the Expanded metal front grill.
120mm Turbine Fans with machined aluminum "Overkill" 120mm Fan Grill Rings
The 120mm Turbine fans measure 120mm x 25mm. The Evercool fan frame is machined aluminum that has been polished. The plastic fan blades are electroplated chrome. The fan is rated at 2000 rpm with 79.4 cfm and 30 dBA.
To emulate the look of an engine inside the PC. Each side panel will utilize K&N single carburetor covers. A 92mm cooling fan will reside in each cover. The dense filter inserts will be removed from each cover and replaced with Round Modders Mesh for maximum airflow.
The K&N filters will utilize Round Modders Mesh
Using Tin Snip to cut the Round Modders Mesh for each of the K&N air intake covers.
The K&N filter covers were modified for 92mm intake cooling fans.
[img]img src="http://www.mnpctech.3dpixelnet.com/picture_library/amd_codemasters_dirt_showdown_gaming_pc_case_mod_a md_cooler_FX_radeon_fractal_design_92mm_scoop2.jpg[/img]
Drawing out the window design on the Define R3 side panel.
Customized Define R3 side panel with K&N intake.
All of the chassis modifications are made before sending it to paint booth for "House of Kolor" brand Tangelo Metal Flake Orange paint.
Custom pcb made by Twizted for "Tachdunio" HDD activity meter that will be mounted on top of the PC.
for the top, I'm installing Mnpctech machined aluminum and Black anodized 2x140mm (280) from frozencpu
I used a Dremel and Jigsaw to remove the factory grill perforations for improving airflow.
Using Measuring Square to center the location of the 280mm fan/radiator grill, then trace the hole locations with a pen.
I drilled the grill mounting holes before cutting outline for fan holes.
Using Dremel with reinforced cutting wheel to make initial cut before using the Jigsaw.
Using Jigsaw with 18 TPI bi-metal cutting blade.
The perforated factory fan ventilation holes were removed to improve airflow and allow for 280 cooling fan / radiator grill.
The Toggle switch for the carry handle has a Red LED for Power On. This will be used for the mini Halogen lights.
Wiring diagram for Fighter Pilot Toggle Switch with LED. You can use this switch to power on any accessory in your PC like cooling fans or lights.
Toggle switch is installed and tested.
Top carry handle...
The top carry handle was fabricated and welded from 1/2" square Steel tubing.
The HD activity tachometer will be located in front of the top carry handle. The next stages include velocity stack style fan grills, installing the Tachometer, custom paint, airbrushing, and more hot rod stuff
Update: 6/2/12
Here is both single and dual velocity stack fans finished. These will be mounted vertically behind the front intakes.
Update: 6/11/12
Next step is Hot Roddin the Tachometer gauge face with fire, with Brad Galvin behind the IWATA airbrush....
The sponsors graphics are created with a vinyl overlay, which is made with vinyl film plotter, the overlay is placed over the panel, so the open portion overlay is painted with Black enamel paint.
The Showdown graphic was done the same way, but in 3 different steps for Black, White and Yellow paint.
Graphics are finished... next step is using a small detail paint brush to add dirt specs around the graphics, and paint scuffs to the side panel.
Small detail paint brush with Black enamel paint...
The specs flow toward rear edge of the case to stimulate motion..
AMD logo was painted in top center of the bezel door to emulate a car emblem.
next step is clear coating the graphic, which requires clearing the entire panel.
Using large paint brush to create scuffed paint effect.. "Rubbin's Racin" :cool:
Finished wiring mini headlight projector lights, and assembled the front bezel and door with "bruiser derby" front grill.
Started the system install last night and finish everything today for photos at 8pm, I'll be editing video of the project Saturday, so I can have it posted for AMD on YouTube on Monday. The "Dirt Showdown" PC will be powered by an AMD 8-core FX-8150 3.6GHz processor. It will be cooled with AMD's new Liquid CPU Cooler. Sapphire Radeon HD 7950 and Pure Black 990FX motherboard. 16GB of AMD "Performance Edition" Memory DDR3
mnpctech is offline   Reply With Quote
Old 31st May 2012, 11:37   #2
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
OH GOD , Looks amazing love the K&N Airfilter and the top Well done cant wait to see the finish mate !
SilveR_172 is offline   Reply With Quote
Old 31st May 2012, 12:34   #3
Balder
Calmer than a monk on morphine
Balder's Avatar
Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.Balder is a hoopy frood who really knows where their towel is.
Damn it Bill, this looks like awesomness in the making, your mods are always amazing
__________________
All progress is precarious, and the solution of one problem brings us face to face with another problem.
- Martin Luther King, Jr.
Balder is offline   Reply With Quote
Old 31st May 2012, 12:35   #4
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
This is awesome. I'm VERY excited to see the final result.
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is online now   Reply With Quote
Old 31st May 2012, 12:45   #5
Shurika
Multimodder
Shurika's Avatar
Shurika has yet to learn the way of the DremelShurika has yet to learn the way of the Dremel
Amazing start!!! Look forward for new updates. Bill, you`re one of the best modders on bit-tech
__________________
sorry for my English
Shurika is offline   Reply With Quote
Old 31st May 2012, 13:19   #6
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.Angel OD is a hoopy frood who really knows where their towel is.
I really want to hate this mod, but I just can't... That tach is made of WIN!
I'll keep my wrath directed towards AMD who decided to not include Denmark to countrys who can enter the sweepstakes...
Edit - make an extra Tach, I can put it on the dashboard and link it to my carpc!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 31st May 2012, 14:12   #7
E.E.L. Ambiense
Acrylic Heretic
E.E.L. Ambiense's Avatar
E.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run CrysisE.E.L. Ambiense can run Crysis
Originally Posted by Shurika View Post
Amazing start!!! Look forward for new updates. Bill, you`re one of the best modders in the world
Fixed!
Oh yeaaaaaah!
__________________
Latest Builds:
LilyPC - in progressBIO-A10 - MotM Jul. '12 Nominee Loser!"Movie Sign!" - in progressCheckMate - MotM May '09 Nominee Loser!BluBawx I - MotY '09 Nominee Loser!Lumière Noire - MotM Apr. '08 Nominee Loser!NOTalis w/ MNPCTech"Building Better Worlds" - MotM Feb. '08 Nominee Loser!
E.E.L. Ambiense is offline   Reply With Quote
Old 31st May 2012, 15:46   #8
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
@EEL - Git outta here and post the start of that log you've been sitting on the parts for.
-So if this one goes well, will they up the budget for later mods?
Cheapskate is offline   Reply With Quote
Old 31st May 2012, 16:09   #9
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Woooo hoooooo I'm quite excited about this one Bill the fans look awesome, that hdd activity gauge, just perfect for a motor theme mod, going to enjoy watching you do a theme you like a lot.
Side panel switchable awesome extra air in take also, nice load of progress held back to make an excellent first post for the thread, I'll follow such an example from now.
Waynio is offline   Reply With Quote
Old 31st May 2012, 17:12   #10
Kylevdm
The Mod Zoo Podcast Host
Kylevdm's Avatar
Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.Kylevdm is a hoopy frood who really knows where their towel is.
This mod is going to be insane! Was excited about it a while ago!
__________________
Kyle van der Merwe host at www.TheModZoo.com Podcasts!
Project: Codename C :: LANBOY APOCALYPSE (built with MNPCTECH!) :: Project: Deadline :: Project: MNU
Projects supported by EK Waterblocks, MNPCTECH, Fractal Design, NZXT, ENERMAX, and TM3 Connections
Core i7 920 D0 :: Asus P6T Deluxe v2 :: 6GB Crucial BalistiX :: Asus GTX 570 :: ENERMAX Platimax 850W :: OCZ Agility 3 120GB :: 4x Samsung SpinPoint F3 1TB
Kylevdm is offline   Reply With Quote
Old 31st May 2012, 18:57   #11
Scirocco
Boobs, I have them, you lose.
Scirocco's Avatar
Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!
Woot! Car themes and pc modding -- always a great combo. And we know Bill will do it right!
__________________
"If she were any more of a bitch, she'd have puppies!" Victoria Chase, Hot in Cleveland.
Current project: La Fée Verte
Scirocco is offline   Reply With Quote
Old 31st May 2012, 20:35   #12
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Good job Bill,looks great allready.
Pranja is offline   Reply With Quote
Old 31st May 2012, 20:51   #13
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is.
An astounding mod, especially the smaller details being put in place, like the filter-covers on the side.
I do find myself wishing I could haul my ass over to the states and get that chip happily stable at 4.8ghz for you. Under that cooler; it should be perfectly happy there. Either way; I'm eager to see how it turns out once you've started to pack hardware in there.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM
Dell 1908 | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9
.//TuNdRa is offline   Reply With Quote
Old 1st Jun 2012, 01:25   #14
E.E.L. Ambiense
Acrylic Heretic
@ Cheaps: I can pway too! *kicks rocks like a kid*
That's not the 1st time either. Bill's been using that trick for years. Check out some of his past projects a few years back... Some killer stuff, man. And it's not like you're reading the JC Penney clothes catalog either; it's bloody entertaining and fascinating!
__________________
Latest Builds:
Old 1st Jun 2012, 13:29   #15
mnpctech
bit-tech sponsor
mnpctech's Avatar
@SilveR_172, Thank you! I forgot to mention, the K&N Air Filter is for Single or Two Barrel Carburetors, Part #56-9169
@Balder, Thank you for the post! I'm having lots of fun with this project
@Parge, Thanks! me too! It's been fun just sourcing the parts off Ebay.
@Angel_OD, Thats awesome! I've told Vern about this thread too
@Shurika, Thank you. I'm inspired by the Modders in this forum everyday
@Cheapskate, Yes. The next project, if accepted will be Killer...literally I think E.E.L is waiting to see Prometheus first
@Waynio, Thank you dude, but your logs set a good example for all of us
@Kylevdm, I can only get work done during Dixie's naps (shes my 9wk old beagle)
@Scirocco, luv it, and haven't forgotten about your project
@Pranja, Thank you for tuning in!
@.//TuNdRa, that would be cool! I'm looking forward to playing on this PC.
@EEL! haha! I bought my first Home Stereo from that catalog, Realistic.. I was a kid!!
Some people offlist asked if I will knick 'n scuff up stuff, to fit the theme appropriately. Yes, of course, that is the funnest part. Watching the Dirt Showdown trailers have spawned a lot of Hot Rod inspired aesthetics for this PC. I love seeing Velocity stacks used on carburetors. A Velocity stack is a trumpet-shaped device of differing lengths which is fitted to the air entry of an engine’s intake system, carburetor or fuel injection. I'm creating fan grills to emulate Velocity stacks.
I'm using Rheobus knobs to emulate the fuel line connectors.
I'm creating fuel connector mount from the corner of a 120mm fan. I used a jigsaw with 18 TPI bi-metal blade.
Faux fuel line connector base. The Rheobus knobs were bored out for 1/4" wire loom tubing.
Billet machined 120mm fan grill frame
The inserts are 120mm Black acrylic honeycomb fan grill.
inserting 1/4" wire loom tubing in Velocity stacks
There will be two velocity stack grills mounted on the back of front turbine intake fans
Brad and I concocted a custom paint mix cfor the Dirt PC. We've named it "Dirt Showdown Orange" It's a combination "House of Kolor" Kandy Orange with touch of Red over "House of Kolor" "Shimrin Metajuls" Gold Basecoat.
Update: 6/5/12
Thank you for the posts guys!
Drawing inspiration from K&N race series street rod... except these will be mounted like "pipe stacks" on the rear of chassis..
I've modified pipe from bathroom sink trap I found in Plumbing section at Home depot...
made manifold mount from Blue transparent acrylic, I was lucky to get handful of these red anodized 6/32 machine screws from Twizted old online store, Dragonmodz.. which is now closed.., but You can get anodized machine screws from Parts-Express, http://www.fastener-express.com/
Update: 6/07/12
I installed our polished Machined aluminum "Diamond Knurl" pc case feet which are made in HAAS cnc lathe.
The base diameter is 1- 3/4" with height of 1" to elevate the case for improved airflow beneath it.
Velocity style cooling fans installed.
Signal lights aimed on the cooling fans.
The Tachometer shell is ready for circuit board...
Old 1st Jun 2012, 13:46   #16
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
that mod just cries for chromed exhaust pipes and key to turn on
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is online now   Reply With Quote
Old 1st Jun 2012, 13:54   #17
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Squigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the Dremel
Oh hell yea!!! a key power button.. or like a start button.... nah, KEY!!!!!!!
Squigly is offline   Reply With Quote
Old 1st Jun 2012, 14:25   #18
Twizted
What's a Dremel?
Twizted has yet to learn the way of the Dremel
Looking great Bill!
LOL @ "What's a Demel?" for status
Twizted is offline   Reply With Quote
Old 1st Jun 2012, 15:02   #19
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Now that's just badass...
Mankz is offline   Reply With Quote
Old 1st Jun 2012, 15:37   #20
dbradford32
Multimodder
dbradford32 has yet to learn the way of the Dremel
HOLY CRAP BILL! AMAZING! I want one of those Tachs... Tell Vernon to hook me up! I love it! I almost had a tear in my eye! lol I am also building a car style PC. That tach would look great with my BMW theme! lol
__________________
Yesterday is history, Tomorrow a mystery, today is a gift, which is why it is the "present".
dbradford32 is offline   Reply With Quote
Reply
Tags
cpu tach, fractal design case mod, hok metajuls paint
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
