Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Jun 2012, 10:33   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Intel unveils Xeon Phi MIC hardware
Intel has announced plans to launch the Larrabee-based MIC hardware as the Xeon Phi.
http://www.bit-tech.net/news/hardwar...ils-xeon-phi/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 19th Jun 2012, 11:31   #2
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
They may have ended up aiming at core count being a power of two. Until they say precisely, though, it's all guesswork.
I'm actually really curious about this; much is going to depend on performance per Watt, as even the HPC sector is getting energy conscious.
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Old 19th Jun 2012, 13:54   #3
LordLuciendar
meh.
LordLuciendar's Avatar
LordLuciendar has yet to learn the way of the DremelLordLuciendar has yet to learn the way of the Dremel
Not that these boards will ever be affordable by common man... but how long until a company like Lucid writes an app that siphons the massive computing power of these boards through onboard graphics?
There is just no arguing, twice the computing power has got to produce something good in the world of rendering.
__________________
ASUS P8P67 Pro, Intel i7-2600k @ 4.5GHz, Thermaltake Frio, 16GB (4x4GB) Corsair Dominator 1866Mhz, 2xCorsair Force Series 3 120GB in RAID0, Enermax Platimax 1kW, 2xEVGA GTX 670 SuperClock 4GB, 3xAcer 1920x1200 24in IPS, 4x WD2500AAKS in RAID0, LG HD-DVD/BD-R/DVD-RW Drive... and more. That's just my workstation.
LordLuciendar is offline   Reply With Quote
Old 19th Jun 2012, 15:01   #4
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
I saw somewhere but cannot remember where, but it said these thing's had around 100 cores based on the old Pentium 4.
I wonder if these would be able to be used for F@H giving you a massive increase in PPD possibly.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 19th Jun 2012, 15:24   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
Wherever you read it, it was wrong: they're fifty-some core cards, and have nothing to do with the old Pentium 4 architecture whatsoever.
That's exactly the kind of task Intel is aiming the Xeon Phi at: massively parallel processing in supercomputing and HPC. You *could* get a massive increase in PPD, but the boards are going to be seriously expensive and you'd need to modify the F@H code to specifically use the MIC architecture. Not that that's a real problem: when I spoke to Intel about MIC (based on what was then called Knights Ferry) at ISC last year, Kirk Skaugen claimed it had taken the university of forgottenwhere a week to modify their software to be MIC-ready.
__________________
Old 19th Jun 2012, 15:38   #6
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
i'm still unclear about these - is this actually a gpgpu like tesla or is it actually additional cpu cores? also, i feel like something like this would likely be faster than the main CPU of the system and therefore find it hard to believe that it can perform to its maximum potential from a pci-e slot. also, it is atom based again or xeon this time?
__________________
4.5GHz FX-6300 (on an AM3 board) with C'n'Q on, 8GB of RAM, R9 290, ADATA SP900 64GB SSD, Arch Linux 64 bit.
schmidtbag is offline   Reply With Quote
Old 19th Jun 2012, 15:43   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
Six of one, half a dozen of the other. The cores have more in common with a GPU than a CPU - they're based on the Larrabee architecture - but there's no graphics handling capabilities. They're designed for massively-parallel processing and floating-point performance, but they don't show up as CPUs to the system - you can't run your OS on them.
Remember it's got a chunk (8GB or more) of its own RAM, and Intel's making noises about InfiniBand backplanes (something Knights Ferry and Corner, which were PCIe exclusively, didn't feature.) Remember too that a GPU is technically 'faster' than the main CPU of a system at certain tasks - otherwise we wouldn't have GPUs...
Neither, it's MIC.
__________________
Old 19th Jun 2012, 15:55   #8
noizdaemon666
I'm Od, Therefore I Pwn
noizdaemon666's Avatar
noizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyannoizdaemon666 is a Super Spamming Saiyan
Wasn't Larrabee based on X86? So is this still X86 with added instruction sets or a completely different set?
__________________
I make up-to-date Windows ISOs for the making of faster installs
noizdaemon666 is offline   Reply With Quote
Old 19th Jun 2012, 16:00   #9
Gareth Halfacree
WIIGII!
bit-tech Staff
That's one of Intel's biggest selling points: unlike rival floating-point accelerator boards, such as GPGPUs and boards like Adapteva's Epiphany, the MIC boards are largely x86 - making them easy to code for. Unfortunately, they're special enough that code still has to be rewritten - but not as much as migrating the code to a non-x86 platform.
__________________
Old 19th Jun 2012, 16:21   #10
noizdaemon666
Ahh, thanks for that On the f@h front, you're not allowed to alter any of the code within the client, only the Stanford team are allowed. But if someone persuaded them to do it, and some other nice people with lots of money bought a couple of these, the output would be phenominal.
__________________
Old 19th Jun 2012, 17:10   #11
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyan
I have a couple of these on my future shopping list, for folding with (but not before Stanford update their code to support it). Should be a lot of ppd with these cards
__________________
HeatWare
debs3759 is offline   Reply With Quote
Old 19th Jun 2012, 22:43   #12
Alecto
Multimodder
Alecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the DremelAlecto has yet to learn the way of the Dremel
How does that work ? If they don't implement the entire x86 instruction set, the programs need to be recompiled to run on those cores anyway. If programs have to be recompiled, it doesn't matter whether those cores s'speak' any x86 at all - afterall x86 isn't well-known for being an efficient architecture or anything, it's a bloaty kludge on kludge kind of thing, so anything built from the ground up would provide better results ... and if you're recompiling anyway, why not recompile for the BEST solution ?
Alecto is offline   Reply With Quote
Old 19th Jun 2012, 22:44   #13
Alecto
Multimodder
How does that work ? If they don't implement the entire x86 instruction set, the programs need to be recompiled to run on those cores anyway. If programs have to be recompiled, it doesn't matter whether those cores 'speak' any x86 at all - afterall x86 isn't well-known for being an efficient architecture or anything, it's a bloaty kludge on another kludge kind of thing, so anything built from the ground up would provide better results ... and if you're recompiling anyway, why not recompile for the BEST solution ?
Old 20th Jun 2012, 04:34   #14
noizdaemon666
Because, as Gareth pointed out, most of the instruction set is the same only requiring relatively minor tweaks to make it work. Building from the ground up would take so much longer and loads more man hours to get anything to work with it. There's a reason x86 is still the predominant instruction set.
__________________
Reply
Tags
hpc, intel mic, intel xeon, knights corner, knights ferry, larrabee, many integrated cores, mic, nvidia tesla, pci express, supercomputing, tesla, xeon phi
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
