Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 26th Jun 2012, 10:37   #1
Pubkrooz
I Break Stuff
Pubkrooz's Avatar
Pubkrooz has yet to learn the way of the Dremel
ASRock Z68 Fatallity Compatibility Question
Hi All,
I was wondering if any of you guys could help me out.
My new build is based around a Fatal1ty Z68 Professional Gen3, the dr debug feature on it is throwing up an error code 45 which according to google is a generic memory fault.
The ram im using is Corsair CMX8GX3M2B1600C9, putting an individual stick into each slot still throws up this error. Im close to RMA'ing the motherboard but i checked the compatabillity lists of the mobo and didnt find my ram on there (i know i shouldve checked but normally suggestions from this forum are reliable enough.
Am i being thick or are these 2 things uncompatable?
(links to the stuff on scan are below if i havent been clear enough)
Thanks In advance
Pub
MoBo = http://www.scan.co.uk/products/asroc...30-%28x16%29-d
RAM = http://www.scan.co.uk/products/8gb-%...s-9-9-9-24-15v
Pubkrooz is offline   Reply With Quote
Reply
Tags
as rock, compatibility, corsiar, motherboard, ram
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
