Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 8th Jun 2012, 13:17   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Should size be the new battleground in the motherboard market?
http://www.bit-tech.net/blog/2012/06...-battleground/
brumgrunt is offline   Reply With Quote
Old 8th Jun 2012, 13:30   #2
blinkieleblind
Tings and such
blinkieleblind's Avatar
blinkieleblind has yet to learn the way of the Dremel
i drool over the prospect of building a monster micro-pc!!
couldn't agree more
__________________
i5-2500k @4.4Ghz | MSI P67A-GD53 | GTX 770 OC | 128 GB Samsung 850 | 128G vertex 4 SSD | 1TB Seagate Barracuda | 8GB 1600mhz Corsair | XFX 850W PSU | Fractal Define R3 Titanium
blinkieleblind is offline   Reply With Quote
Old 8th Jun 2012, 14:02   #3
GuilleAcoustic
Ook ? Ook !
GuilleAcoustic's Avatar
GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.GuilleAcoustic is definitely a rep cheat.
I wish GPU could have a more "squared" shape to match mITX motherboard. Shorter but wider GPU board would allow a GTX680 to fit a case with a really small footprint. This is the actual GPU size that prevents case from being shorter.
GuilleAcoustic is offline   Reply With Quote
Old 8th Jun 2012, 14:15   #4
Somer_Himpson
Banned
Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.Somer_Himpson is definitely a rep cheat.
I love my mATX board, even housed in a big case...gives it room to breath!
Somer_Himpson is offline   Reply With Quote
Old 8th Jun 2012, 14:18   #5
GuilleAcoustic
Ook ? Ook !
To illustrate my idea about GPU size :
Old 8th Jun 2012, 14:24   #6
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyanbulldogjeff is a Super Spamming Saiyan
What I'm finding is that hardware in general is so powerful these days that size is starting to prove irrelevant. My old i7 940 asus P6 combo was more than enough for my needs.
I've said it in the past but 80% of us one here could quite easily cope with an i5 750 and some thing like a GTX 460 for most of the time.
bulldogjeff is offline   Reply With Quote
Old 8th Jun 2012, 14:26   #7
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Well, as someone who's buidling their own PCs for some 15+ years now I can positively say, that I've tried it all.
During the last two years I was all about mini ITX and it's quiet nice actually what you can do in that area. However cooling in such tight spaces is not as easily done and the level of noise increases the smaller your case gets.
Putting a mini ITX board into a µATX-case is counterproductive tho, as you'll get a better µATX-board for less money. So why would you want to buy mini ITX, when you still need a somewhat large case for effective cooling?
When you use a 200 Watt GPU in addition to a 95 Watt CPU your best option is still ATX or µATX, as you need the larger cases anyways to install enough cooling without being forced to have high RPM fans increasing noise significantly.
So no, size isn't really the new battleground in the motherboard-market when we're talking about workstation or gaming-rig performance. Trying to get the performance of an ATX or µATX-board on a smaller formfactor is wasted efforts imho aslong as the CPU and GPU don't get smaller (i.e. produce way less heat) without loosing performance.
Size might be a battleground for HTPC and office-PCs, that don't draw more then 100-200 Watts in total. My Atom/ION-systems for example draw only 30 Watts from the wallplug, and they're still capable of running office and multimedia-tasks without problems.
If you use the integrated graphics of the new intel or AMD-CPUs then you'll be fine aswell for office and multimedia and have the benefit of a little more power on the CPU-side.
I'd like to see more all-in-one motherboards, like we've seen from Zotac and ASUS, where the PSU was integrated aswell.
Give me a mini ITX board with LGA1155 socket, integrated 90W PSU and onboard WiFi, where I can install an upcoming i5-3470T (35W TDP) onto in addition to a PCIe x1 DVB-S card.
For workstations and gaming-rigs I'm only interested in reasonably priced ATX or µATX-boards with the standard-set of features. My next setup will be a LGA1155 µATX again, as my LianLi Q08-setup is too noisy due to it's cooling-restrictions, allthough I allready use a Corsair H60 for the CPU. An aftermarket-cooler like the Prolimatech MK13 for the GPU won't fit, so the GPU is too loud. It was even worse, when I had the hardware installed into a SUGO SG05.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 8th Jun 2012, 14:36   #8
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.
How about ONLY making mini-ITX boards, and then having the bits bolt on and be sold as extras.
ie
Z77 Pico ITX board, with a slots for
1. memory modules - 1, 2, or 4
2. additional PCI-e lanes
3. VRM's
4. Storage/SATA/Raid etc
5. Thunderbolt, USB
6. Bios/motherboard control
7. Power Supply (so that it could be integrated with the mobo for truly tiny builds)
Think of the cost model, and where they could make savings. 1 board per socket model, then a set of peripherals according to match, instead of 1 board per socket per marketing price point.
I see this as being a great way that manufacturers can drive/add value to the market. Upgrades would no longer involve full refreshes. The second hand market would not cannibalise the retail market so much, and manufacturing lines could be MUCH simplified, as would the test and QA process.
Returns would only need to focus on the broken bits, and that would be a specific item
It's a great idea, and I'm certain it would work. After all, I came up with it
Tattysnuc is offline   Reply With Quote
Old 8th Jun 2012, 15:06   #9
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
You also have to take in to account cooling of such a hot product. Many mITX cases only have a single air intake or maybe 2 smaller fan holes. But the idea is tempting.
__________________
SchizoFrog is offline   Reply With Quote
Old 8th Jun 2012, 15:14   #10
GuilleAcoustic
Ook ? Ook !
Yup, but unfortunatly it's unlikely to happen ... unless they revise the whole ATX norm .
My dream would be to have 2 processor sockets on a single motherboard : one for the CPU and one for the GPU, with the memory shared between them. When you look at the GTX670, the power circuitry is compact. A power circuitry like on the Asus deluxe could be used to produce such a board.
Old 8th Jun 2012, 15:17   #11
Hopelessness
What's a Dremel?
Hopelessness has yet to learn the way of the Dremel
ie
3. VRM's
5. Thunderbolt, USB
This sounds like DLC for motherboards
I had an Asus M2N32Sli-Deluxe a few years ago, that had WiFi onboard, and 2 Gigabit ethernets. What has happened to features like that on motherboards!?
Hopelessness is offline   Reply With Quote
Old 8th Jun 2012, 15:18   #12
javaman
May irritate Eyes
javaman's Avatar
javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.javaman is the Cheesecake. Relix smiles down upon them.
You have a point. Intel has broight thunderbolt tho it has limited appeal to most outside of a laptop atm. Does AMD still make their own chipsets? Its another area they could push sales in terms of features but what do you add? New ports take time to adopt and develop, PCI lanes arnt saturated, do we need more memory bandwidth? Only thing I can think of is adding a GPU back into the board for hybrid crossfire with their APU's or integrate a low powered arm cpu for basic tasks. Who knows, I'm not paid to think.
javaman is offline   Reply With Quote
Old 8th Jun 2012, 16:51   #13
themassau
Minimodder
themassau has yet to learn the way of the Dremel
maybe on-board flash memory. the flash would store your ram data when you go in hibernate lets say the size of 16GB or 32 GB for so you OS can also be on it. it would be like a buffer.
multi-socket motherboards for enthusiast.
maybe new orientation of the socket for better cooling etc like the BTX standaard but keep de holes at the same space so you can still put in ATX standaard cases.
12v only mobo's would make the market better. whit an batery on it that would be just large enough to get the ram copied to the integrated flash i told of.
themassau is offline   Reply With Quote
Old 8th Jun 2012, 17:30   #14
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
I thought the exact same thing, minus the shared memory. I think the GPU should have its own separate memory source, but still one that is manually defined.
I feel that all boards should start out as Mini-ITX, but have a new form of expansion. The board would come with everything you need to get a functional system - maybe 2 RAM slots, 4 SATA ports, a couple USB headers, 1 PCI-e 16x slot, audio headers, and any other essentials for the typical system. At the right side and bottom of the board would be a couple gigantic slots where you can attach daughter boards.
The right-side slot would expand the board to be the width of standard ATX boards. Daughter boards that go here can have varying lengths, being as long as the mini-ITX board itself to as long as a standard ATX board. These daughter boards would contain additional RAM slots, additional pin headers (so if there are 2 USB ports not in use, they could be put here), and features that take advantage of unused south bridge resources.
As for the slot at the bottom of the motherboard, users can buy daughter boards containing 3 expansion ports (expanding the motherboard to become micro ATX). These daughter boards can also be expanded upon each other, so you can form full ATX as well. These boards can have any variety of slots, whether that be all PCI, PCI-e slots designed specifically for SLi or Crossfire, or even mini-PCIe slots.
Products like this would put back originality and customization in home-made PCs, and if designed properly, allows anybody to make a computer of any price point.
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 8th Jun 2012, 17:36   #15
AmEv
Meow meow. See yall in 2-ish years!
AmEv's Avatar
AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.AmEv is definitely a rep cheat.
I've seen non-Dell motherboards that are uATX, with little cards that convert it into ATX.
__________________
The Elder is away.
AmEv is offline   Reply With Quote
Old 8th Jun 2012, 17:59   #16
TheDarkSide
Multimodder
TheDarkSide has yet to learn the way of the Dremel
they still exist! Asus z77 deluxe
but you pay a hefty premium for them.
TheDarkSide is offline   Reply With Quote
Old 8th Jun 2012, 19:28   #17
l3v1ck
really joined on Dec 24th 2004.
l3v1ck's Avatar
l3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremell3v1ck has yet to learn the way of the Dremel
I'd like to see one x16 PCIe slot for a single graphics card, then several open ended x4 slots. Ditch the x1 slots. A x1 card will still fit in a x4 slot.
My old Asus board had that so you could fit larger cards if you wanted, but they'd just get 4 channels.
There's every chance SSD's will soon need PCIe as even SATA III will be a bottleneck soon.
__________________
Originally Posted by Sifter3000
We swung the banhammer in his little stupid spamming face
The old Dennis Forums (CPC, PC Pro, Mac User etc) - Meeting Place lives on. You're welcome to visit it HERE
l3v1ck is offline   Reply With Quote
Old 8th Jun 2012, 19:37   #18
fata1_666
fata1_666 has yet to learn the way of the Dremel
Ive always had micro -ATX instead of full size atx boards like you say its just no needed and even now im looking at the mini -itx options purely for some space in the case and the fact it has all the features i need. the mini-itx has come along way and should soon be seen as the base for any new build then expand to bigger size if an add on card is required.
fata1_666 is offline   Reply With Quote
Old 8th Jun 2012, 23:18   #19
Tyr
Multimodder
Tyr's Avatar
Tyr has yet to learn the way of the Dremel
Smaller can be better. My all time favourite build was my wife's ASUS M4A88T-I Deluxe build. I had to add a lot of fins to the MOSFETs and the VRegs as I put in a 125W processor into eh little 95W board. Then Stuck a really big 12cm cooler/fan (almost as big as thr 14x14cm board!) blowing down to keep it all cool. Add in a top end GPU and it is a nice compact quiet gaming rig.
I just wish ITX boards and cases has a 16x PCI-E and a 1xPCI-E.
__________________
Ex-Notebook Junkie...
Now Desktop Junkie...
Tyr is offline   Reply With Quote
Old 8th Jun 2012, 23:31   #20
Picarro
I Mod, Therefore I Own
Picarro's Avatar
Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.Picarro is a hoopy frood who really knows where their towel is.
Give me a mini ITX board with good onboard sound! (Yes, F off Realtek). Then I can just add a short but powerful GPU like the 670 and be done with it.
__________________
Intel Core i5 2500k @ 5gHz -:- Gigabyte Z68X-UD3H-B3 -:- 2x4 gbCorsair Vengeance 1,5v 1600mHz -:- Gigabyte Windforce X3 GTX 670 -:- Crucial M4 128 gb -:- Samsung F3 Spinpoint 640 gb -:- Corsair H60 with 2x Gentle Typhoon 1850 in push-pull -:- Corsair HX650 -:- Lian Li A05FN -:- Dell U2410 flanked by 2x Dell U2001FP -:- BenQ W1000+ -:-
Picarro is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
