#1 |
Administrator
bit-tech Staff
Intel unveils Centerton, Avoton Atom SoCs
Intel has announced the Centerton and Avoton Atom SoC parts, designed for the microserver market.
http://www.bit-tech.net/news/hardwar...erton-avoton/1 |
#2 |
theorycrafting
The race for more efficient low-power-solutions is very welcome here.
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#3 |
Supermodder
I wonder if Avoton on 22nm is finally introducing architectual changes to Atom that Intel is promising. Things like true OoO processing, etc. IIRC Intel has been saying 2013 and the transition to 22nm Atom is when Atom is getting a full architectual rework.
I'd be interested to see that. That said, I can't complain about recent low power Intel stuff. Sure, 8.95w is under load, but my current SB Celeron file server at home, with a micro ATX H75 Board and 4GB of 1.35v DDR3 memory, Intel PCI-e GBE NIC, an SSD boot drive and pair of spinning disks draws all of 17.5w at long idle with the disks spun down and only 21w when steaming a single 720p stream. Under heavy load with all of the disks spun up it draws only a bit over 50w. Old Semron 140 micro ATX server w/ 2GB of DDR3, which was replaced by the SB Celeron server, drew 39w from the wall at long idle and 45w when streaming a 720p stream (about 60w when heavily loaded, and at best half the computational power of this sandy bridge celeron machine). I'll take every bit of power savings I can though, supposing processing power has advanced enough to give me at least half of what my SB celeron server setup has, at signficantly less power draw. That would make a good always on file server and content server if system power draw (not including drives) could be something south of 10w at idle.
__________________
Core 2 Duo E7500, MSI P43-C51, 2x2GB G.Skill Eco DDR3 1600 Cas 7, OCZ Vertex 60GB, Vertex 30GB, Samsung F3 500GB, Samsung F4 2TB, Powercolor Go Green ATI 5570 |
| Thread Tools | |
