Reply
Thread Tools View Mode
Old 5th Jun 2012, 05:51   #1
nhenhophach
Bit-tech
nhenhophach's Avatar
nhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysis
ROG Max V,MOTY Nominee .
Max V
The case with name from ASUS MAXIMUS V Formula motherboard, it l will exhibit at ASUS booth
i started this project 2 month ago, but i can post worklogs now.
Sponsor:
I got Hardware from Sponsor
Time too short so i can't design with Sketchup, i do with Acrylic first then change to Aluminium some parts.
Laser cut Base and TOp of case.
Shaped aluminum
TAP.
Assembly into the base
Acrylic tube OD/30mm
nhenhophach is offline   Reply With Quote
Old 5th Jun 2012, 06:09   #2
nhenhophach
Bit-tech
Make main tray.
I want put Thunder FX to case too, so i need space.
Old 5th Jun 2012, 06:20   #3
nhenhophach
Bit-tech
My idea is use two Acrylic tube become reservoir so i have many of work to do.
Lathe solid Acrylic.
Prepare material,
Old 5th Jun 2012, 08:47   #4
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!!
Looking great so far!
__________________
ZiiP Gamestore
[ZiiP] Gaming Community - IW BlackMailers and loonies abound!
Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350.
[ZiiP] NaloaC is offline   Reply With Quote
Old 5th Jun 2012, 10:09   #5
RedManc
Supermodder
RedManc's Avatar
RedManc has yet to learn the way of the DremelRedManc has yet to learn the way of the Dremel
I like this style of case, this one is looking great so far
__________________
RedManc is offline   Reply With Quote
Old 5th Jun 2012, 11:19   #6
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
Looking good, how did u mount the videocard?
Meelobee is offline   Reply With Quote
Old 5th Jun 2012, 11:30   #7
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.Bindibadgi is the Cheesecake. Relix smiles down upon them.
I'd like to also say that Ban not only made this, but the flight case for it too. All in about 6 weeks! It's on the ASUS booth in Computex both 100% working and 100% perfect. The man is not a modder, he's a miracle worker. You have our utmost thanks!!
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 5th Jun 2012, 17:15   #8
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Awesome!
Cheapskate is offline   Reply With Quote
Old 6th Jun 2012, 01:47   #9
nhenhophach
Bit-tech
I use two reservoir keep two doors too. So i add some ball bearings
Acrylic pices will hold Therdex FX and look better.
Old 6th Jun 2012, 01:51   #10
nhenhophach
Bit-tech
Receive goods from BITSPOWER.
Carbon Black.
Đây là số Fitting sẽ được dùng cho case, phần trong bọc để dành.
Continue work
Old 6th Jun 2012, 01:53   #11
nhenhophach
Bit-tech
I change some parts from Acrylic to Aluminium.
Nhôm 5mm.
CNC
Motherboard TRAY
Old 6th Jun 2012, 06:16   #12
Djayness
ASUS
Djayness's Avatar
Djayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the Dremel
Excellent work. Not to ruin the end of the mod but there's some flashes of it at 44 and 55 seconds in this video.
Djayness is offline   Reply With Quote
Old 6th Jun 2012, 12:22   #13
KryptiK
Minimodder
KryptiK has yet to learn the way of the DremelKryptiK has yet to learn the way of the Dremel
amazing! subbed
KryptiK is offline   Reply With Quote
Old 6th Jun 2012, 16:14   #14
amagriva
Multimodder
amagriva's Avatar
amagriva has yet to learn the way of the Dremel
to give us un unwanted asus commercial you did spoiled the log...
amagriva is offline   Reply With Quote
Old 7th Jun 2012, 00:35   #15
Djayness
ASUS
Djayness's Avatar
You do realise that;
1. ASUS ROG sponsored the build.
2. The mod is on show at Computex 2012
3. The video linked shows you the mod and my word, it's absolutely brilliant.
Old 7th Jun 2012, 02:44   #16
nhenhophach
Bit-tech
Old 7th Jun 2012, 10:55   #17
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Thats an epic mod!!!!!!!!!!!!
AnG3L is offline   Reply With Quote
Old 7th Jun 2012, 16:38   #18
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
Ban, you're my hero!
__________________
Preparing: Raz3r D3sk
Running : L3p Parvum
Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 8th Jun 2012, 01:54   #19
nhenhophach
Bit-tech
Making TOp of case
Interconnected Plate
Old 8th Jun 2012, 01:56   #20
nhenhophach
Bit-tech
Make two doors
I used plenty of Acrylic pieces
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
