Reply
Thread Tools View Mode
Old 21st Oct 2012, 09:56   #321
PabloFunky
Ultramodder
PabloFunky's Avatar
PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.PabloFunky is definitely a rep cheat.
I was always told, never put things where they dont belong, but this rad placement is an exception i think.
PabloFunky is offline   Reply With Quote
Old 21st Oct 2012, 21:44   #322
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
Thanks Pete, I tried to get it in the case and is just wasn't going to happen so it went under it. Keeps it all nice and discrete as well.
bulldogjeff is offline   Reply With Quote
Old 26th Oct 2012, 23:43   #323
bulldogjeff
I've just been adding up the cost of this build and so far based on donations and stuff I had laying about gathering dust I am running at about 120, and one things for sure it will finish at under 150.. Modding on the cheap.. haha, love it
I won't be so lucky on the next one thats for sure lol
Old 26th Oct 2012, 23:59   #324
Teelzebub
Up yours GOD,Whats best served cold
Teelzebub's Avatar
Teelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming Saiyan
So we going to get some more updates this weekend then?
__________________
bt was once a great and vibrant forum wtf happened to it? , there must be a Hex on us back to mediocrity Get back under your bridges you scummy Troll's and STFU Mountain mods case, Enermax 1250w PSU, Asus Maximus V Extreme, i7 3770k @ 14.6ghz, Samsung 840 250gb SSD. 500gb Seagate,Corsair H80i wind tunnel, 16gb Corsair Vengeance pro 1866mhz,4xEVGA GTX 670 quad SLI 2 x Dell U27" @ 2560 x 1440, 4 bags of weed
Teelzebub is offline   Reply With Quote
Old 28th Oct 2012, 19:35   #325
bulldogjeff
Not going to make any progress this week end, but I'll be putting the hardware in dure the week so expect a few updates. Maybe even be complete by the end of the week.
Old 30th Oct 2012, 20:28   #326
bulldogjeff
The last few bits have just arrived today.. Now I can put it all together ...Wooooohooooo
Old 4th Nov 2012, 17:44   #327
bulldogjeff
Just about to put it all together and I can't find any fittings
Got loads of 1/2 compresions, no 3/8 and 7/16 tubing. All non compatible. I think the route I'll have to go is ti squash the 7/16 tube on to some 1/2 inch barbs.
Oh well at lest I'll know that once that tubing goes on it ain't coming off ...lol
Old 5th Nov 2012, 15:07   #328
Blarte
Moderate Modder
Blarte's Avatar
Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!Blarte - it's over 9000!!!!!!!!1!1!1!!!
washing up liquid, boiling water.. just make sure if its on compression fittings the compression bit is padded out with ptf or something (that plumbers putty works great)
__________________
Watering down PC's since 2009....
Blarte is offline   Reply With Quote
Old 7th Nov 2012, 22:14   #329
bulldogjeff
Got all the barbs now, Just tested one they have some serious grip. Won't let go unless I slice the tubing.
Looks like it's time to build a computer
Old 7th Nov 2012, 22:48   #330
KrunchR
Supermodder
KrunchR's Avatar
KrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpit
Yay! Now hurry up.
KrunchR is offline   Reply With Quote
Old 8th Nov 2012, 18:49   #331
bulldogjeff
Originally Posted by KrunchR View Post
Yay! Now hurry up.
It will all be done and dusted now very soon, maybe even by next week end.
Old 13th Nov 2012, 00:13   #332
bulldogjeff
I've been really busy lately but I have found some time to get started on the inside, mainly routing all the water cooling ..
To start with I have a matching pair of these...Although the blocks have different logo's on them, they are identicle, both GPU's are factory over clocked, but I'll be giving them a bit more.
So there you have it. A nice bit of progress.
I just need to braid a few cables, get it all wired up and leak tested and I'm done.
Probably be all finished with in the next few days.
Thanks for looking
Old 13th Nov 2012, 00:15   #333
Teelzebub
Teelzebub's Avatar
Nice one Jeff looking good mate.
__________________
Old 13th Nov 2012, 00:20   #334
YEHBABY
RIP Tel
YEHBABY's Avatar
YEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming Saiyan
Looking very good Jeff
__________________
i7 2700K / Asus Gene V / 8GB Corsair Vengeance LP / Samsung 830 256GB / 2x4TB HGST & 4TB WD Red / Be-Quiet! E9 CM580W / Antec P182 / Thermalright Silver Arrow Cooler / Dell U2412M
Microsoft Surface Pro 4
NAS: QNAP TS-670 Pro (upgraded cpu i7 3770S and 16GB RAM). RAID 6 (6 x 4TB) WD RED
YEHBABY is offline   Reply With Quote
Old 13th Nov 2012, 00:36   #335
bulldogjeff
Thanks a lot lads. The pics are a bit crap as I done them on the phone because my camera ran out of batteries.
Old 13th Nov 2012, 09:51   #336
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
An update! Woohoo!
Looking forward to the finished article, Jeff. I'm sure Dylan can't wait.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|16GB|256GB M.2|500GB SSD|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Old 13th Nov 2012, 23:14   #337
bulldogjeff
Originally Posted by Spreadie View Post
An update! Woohoo!
Well it's been leak tested now for a few hours and all seems ok, so it's time to start putting it all together.
Old 13th Nov 2012, 23:38   #338
Teelzebub
Teelzebub's Avatar
Yaaaaa glad to hear it Jeff
__________________
Old 14th Nov 2012, 02:41   #339
Kovoet
I Mod, Therefore I Own
Kovoet's Avatar
Kovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming Saiyan
Damn nice bud cannot wait to see it finished now
__________________
MOBO[ Asus Maximus Formula VII ]CPU[I7 4770K]RAM[Corsair Vengeance PRO Red 2133mhz]SSD's[1TB Samsung EVO, 256GB Samsung, 128GB Mushkin, 128 GT Corsair]GPU[EVGA GTX980]PSU[Corsair AX1200i Red Cables]CASE[Corsair 540] Cooler[Corsair H100i]Screen[Dell U2913WM} Perp[Corsair K70, Logitech G502,Belkin razer N52TE,
HyperX Cloud II]
Kovoet is offline   Reply With Quote
Old 14th Nov 2012, 12:43   #340
Ripitup121
MMMMMMm watercooling....
Ripitup121's Avatar
Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.Ripitup121 is a hoopy frood who really knows where their towel is.
Looking at those cards its a pity that BFG tech aren't still in business. They made some wonderful cards. Build is looking good Jeff, Looking forward to the final outcome.
__________________
Asus ROG Maximus V Formula MoBo, Core i5 3570K @ 4.7Ghz, 6GB Corsair Dominator Ram 1600Mhz, SLi GTX460's(1GB), Enermax Revolution 1250W PSU, Xigmatek Elysium Chassis
Dual WaterCooling Loops with 12 Noctua NF-P12's = WOOOOSH!!!
Ripitup121 is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
