Reply
Thread Tools View Mode
Old 26th Jun 2012, 22:16   #1
GotMod?
Minimodder
GotMod?'s Avatar
GotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the Dremel
"Monochrome" Lian Li V600f / Finished 28Nov
Hi to all crazy people!!
Some modding from Moscow )
im new to all these..modding, wc, bit-tech ) first project ever - greetings!!!
I'll be short for comments, let's get to bizznes, i mean business ) (my english is not too good)
Here is the case to be modded (Lian Li V600f):
Not the best solution for a watercooling, but looks freakingly nice!
The first thing i did was taking it apart:
*nice stiker on the back
Totally taken apart (sorry for pics quality):
Parts to be painted:
Some pics of hardware i'm gonna use:
GotMod? is offline   Reply With Quote
Old 26th Jun 2012, 22:45   #2
Sparky1987
Multimodder
Sparky1987's Avatar
Sparky1987 has yet to learn the way of the DremelSparky1987 has yet to learn the way of the DremelSparky1987 has yet to learn the way of the DremelSparky1987 has yet to learn the way of the Dremel
Ah! Always good to see a Lian li build I've done a couple myself, the most recent is half done mind you.
If I could give some advice, always finish your build, even if it costs more then you expected, it's worth it in the end, knowing you built it and it works .
Happy building!
Sparky1987 is offline   Reply With Quote
Old 26th Jun 2012, 22:48   #3
GotMod?
Minimodder
GotMod?'s Avatar
Painted all the parts with matte white:
And the result:
Old 26th Jun 2012, 22:49   #4
GotMod?
Minimodder
GotMod?'s Avatar
Happy building!
Thank's a lot!!
Old 27th Jun 2012, 12:24   #5
GotMod?
Minimodder
GotMod?'s Avatar
Sleeving
Ok, did the sleeving. Used panda camo paracord.
Old 27th Jun 2012, 12:30   #6
GotMod?
Minimodder
GotMod?'s Avatar
But as i did the sleeving for the first time, i guess i did it not really good.
I don't like the result. Heatshrink seems to me too ugly )))
I decided to remake it without using heatshrink.
Here is the result. Looks much better to me:
And here is 24-pin:
Old 27th Jun 2012, 13:26   #7
Shurika
Multimodder
Shurika's Avatar
Shurika has yet to learn the way of the DremelShurika has yet to learn the way of the Dremel
Welcome to the bit-tech! Your mod is very interesting - looking good so far!
расскажешь, как делал без термоусадки? у меня тоже репшнур и тоже хочу как у тебя сделать - интересно, как делал. Привет из Москвы
__________________
sorry for my English
Shurika is offline   Reply With Quote
Old 27th Jun 2012, 13:37   #8
GotMod?
Minimodder
GotMod?'s Avatar
Thank's Shurika!
I'll try to make a short vid to show you how to make it shrink-free, its really easy - melt and twist ))
Old 27th Jun 2012, 13:38   #9
Shurika
Multimodder
Shurika's Avatar
OK, I`ll wait for update
__________________
Old 27th Jun 2012, 17:26   #10
Sparky1987
Multimodder
Sparky1987's Avatar
I agree no heat shrink looks lots better from your pics so far it's looking good, great finish to your paintwork with clean lines, can't beat a good black and white build
Old 27th Jun 2012, 22:25   #11
Lehani
Multimodder
Lehani's Avatar
Lehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the Dremel
Very nice build - yes i would love to see how you sleeve without using heatskrinks
i have some MDPC sleeving for my furture build - so making that without heatskrink would what be lovely
Lehani is offline   Reply With Quote
Old 28th Jun 2012, 08:19   #12
GotMod?
Minimodder
GotMod?'s Avatar
Thanks!!!
Old 28th Jun 2012, 08:23   #13
GotMod?
Minimodder
GotMod?'s Avatar
Time for the inside panels
Ok, with the help of cardboard, did the templates of the inside panels:
The AutoCad version:
And the real ones after lasercut:
Here is the plan on how to place them:
Old 28th Jun 2012, 08:31   #14
GotMod?
Minimodder
GotMod?'s Avatar
Cut all the holes:
Old 28th Jun 2012, 11:55   #15
GotMod?
Minimodder
GotMod?'s Avatar
Shurika, as i promised, here is a short video on how i make it
I guess the same method works with MDPC sleeving as well.
Old 28th Jun 2012, 14:51   #16
GotMod?
Minimodder
GotMod?'s Avatar
Just testing how everything fits:
Old 29th Jun 2012, 02:32   #17
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
Cool vid! I'll have to try paracord next time. I just made my first attempt at sleeving and used my fingers to push in the staples... You're right, sliced the **** out of several of em. Looking forward to the rest of this project.
whyte is offline   Reply With Quote
Old 29th Jun 2012, 03:02   #18
krussellusaf
Modder
krussellusaf has yet to learn the way of the Dremel
That sleeving technique is amazing. Thank you very much for the how to vid.
krussellusaf is offline   Reply With Quote
Old 29th Jun 2012, 08:56   #19
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
What type of paracord did you use? I presume it's the 3mm stuff with the centre pulled out?
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 29th Jun 2012, 11:04   #20
GotMod?
Minimodder
GotMod?'s Avatar
Thank you all guys!!
It's usual paracord 550 Type III, approximately 4 mm. There was something in the center, I don't know how to call it, but i had to pull it out.
Reply
Tags
sff
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
