Reply
Thread Tools View Mode
Old 8th Jun 2012, 11:07   #1
aio
Multimodder
aio's Avatar
aio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for presidentaio should be considered for president
Case 4 Cu fittings performance (upd 05.05.2013)
Hello everybody from the city of white nights.
Let me present you my fourth Сase mod.
Sorry for my bad english : )
Factory model Aerocool Qs-202
First of all, turned the front panel
hdd rack for 4 disk
aio is offline   Reply With Quote
Old 8th Jun 2012, 13:31   #2
aio
Multimodder
aio's Avatar
Old 9th Jun 2012, 10:12   #3
aio
Multimodder
aio's Avatar
Next step "power button"
Old 10th Jun 2012, 01:51   #4
Mizugetsu
Multimodder
Mizugetsu's Avatar
Mizugetsu has yet to learn the way of the Dremel
Looking good
Mizugetsu is offline   Reply With Quote
Old 10th Jun 2012, 08:12   #5
dietje1908
Minimodder
dietje1908 has yet to learn the way of the Dremel
nice powerbutton
dietje1908 is offline   Reply With Quote
Old 10th Jun 2012, 08:15   #6
Shurika
Multimodder
Shurika's Avatar
Shurika has yet to learn the way of the DremelShurika has yet to learn the way of the Dremel
ai, nice to meet you here. I`ll tried not to unsecret all mod`s details before you finish
__________________
sorry for my English
Shurika is offline   Reply With Quote
Old 10th Jun 2012, 09:32   #7
Herodj95
Multimodder
Herodj95's Avatar
Herodj95 has yet to learn the way of the Dremel
Very good job!
The frontal is made of plexyglass or metal??
Herodj95 is offline   Reply With Quote
Old 10th Jun 2012, 10:59   #8
aio
Multimodder
aio's Avatar
Originally Posted by Mizugetsu View Post
Looking good
thanks
Originally Posted by dietje1908 View Post
nice powerbutton
thanks
Hello =)
Originally Posted by Herodj95 View Post
Very good job!
thanks
thanks
this is steel 10mm
Old 10th Jun 2012, 11:15   #9
Shurika
Multimodder
Shurika's Avatar
Herodj95
it is 10mm steel
__________________
Old 10th Jun 2012, 11:21   #10
aio
Multimodder
aio's Avatar
Сopper handles
soldering
polish
two component acrylic clear for car
Old 10th Jun 2012, 12:05   #11
KrunchR
Supermodder
KrunchR's Avatar
KrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpit
The front is awesome, will you be leaving it bare metal?
__________________
SYSTEM ONE on hold for now....
But my KnuckleDuster makes a Return!
For sale! lian li pc7
KrunchR is offline   Reply With Quote
Old 10th Jun 2012, 21:40   #12
aio
Multimodder
aio's Avatar
no, Powder Coating, coming soon
Old 10th Jun 2012, 23:08   #13
KrunchR
Supermodder
KrunchR's Avatar
Nice. Cant wait for next update.
Old 10th Jun 2012, 23:09   #14
aio
Multimodder
aio's Avatar
Thumbs screw
gears of laser cutting
and DIN 7991 M3-M4
Powder Coating
Old 11th Jun 2012, 09:33   #15
aio
Multimodder
aio's Avatar
Case Fans
Thermalright X-Silent
Add warm glow LEDs
2pin for controlling fan lights
2x140mm и 1x120mm
Old 11th Jun 2012, 09:54   #16
aio
Multimodder
aio's Avatar
CPU Fans
Enermax UCTB12
Old 11th Jun 2012, 17:27   #17
aio
Multimodder
aio's Avatar
Light
LED Strip with warm glow LEDs
Suit of Heat Shrink Tubing
Old 11th Jun 2012, 17:28   #18
aio
Multimodder
aio's Avatar
Cardreader
3pin hub for controling LEDs
Fanbus ZALMAN ZM-MFC1 Plus
fanbus will be inside
Old 11th Jun 2012, 17:35   #19
aio
Multimodder
aio's Avatar
Powder Coating
Power button
Front grille
HDD Rack
Front panel
Old 11th Jun 2012, 17:35   #20
aio
Multimodder
aio's Avatar
Window
A new window. Tinted plexy glass
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
