News E3: Nintendo reveals Wii U controllers
Discussion in 'Article Discussion' started by CardJoe, 4 Jun 2012.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    The link to the 'unusual developers' points to a pasword-protected part of the website...
    Fix it, I'm curious!
  3. Tangster
    23 May 2009
    All the links do!
  4. CardJoe
    3 Apr 2007
    Nothing to see here...
    (Fixed)
  5. Horizon
    Horizon Dremel Worthy
    30 May 2008
    well that solves that mystery, if the ps3 and 360 controller had an illegitimate child.
  6. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    Looks like they are officially bringing back the start and select buttons. They still have + and - symbols though.
    They should have just done the full rip-off though and put the right analog stick where the face buttons are and vice/versa. So used to using the 360 and PS3 setup where the buttons are above the analog stick.
  7. GoodBytes
    20 Jan 2007
    They also updated the WiiU controller:
    -> 2 analogue sticks, instead of the thumbsticks
    -> Clickable analogue sticks
    -> Better location of buttons
    -> It LOOKS LIKE (from the video) that they implement a capacitive touch screen, instead of the "press to do contact" type of screen.. but not too sure about it.
    -> Added a NFC reader
    -> Can be used as your TV remote.
  8. Eiffie
    Eiffie What's a Dremel?
    11 Oct 2010
    I for one really can't stand the Bumper + Trigger buttons up top. I wish they just had two buttons and no Triggers at all. No, I'm sorry, I don't get the feeling of firing a gun when I pull them. As for people who want to be able to adjust things with pressure, I liked how the old Gamecube controllers had two clicks to the shoulder buttons. You knew exactly when you were gonna have to press harder to break into the second click of the button. Those things also were built like WW2 Panzer tanks.
  9. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Somewhat strange design they've gone with. Moving both joysticks to be above their respective button cluster is an odd move, I have to wonder if they did it just to be different. Whatever the reason, I'm very wary of it. It's going against a lot of gaming instinct to move your right thumb down to press buttons rathern than up.
    And the worst part is that many games use the bumper anyway, even to shoot. R1's history as "Fire" is just too lengthy.
    The one thing I've found triggers to be really good for is driving games for gas and brakes since it's easy to get different inputs than with a button, but fans will often buy wheels and pedals anyway so it's not really a good reason to change the whole controller.
  10. GoodBytes
    20 Jan 2007
    The layout of this controller, is the same as the Wii U tablet one.
    Reporters said it was easy to use, and comfortable.
  11. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    An eye for an eye I guess, MS basically ripped off some of the functionality of the GamePad so they rip off the 360 design. Oh well.
Tags: Add Tags
