Reply
Thread Tools View Mode
Old 8th Jun 2012, 02:52   #21
Asouter
Tremendously Difficult Lifestyle
Asouter's Avatar
Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.
Absolutely Stunning, I am quite biased to use of layers in builds though. Awesome
__________________
Finished Project : D33P THOUGHT
Finished Project : THING
Current Project : Mini Moto Mayhem
Asouter is offline   Reply With Quote
Old 8th Jun 2012, 08:51   #22
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!![ZiiP] NaloaC - it's over 9000!!!!!!!!1!1!1!!!
As with your previous builds, it just screams "Cybran" at me, love it!
__________________
ZiiP Gamestore
[ZiiP] Gaming Community - IW BlackMailers and loonies abound!
Sui Generis: i7 920, Corsair H50, 6GB Dominator C7 1600, EVGA x58 SLI LE, Corsair F3 120GB SSD, Samsung F3, Sapphire 5870 Vapor-X, Corsair HX850W, Corsair Obsidian 800D, Iiyama 26" Prolite, Logitech G15, Logitech G5, Sennheiser PC350.
[ZiiP] NaloaC is offline   Reply With Quote
Old 8th Jun 2012, 12:01   #23
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
Those side ally parts look great, it would be fantastic if you could use them as a passive cooler of some kind to
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 12th Jun 2012, 11:04   #24
nhenhophach
Bit-tech
nhenhophach's Avatar
nhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysisnhenhophach can run Crysis
Painting and start assembly.
nhenhophach is offline   Reply With Quote
Old 12th Jun 2012, 17:00   #25
_ferry_
Supermodder
_ferry_'s Avatar
_ferry_ has yet to learn the way of the Dremel
Your finger is just 3cm away from a painfull cutoff. But anyway, cool project! I was just wondering how the paint will hold on those sharp acrylic edges without a clear coat. Doesn't look very scratch resistant?
_ferry_ is offline   Reply With Quote
Old 12th Jun 2012, 17:43   #26
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.
@Ferry - If he used an etching paint, it should hold up. It attacks the plastic and fuses to it.
Cheapskate is offline   Reply With Quote
Old 12th Jun 2012, 17:57   #27
_ferry_
Supermodder
_ferry_'s Avatar
Okay, sounds like i need some it 's matte look makes it look like it's anodized alu
Old 14th Jun 2012, 13:12   #28
coolamasta
Folding@Home CC Captain 2010/11/12
coolamasta's Avatar
coolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for presidentcoolamasta should be considered for president
QUALITY loving that
__________________
My Main Rigs:~ H2O'd i7 3770K @ 4.5 - 16GB - H2O'd GTX 670 | Asus Z9PE-W8, EP-Xeon 2670 @ 3.2 - 16GB
| ~~~ My Current Dual EP-Xeon 2670 Project ~~~ | ~~~ My Mitsubishi Evo Track Car Project ~~~ |
coolamasta is offline   Reply With Quote
Old 16th Jun 2012, 02:41   #29
nhenhophach
Bit-tech
Made two adapter for Maximus block.
Custom screw for VGA TRAY
Using PCI-E Plex.
Set up and test
Chạy thử.
Old 16th Jun 2012, 08:17   #30
sorry2
What's a Dremel?
sorry2's Avatar
sorry2 has yet to learn the way of the Dremel
Whow...... just awesome
sorry2 is offline   Reply With Quote
Old 16th Jun 2012, 11:04   #31
dietje1908
Minimodder
dietje1908 has yet to learn the way of the Dremel
Amazing !!!
dietje1908 is offline   Reply With Quote
Old 16th Jun 2012, 11:40   #32
nhenhophach
Bit-tech
Interconnected Plate for Two reservoir use one pump.
Old 16th Jun 2012, 12:02   #33
cookie! nom nom
Supermodder
cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!cookie! nom nom - it's over 9000!!!!!!!!1!1!1!!!
this is nuts :O never seen anything like this....
cookie! nom nom is offline   Reply With Quote
Old 16th Jun 2012, 16:20   #34
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
i bothered that project already finished and showed... and we watching small pieces of work instead of of full WL
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 21st Jun 2012, 02:38   #35
nhenhophach
Bit-tech
Mod 45* Rotary fitting become female to female adaptor.
Final setup
PSU
Old 21st Jun 2012, 02:40   #36
nhenhophach
Bit-tech
ROG logo
SSD
DP Ultra
Old 21st Jun 2012, 02:43   #37
nhenhophach
Bit-tech
Final.
Because time to final case too sort, so i can't take all pcis. And some work can't perfect 100%. I am going make two Reservoir glow too.
Some pics at COMPUTEX ROG Booth.
Old 21st Jun 2012, 04:51   #38
Djayness
ASUS
Djayness's Avatar
Djayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the DremelDjayness has yet to learn the way of the Dremel
MOTY? That is...unbelievable.
Djayness is offline   Reply With Quote
Old 21st Jun 2012, 05:14   #39
l3p
www.^.nl
l3p's Avatar
l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.l3p is a hoopy frood who really knows where their towel is.
No doubt
__________________
Preparing: Raz3r D3sk
Finished : L3p Parvum - Cross - L3p AlCu - L3p L4n - L3p D3sk
Sites: www.l3p.nl - www.redharbinger.com
l3p is offline   Reply With Quote
Old 21st Jun 2012, 05:46   #40
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
Another epic mod by nhenhophach, dude you gotta stop now, you're making all us other modders look bad
Meelobee is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
