Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 10th Jul 2012, 08:47   #241
j_jay4
Supermodder
j_jay4's Avatar
j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.j_jay4 is the Cheesecake. Relix smiles down upon them.
Originally Posted by Burnout21 View Post
Bit: "So Simon can you tell us what your going to do when you get your 3920XM"
Si "I'm going to Disneyland! Woooooooh"
He even gets to go to Disneyland, he is splashing a lotta cash. Although he should max out the holiday and go Disney World. You gotta upgrade!
__________________
Gaming PC: ASUS PB287Q, Fractal Design ARC Mini R2, AsRock Z87e-ITX, Intel 4670K, Samsung 840 EVO 500 GB, G.Skill 8GB RipjawsX, EVGA GTX 670, Be Quiet! Dark Power Pro 750 W.
HTPC Server Samsung UE40F5000, HP ProLiant G7 N54L 2.2GHz MicroServer, 4 GB RAM, ASUS R7 240, TBS 6982, Samsung 830 256 GB, 3 TB WD Red.
j_jay4 is offline   Reply With Quote
Old 10th Jul 2012, 10:24   #242
N17 dizzi
Mod Amateur
N17 dizzi's Avatar
N17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming SaiyanN17 dizzi is a Super Spamming Saiyan
Originally Posted by Pookeyhead View Post
Seems to be the same here. Temps when benching are around 75degrees. Boost is always at around 1100 to 1150MHz, and goes up to 1176 when it drops below 70C.
A fine choice of card you have made there That's just about what mine do. Over 80 gpu 1 used to drop to 1110 due to suffocation.
Underwater they never go below 1150 stock and I run them at 1200~ anyway
N17 dizzi is offline   Reply With Quote
Old 10th Jul 2012, 10:54   #243
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
You 2 are forgetting that your cards are SC which are far from a vanilla card. Also you will have a high flowing rear bracket which helps maintain lower temps. Also not forgetting where your chip came from on the die can result in higher boost clocks and lower temps. So again, this can result in you being within the threshold to maintain boost all the time.
I'm sure when reading around you will find cards dropping to the stock core once temps get to the threshold.
Also you need to bare in mind that anyone running 3Dmark 11 etc will OC their cards to get maximum performance, so yes N17 - your score will look low to the norm.
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
Last edited by true_gamer; 10th Jul 2012 at 12:51. Reason: Spelling...Stupid phone...
true_gamer is offline   Reply With Quote
Old 10th Jul 2012, 16:30   #244
N17 dizzi
Mod Amateur
N17 dizzi's Avatar
Maintain lower temps with SC cards? I said that mine on air hit 85c because it was suffocated and still boosted beyond the manufacturers stated boost speed.
Me being right near the bottom of that graph is because I was the only person that had lowered my speed by 250Mhz, obviously!!!
I'm sorry to fall out with you T_G but this feels more like an exercise in trying to belittle high end Nvidia desktop cards for someone who has an AMD laptop.
Old 10th Jul 2012, 16:51   #245
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Well, we can all agree that a single 670/680, will always provide a better gaming experience than any two mobile GPUs, even at 'stock' - which, by the way I agree with Dizzi on, and should include the boost, since its ships on all cards by default. If you read Techreports in depth article, you'll see that in BF3 (arguably the ultimate real world test of a GPU) "the chip spent most of its time at about 1.1GHz—above both the base and boost levels."
No 50ms+ frame renders (common complaint with any SLI/X-Fire setup), less noise, and far better bang for buck.
You don't buy a gaming laptop to get the fastest speeds (never going to happen), and as a value proposition, its pretty terrible too, but, the 7970m are nevertheless impressive....... for a laptop GPU.
No doubt when TG decides he wants to play with the big boys again, he'll be back to 4GB 680's!
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 10th Jul 2012, 22:18   #246
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Lol.
Hahaha. Disneyland first this year, then Egypt next year. So Disney World and the rest around the international drive is on the agenda for the yr after.
You're taking this to heart, when all I'm doing is seeing where the 7970m's fit in with the desktop GPU's.
You're now quoting me to be a fanboy of AMD? I only buy what ever is faster at the time of making my purchase, so obviously I went for the 7970m's because they were the fastest GPU on the market at that time, and almost double the speed of NVidia's offering.
At the end of the day, boosting is OCing (Whether you except that or not. That is how I and many others see it.) This is why I wanted to see what the GTX 670 is like at its base clock of 915MHz, which you showed me. Thank you.
So by going by the base clocks of mine and yours, we can see that the 7970M's are very fast for a mobile GPU. (I am not dissing NVidia's desktop GPU's at all. As I have to admit, I prefer NVidia).
So as soon as you go over that base clock of 915MHz it is boosting (OCing it's self).
So this is now water under the bridge, so lets move on and keep this thread a friendly place.
You do buy the fastest gaming laptop for the best experience in a truck.
And yes, when the time comes, and things change, which they do in life...I will get another desktop, to keep the trend going.
__________________
Old 10th Jul 2012, 23:42   #247
N17 dizzi
Mod Amateur
N17 dizzi's Avatar
Not to heart but I do take issue with what your saying as I own 670s and what you are saying is inaccurate.
Whether you accept it or not. GPU boost is a feature designed and implemented by the card manufacturer to increase card performance in relation to the TDP etc. It is not overclocking, as in, something that used to void a warranty not so long ago. I and many others see it that way.
I posted the 915 run, underclocking my offset by 250Mhz, because you asked me and I consider you a friend on this board, not so you can have a stick to beat 670 owners with.
I'm happy to move on, water has flowed any time you like, if you stop with this line that GTX670 or 680s by default run at their base clocks. Because they do not.
Carry on with the thread by all means
Old 11th Jul 2012, 08:16   #248
true_gamer
Cheesecake on sale!
true_gamer's Avatar
You've slightly gone off the rails - where am I beating 670 owners with a stick...
670/680's come with as you say a boost feature, which in it own class is self OCing. (Call it what you will, but it's still OCing. No different to Intel's turbo feature which also gives it an advantage).
So back to the point - you showed me what the 670's have done at its base clock. And you have clearly expressed yourself after doing it, prior to you flaunting your ego when cranking up the clocks, when all I wanted was to see a fair comparison...
So now it is time for others to read through and judge for them selfs, and so we should leave it as that.
Still friends.
__________________
Old 11th Jul 2012, 11:12   #249
N17 dizzi
Mod Amateur
N17 dizzi's Avatar
Yeah I did flaunt a bit, but hey you are the king of flaunting so don't hold that against me!
Still friends, agree to partially disagree
Old 11th Jul 2012, 11:34   #250
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Very true mate.
I'm glad we came to a mutual agreement.
Also peeps love us flaunting our stuff, as they get to see results without them splashing the cash.
__________________
Old 11th Jul 2012, 13:23   #251
merter
What's a Dremel?
merter has yet to learn the way of the Dremel
I'm well overdue an upgrade... really wish I was buying one of these instead of a new house :|
merter is offline   Reply With Quote
Old 12th Jul 2012, 01:14   #252
Teelzebub
Up yours GOD,Whats best served cold
Teelzebub's Avatar
Teelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming SaiyanTeelzebub is a Super Spamming Saiyan
Lol you cant live in a laptop.
__________________
bt was once a great and vibrant forum wtf happened to it? , there must be a Hex on us back to mediocrity Get back under your bridges you scummy Troll's and STFU Mountain mods case, Enermax 1250w PSU, Asus Maximus V Extreme, i7 3770k @ 14.6ghz, Samsung 840 250gb SSD. 500gb Seagate,Corsair H80i wind tunnel, 16gb Corsair Vengeance pro 1866mhz,4xEVGA GTX 670 quad SLI 2 x Dell U27" @ 2560 x 1440, 4 bags of weed
Teelzebub is offline   Reply With Quote
Old 12th Jul 2012, 01:33   #253
Elton
Officially a Whisky Nerd
Elton's Avatar
Elton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming SaiyanElton is a Super Spamming Saiyan
Don't listen to him! Of course you can! I do what I want! I'm an ADULT!!
On the other hand, I'm mighty jealous of this. But that much money is more than a tad excessive. And no IPS screen for the lose.
__________________
Gotta keep it 100 we got fundamentals.
Elton is offline   Reply With Quote
Old 12th Jul 2012, 10:15   #254
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Benchmarks: i7 3720QM @ 3.8GHz - GPU's @ Stock.
Cinebench 11.5
SuperPi
Geekbench
__________________
Old 12th Jul 2012, 11:04   #255
Ljs
Mod Master
Ljs's Avatar
Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.Ljs is definitely a rep cheat.
Pffft... Windows Experience Index is the benchmark for REAL MEN.
Very nice dude, and yes, I am jelly!
Ljs is offline   Reply With Quote
Old 12th Jul 2012, 11:45   #256
BennieboyUK
CPC Folder of the Month Sep 2011
BennieboyUK's Avatar
BennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming SaiyanBennieboyUK is a Super Spamming Saiyan
Such an awesome lappy, such a shame they don't have a matt screen option, I just couldn't get on with the screen when I had my 17 R3 - had to sell it. Just too reflective in almost all light conditions
__________________
Main Rig|4790k @ 4.8ghz on H60|ASUS ROG Impact ITX|8gb Vengance Pro @ 2000mhz|Samsung EVO 250GB|MSI GTX 980 4GD5 OCV1|600w SFX Strider|FT03 Mini|U2711|K65 RGB|R.A.T. 5
Server|Dual x5690's|Intel S5500BC|32gb DRR3 ECC|OS 240gb Intel 520|Hyper-V 240gb RevoDrive x3|RS25DB080 on x4 WD 4TB Blacks Raid 5|x2 WD 2TB|Intel Quad Port VT|
Backup|AMD 1354|8gb|OS 30gb SSD|SRCSASBB8I x5 1TB Raid 5|
BennieboyUK is offline   Reply With Quote
Old 12th Jul 2012, 12:05   #257
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Yes WEI is the ultimate test! XD.
Thanks Mate.
Very true, but did you know that behind the glass screen is a anti glare panel. (Read it on another forum as someone else strip his back).
I have managed to fine some anti glare film for it. So that will be going on when it comes.
Vantage with 1 GPU @ Stock- CPU @ 3.8GHz
Vantage with both GPU's @ Stock - CPU @ 3.8GHz
My new CPU 3920XM arrived this morning, so will putting that in some time today with pics to follow. But first I have to redecorate my Daughter's bedroom ready for her new High sleeper bed to come tomorrow.
__________________
Old 12th Jul 2012, 17:09   #258
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Installing the 3920XM in to my Lappy.
Where to start...
Remove the keyboard.
Flip it back over and start undoing all the screws...
Removing the Screen.
Removal of the palm rest. Which was a pain in the bum, trying not to break the plastic clips. But with a bit of time and patients, no harm was caused.
Oh look! That will be the 3920XM...
Came specially delivered from OCUK this morning! Thanks Andy. Top service as always!
Taking the 7970M out to remove the heatsink and add some MX2 to it instead.
Heatsink removed!
Doing the same to the other 7970.
Now putting it all back together. Believe it or not, this was the most hardest bit of putting it back together. The stupid cable to the keyboard was so fiddly, it took me 30mins to get the bloody thing in. But we got there in the end.
And to finish off, heres a Bios screen shot.
Oh just one more thing, and I know this will piss off a few peeps.
CPU OC'ed to 4.2GHz on all cores.(Now need to get the Dual copper heatsink for the CPU, to clock it further.)
Muahahaha!
Clicky
__________________
Old 12th Jul 2012, 17:50   #259
true_gamer
Cheesecake on sale!
true_gamer's Avatar
SuperPi 3720QM @ 3.8GHz vs 3920XM @ 4.2GHz
__________________
Old 12th Jul 2012, 20:20   #260
teacherboy
Part Carbon/Nylon/Bovine
teacherboy's Avatar
teacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpitteacherboy is almost as Godly as yodasarmpit
You sir have Cajones the size of space hoppers
I tip my hat to your bravery and dedication to the overclocking cause - and am very jelly of the monster laptop, my wife is bored of hearing about your exploits now
__________________
Planning more charity bike rides but building a road bike first.......
teacherboy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
