Reply
Thread Tools View Mode
Old 28th Jan 2013, 03:27   #61
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
I think that F2 looks better. The black mesh matches better. As for the pump, if you can find another place for it, having push and pull fans is better. Lastly, on your rad it looks like the fans are pushing against each other, not facing the same way. Good luck with the pump, I know how hard it can be having to find a new place for something like that.
__________________
Project Carbon Apple
whyte is offline   Reply With Quote
Old 28th Jan 2013, 18:21   #62
Johnny71
Modder
Johnny71 has yet to learn the way of the Dremel
Yes, I am staring to like the F2 option better with time. I might be able to have it in the HDD bay, but I'm sceptical to the flow from res to pump then, don't want it to be a problem and maybe let the pump run dry when filling etc. Either that or take awat a set of fans, someone even suggested just to remove one fan on the side to make room for pump, wont the airpreassure be unbalanced if that even matter?
Yes you are correct, just put them on there to get the measurements, but thank you for pointing out
Johnny71 is offline   Reply With Quote
Old 29th Jan 2013, 12:23   #63
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
DAM that paitings looking marvelous.
dream1 is online now   Reply With Quote
Old 3rd Feb 2013, 13:56   #64
Johnny71
Modder
Indeed it does, mad props the the airbrush artist! Thank you for the feedback!
Old 6th Feb 2013, 14:52   #65
Johnny71
Modder
YAAAAY Milestone reached. Recently passed 30,000 views here on bit-tech.net
Huge thank you for the support and kindness you shown and also a shoutout to my sponsors!
Dm-finearts, Plåtspecialisten Örebro, Fractal Design, Corsair, Aquatuning, Mayhems and NZXT
Without you all it wouldn't be possible, yes it sounds cheesy but it's true.
Hope you will continue to follow the StarCraft Tribute project
Take care
Best Regards
Johnny
PenguinMawdz
Old 24th Feb 2013, 21:00   #66
Johnny71
Modder
Update!
Hello everyone!
Here's a little update on what I've been doing the last day or so.
The SLR is out and running somewhere so the note 2 got the job today.
A overall shot of how it looks at the moment.
The majority of what I've been doing is to find a solution on how I will solve the reservoir and pump issue but at the same time get it to look good.
To simplify the mounting of the res and also give a nice and neat way to hide some cables I cut a metal plate to sit over the rubber grommets.
Enkel plåt utskuren men obehandlad.
Another metal plate, though this one was laser-cut. Unfortunately the result wasn't acceptable, so I will get a new one done.
Used some foam to simulate the hight of the res.
Thinking about if I should reproduce this plastic lid in metal? Either way should I paint it and how?
Some test sleeving, not quite sure yet how I want to do with the sleeving colors and combination.
I think I have decided to go with having the pump where the HDD cage usually is placed. I will remove it completely to get it down in height some more. Because then there's a minimal tilt in the right direction. It shouldn't be a problem. If so, when filling up the gravity force/water pressure will give it all force it needs.
The drawback with this is that I don't get a single HDD slot available. Either I'll have to go hardcore SSD solutions or find some other space to push it into, however that's unlikely since this case is already packed^^.
When removing the HDD cage the aesthetics is drawn back, to solve this I will cut out a 3:rd metal plate to cover most of that side. Then I must find a nice way to let some air trough that plate or somewhere else so the front fans can bring in some fresh air.
One last thought before I sign out, should I go for a black finish on all the new plates or should I go the extra mile and get them painted like the rest of the theme even though it takes longer time?
Thank you for all the feedback, helps very much!!
Until next time, take care and mod on!
Johnny
Old 5th Mar 2013, 21:15   #67
MooZ91
What's a Dremel?
MooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the DremelMooZ91 has yet to learn the way of the Dremel
Awesome job... looks so great :3 ^^
MooZ91 is offline   Reply With Quote
Reply
Tags
modding, penguinmawdz, project, starcraft, tribute
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
