Reply
Thread Tools View Mode
Old 29th Jun 2012, 15:22   #21
krussellusaf
Modder
krussellusaf has yet to learn the way of the Dremel
Originally Posted by GotMod? View Post
It's usual paracord 550 Type III, approximately 4 mm. There was something in the center, I don't know how to call it, but i had to pull it out.
Should be 7 nylon strings. I'm not sure on the exact numbers but that's why its called "550". Each string has a specific weight limit and the sheathing does as well adding up to 550. A full piece of 550 can hold 550 lbs. Just a little gee wiz :P
krussellusaf is offline   Reply With Quote
Old 29th Jun 2012, 15:23   #22
Shurika
Multimodder
Shurika's Avatar
Shurika has yet to learn the way of the DremelShurika has yet to learn the way of the Dremel
Thank you, GotMod, I`m going to do the same think, but I decided to ask your method at first.
@Krikkit, there are some strong cord in the middle, I use it to pull long wires through the paracord
__________________
sorry for my English
Shurika is offline   Reply With Quote
Old 30th Jun 2012, 12:25   #23
GotMod?
Minimodder
GotMod?'s Avatar
GotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the DremelGotMod? has yet to learn the way of the Dremel
Little update:
Nothing special, just replaced all stock lian li's fans.
BitFenix Spectre LED White 140mm at the top. It will also be used as the lights:
Arctic Cooling ARCTIC F12 120 mm for the rad (push/pull). Not the best efficiency, but the look is great:
GotMod? is offline   Reply With Quote
Old 1st Jul 2012, 09:46   #24
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
This is looking great GotMod? Good call on "ascetics over efficiency" on the fans
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 1st Jul 2012, 09:52   #25
keir
S p i t F i r e
keir's Avatar
keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!keir - it's over 9000!!!!!!!!1!1!1!!!
Looking good so far.
__________________
Latest project ¦ Hidden living room gaming PC ¦ Awaiting time/space from kids
UV . Silent . waterCooled - Vertex 4 256GB . i5 750 @ 3.1Ghz . 8GB DDR3 1600 . Gigabyte GA-P55M-UD4 .GTX 670
keir is offline   Reply With Quote
Old 1st Jul 2012, 10:14   #26
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
i've got 3 arctic 120 PWM in my case - they pretty noisy for my ears i can tolerate them only at 40-50%
OT: they were cheapest PWM fans i can get... never thought about myself that i so acoustic intolerant as anesthesiologist i'm pretty deaf but this boys loud
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is online now   Reply With Quote
Old 1st Jul 2012, 14:18   #27
GotMod?
Minimodder
GotMod?'s Avatar
Thank's!!!
i've got 3 arctic 120 PWM in my case - they pretty noisy for my ears i can tolerate them only at 40-50% OT: they were cheapest PWM fans i can get... never thought about myself that i so acoustic intolerant as anesthesiologist i'm pretty deaf but this boys loud
I'll check it when the case will be done. I'm more concerned about the temps. If i will be not satisfied with it i'll go for GTs.
//cpu gpu wateblocks installed, pictures soon...
Old 1st Jul 2012, 14:56   #28
Pinwmpires
Minimodder
Pinwmpires's Avatar
Pinwmpires has yet to learn the way of the Dremel
Very good job! Simple and clean.. I love this kind of mods! Keep it up
Pinwmpires is offline   Reply With Quote
Old 1st Jul 2012, 22:17   #29
GotMod?
Minimodder
GotMod?'s Avatar
Thank u.
Seen your build on xtreme. Amazingly illuminated midplate and the rig itself
__________________
'Monochrome' Lian Li V600FB - Finished
Old 2nd Jul 2012, 16:56   #30
GotMod?
Minimodder
GotMod?'s Avatar
Little update. Installed cpu and gpu waterblocks.
Here are some photos of the blocks i made:
EK-SUPREME HF - ACETAL+EN (NICKEL)
EK-FC580 GTX - NICKEL
CPU installed:
Some pics of gpu mounting process:
And the result:
__________________
Old 2nd Jul 2012, 20:00   #31
Vetalar
*learning english*
if i'll be e-tailer - i've ramp up prices for _old_ design EK products 50%... at least...
nice parts here!
__________________
20 have a sleep
30 goto 10
Old 2nd Jul 2012, 21:21   #32
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
Mount the cpublock as it shoud be !, otherwise it looks great!
KoSoVaR^ is offline   Reply With Quote
Old 3rd Jul 2012, 09:26   #33
GotMod?
Minimodder
GotMod?'s Avatar
Hmm, I really didn't think it would matter. seen many builds with this way of mounting.
Can anyone explain me the difference if I rotate it, please?
Thanks.
__________________
Old 3rd Jul 2012, 10:48   #34
Elton
Proud Model M User
Elton's Avatar
Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!Elton - it's over 9000!!!!!!!!1!1!1!!!
Have you considered putting a shroud on top of the waterblock? I have no idea why, but I always liked having something covering that 2nd slot. It just seems so...interesting.
__________________
There's good ideas and then there's terribly great ideas.
Elton is offline   Reply With Quote
Old 3rd Jul 2012, 10:51   #35
Vetalar
*learning english*
maybe there be better results when WB fins will be perpendicular with CPU core?
__________________
20 have a sleep
30 goto 10
Old 8th Jul 2012, 14:28   #36
GotMod?
Minimodder
GotMod?'s Avatar
Little update.
Started to mount the rad, but faced a problem. Rad wouldn't fit in stock lian li's holes:
So i started to think how to mount it. One way was to make custom stands and the other was to use XSPC brackets. I stopped on second one:
And when i began to mount it, i came with a genius idea. If i rotate the lian li's stand upside down, the rad would fit perfectly. So i started to do it:
Upside down:
Mounted the rad to the stand and to the case:
Also placed 140 fan at the top:
Pump is also in the place. (Almost out of space for cables). Some pics of the current state:
__________________
Old 8th Jul 2012, 17:52   #37
Shurika
Multimodder
Shurika's Avatar
It`s pretty! I like colours! 2 fans are good enough for this thick radiator?
__________________
Old 11th Jul 2012, 18:23   #38
GotMod?
Minimodder
GotMod?'s Avatar
Thanks, Shurika!! I hope it will be enough. If not, i've got a Plan B:
Also started to think what to do with the front panel and how to cover it:
Came up with this design (the letter "M" for Monochrome). Going to use white and black plex (2mm each):
Planning to play with some leds and something else ))
Build at the moment (routing hoses, which will be replaced with white or black):
__________________
Old 12th Jul 2012, 07:47   #39
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Looking good. Keep it up!
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 12th Jul 2012, 23:05   #40
RebootTech
Budget? What budget?
RebootTech's Avatar
RebootTech has yet to learn the way of the DremelRebootTech has yet to learn the way of the Dremel
It was quite a few posts ago, but your video of sleeving the cables *totally* helped me out. I had tried about 6 different methods and couldn't get it right, but your ideas to 1) wrap the tip in tape, and 2) melt the end around the tip a bit when finished, took me from madly frustrated to sleeving cables. Thank you so much for that video!
RebootTech is online now   Reply With Quote
Reply
Tags
sff
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
