Reply
Thread Tools View Mode
Old 29th Jul 2012, 05:10   #181
The_Beast
I like wood ಠ_ಠ
The_Beast's Avatar
The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!The_Beast - it's over 9000!!!!!!!!1!1!1!!!
Wow, that case looks absolutely amazing
__________________
- i7 3770k - MSI Z77A-GD65 - EVGA GTX 570 - 8Gb G.Skill Sniper (1.25v) - Fractal R3 Black - Corsair H50 - Corsair 750HX - Samsung 830 128Gb SSD - 6 Samsung F4EG 2TB - 2 WD Black 1TB - 2 WD Black 750GB - Dell UltraSharp U2410 - WASD V1 Custom - IBM Model M SSK - KBC Poker (Ergo-Clears) - Logitech Mx518 & G500 - Audio Technica AD700 - Logitech Z4 - Windows 7 Pro -
The_Beast is offline   Reply With Quote
Old 29th Dec 2012, 12:17   #182
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Mosquito, Roboduck and I will be playing Dirt Showdown online, Saturday, January 26th, at 8pm Central, during the 1st Minnesota Modder's Monthly Meetup ....So if anyone else is from Twin Cities, you're welcome to check it out!
@Waynio, Many thanks for your awesome enthusiasm and support! fyi: for shipping systems, acoustic foam or packing paper works best! I avoid any towels or linens, to prevent static...
@The_Beast, Thank you very much!
mnpctech is offline   Reply With Quote
Old 29th Dec 2012, 13:34   #183
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
Just watched the video for the build and wow, that really does the case more justice than the pictures! brilliant job Bill!
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 12th Jan 2013, 15:59   #184
mnpctech
bit-tech sponsor
mnpctech's Avatar
Thank you Nate! Looking back, I really loved that Orange paint, would love to use it again.
Reply
Tags
cpu tach, fractal design case mod, hok metajuls paint
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
