Reply
Thread Tools View Mode
Old 18th Jun 2012, 13:52   #1
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
Win prizes with your mods!
Our Case Mod Index has a sponsor! UK modding and watercooling etailer Specialtech will be offering up a prize each month to one lucky modder. This month its an awesome Xigmatek Aegir CPU cooler. How to enter? Simply submit your case mod to our Case Mod Index buy following the instructions HERE. Doesn't matter where you live - they ship internationally!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 18th Jun 2012, 14:01   #2
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
Scratch builds are excluded...boo! (and the url link in OP is borked)
yay@ post below
Meelobee is offline   Reply With Quote
Old 18th Jun 2012, 14:07   #3
Combatus
Combatus's Avatar
We're in the process of making a similar index just for scratchbuilds
__________________
Old 18th Jun 2012, 15:16   #4
Mosquito
Hypermodder
Mosquito's Avatar
Mosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run CrysisMosquito can run Crysis
Does it have to be a modern case? Only non-scratch I've done was of a case from the 1980's
__________________
Mosquito
Scratch Builds: Just A-PC | Mini HTPC | Music Box | Ham Theater PC
Case Mod: Definition: Server | IBM PC AT Reborn
Mosquito is offline   Reply With Quote
Old 18th Jun 2012, 15:26   #5
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!Pranja - it's over 9000!!!!!!!!1!1!1!!!
Nice,mine is in the index (don't remeber when I submitted,but ok).
Fingers crossed.
__________________
Cosmos S Reaper L.R.E.C. Scorpio
Arya-under construction ROG Crawler-under construction
Pranja is offline   Reply With Quote
Old 18th Jun 2012, 17:27   #6
Combatus
Combatus's Avatar
As long as you know the make/model that;s fine. If not, send it anyway as we'll probably add a 'generic' section at some point as a few people have asked for it!
__________________
Old 18th Jun 2012, 21:46   #7
bulldogjeff
The modding head is firmly back on.
bulldogjeff's Avatar
bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.bulldogjeff is the Cheesecake. Relix smiles down upon them.
Are the cases on there already included or just new stuff?
bulldogjeff is offline   Reply With Quote
Old 19th Jun 2012, 07:59   #8
Combatus
Combatus's Avatar
Jeff, the first month certainly we'll be including everyone, then we'll see how many submissions we get as to whether we just draw from new submissions, or with everyone.
__________________
Old 22nd Jul 2012, 19:29   #9
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
thumbs up fror specialtech! thank you for supporting the community!
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 30th Sep 2012, 00:22   #10
mybadomen
Multimodder
mybadomen's Avatar
mybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremelmybadomen has yet to learn the way of the Dremel
Is this an old post?or still going on?
mybadomen is offline   Reply With Quote
Old 28th Nov 2012, 01:59   #11
Matt's_Mods
What's a Dremel?
Matt's_Mods's Avatar
Matt's_Mods has yet to learn the way of the Dremel
Is this still current?
Matt's_Mods is offline   Reply With Quote
Old 28th Nov 2012, 15:22   #12
B NEGATIVE
Pipebender
B NEGATIVE's Avatar
B NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run CrysisB NEGATIVE can run Crysis
Yup.
I just won November!
B NEGATIVE is offline   Reply With Quote
Old 1st Dec 2012, 04:31   #13
Matt's_Mods
What's a Dremel?
Cool congrats
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
