Hardware Shakmods Pre-Braided Cables Review
Discussion in 'Article Discussion' started by Baz, 20 Jun 2012.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
  2. Dave Lister
    Dave Lister Minimodder
    1 Sep 2009
    Images aren't showing up, is that just me ?
  3. Gareth Halfacree
    4 Dec 2007
    They're 300x250 images (with 300x250 in the filename) - a common ad format size. If you're using AdBlock Plus or similar, it'll assume the images are adverts and block them.
  4. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    If you're on Firefox, drop the main tools menu down and go to the bottom, you should see Adblock Plus. Just tell it to show the page.
  5. Dave Lister
    1 Sep 2009
    Ahh that will be it, i'm using adblock in chrome.
  6. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    Forgot how annoying the internet was without Adblock D:
    Very nice cables though, might have to pick some up
  7. Unicorn
    25 Jul 2006
    Well spotted. I didn't even think of that!
  8. David
    7 Apr 2009
    If you're using adblock, just add an exception for images.bit-tech.net
  9. Dave Lister
    1 Sep 2009
    I just turned adblock off for the site. The cables look great, I may have to order some I think !
  10. pizzanbeer
    pizzanbeer What's a Dremel?
    19 Jun 2009
    The cables look great.I would like to order some.There web sight not up yet :(
  11. Combatus
    16 Feb 2009
    shakmods isn't yet but if you follow the price link you can get them from ModPC.
  12. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I think this is a good response:
  13. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    If it was white and orange, it'd look exactly like the cableforms used in military jets (which are extremely shiny because they're made out of mineral wool braiding, which is fireproof).
  14. Guest-23315
    Guest-23315 Guest
  15. Tyinsar
    26 Jul 2006
    ^ heh heh
  16. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    What connector only has 11 cables?
  17. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    GOD DAMMIT DON'T ENCOURAGE HIM
    Anyway; I wonder if I can get it with Male connectors at both ends, so I could outright replace the cables on my Strider with these? I only need 30CM for the Motherboard connector, 20 ish for one of the EPS 12vs.
  18. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol: What's up Mankz, tried it & made you go mad or just tired of seeing really nice cable work?. :D
    Only real thing I've come across when doing it is it can bulk up cables to a point where it can make things a bit impractical, but with good planning for the extra bulk it wouldn't be a problem.
    I'll always sleeve fan cables now at least but all the others I want to come up with something new & as nonrestrictive as possible or even just use black wires & keep them as stealthed as possible so it almost looks like there is no power cables but not by soldering or fixing to the other side of a mobo, so will be a challenge & I'm yet to design the idea fully but p0Pe is onto the right idea & doing it perfect, really doubt I could do any better than that. :D
    Sleeving can test patience especially first time, first time isn't much fun at all, this I do know. :lol:
    These ready made solutions are great for people who like the end result but hate the effort. :D
  19. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    So Now I can see the images I have to have the ads as well... Nice.
    Why can't Bit-Tech use a different format to differentiate between images and ads. I do not want the ads full stop. If that means losing the images then so be it, but the long run will mean I will probably stop reading Bit-Tech as much.
  20. Combatus
    16 Feb 2009
    Hi SchizoFrog. It's not something we did on purpose, it's just a couple of key images required a slightly different image ratio than we usually use and unfortunately the resulting resolution happened to be one that ad-blockers don't like. We'll refrain from using this resolution in future so there should be any more issues.
