#1 |
Let there be LED's!
Nuclear Fission
#2 |
Let there be LED's!
'Strip Tease'
#3 |
Let there be LED's!
GTX 480's compared to a GTX 460
#4 |
Let there be LED's!
All tubed up and filled!
#5 |
Let there be LED's!
Replaced the top cathode with UV LED's
#6 |
Minimodder
#7 |
Let there be LED's!
Almost there!
#8 |
Let there be LED's!
Faulty PSU which needs to be returned...
#9 |
Let there be LED's!
This is the issue with the PSU. I am going to return it and may pick up a CoolerMaster Silent Pro Hybrid M1300 to replace it...
http://www.youtube.com/watch?v=gUw2Z8lVkbo |
#10 |
Let there be LED's!
#11 |
Let there be LED's!
Busted the green LED's in the CPU block, as well as the two LED's in the res...
#12 |
Let there be LED's!
Replaced the LED in the CPU block. Now I am contemplating replacing both 480's with a single 7970 with waterblock. The 480's are heating up the loop and making the CPU to IDLE at 50 degrees C.
#13 |
Fenrir The Wolf
Instead od replacing those GTX 480's you should consider making dual loop.
You can istall 240 mm rad in front and 120 mm in the top of the case.
__________________
Cosmos S Reaper L.R.E.C. Scorpio Arya-under construction ROG Crawler-under construction |
#14 |
Let there be LED's!
There is no room for extra radiators except for a 120 up top but I suppose I could place a radiator on top of the 540 rad?
#15 |
Fenrir The Wolf
If there is no room,make it.
![]() But you can also try with sandwich rads if you use slim ones.
__________________
#16 | |
Let there be LED's!
#17 |
Addicted to modding.
go on, squeeze it in, you know u wanna. lol
#18 |
Let there be LED's!
#19 |
Fenrir The Wolf
Temps would be like 30-40 C for CPU and 40 C for GPU's in idle.
__________________
#20 |
Let there be LED's!
At the moment temps are 50-60 C for CPU and 40-50 C for GPU's in idle.
| Tags |
| fission, nuclear, silverstone, watercool, x79 |
| Thread Tools | |
| View Mode | |
