Reply
Thread Tools View Mode
Old 5th Aug 2012, 10:37   #21
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Originally Posted by reeper250 View Post
At the moment temps are 50-60 C for CPU and 40-50 C for GPU's in idle.
Well,there will be big improvement if you use another radiator.
Pranja is offline   Reply With Quote
Old 5th Aug 2012, 11:03   #22
reeper250
Let there be LED's!
reeper250 has yet to learn the way of the Dremel
Add another 540 rad, then add a mod-kit to the D5 pump, and away I go! I just need to figure out how to route the tubing between the two radiators now (FT02 case)...
reeper250 is offline   Reply With Quote
Old 8th Sep 2012, 13:22   #23
reeper250
Let there be LED's!
Added two blue LED strips. One to the top, one to the bottom;
Old 9th Oct 2012, 07:35   #24
reeper250
Let there be LED's!
Another 540 rad wouldn't fit in the bottom so instead I got a Koolance 120 rad for the top. At least it'll help a little...
Old 9th Nov 2012, 11:09   #25
reeper250
Let there be LED's!
Ended up taking apart EVERYTHING and I am not selling my two GTX480's with blocks.
Reply
Tags
fission, nuclear, silverstone, watercool, x79
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
