Reply
Thread Tools View Mode
Old 30th Jun 2012, 19:05   #1
legoman
breaker of things
legoman's Avatar
legoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for president
(no name) Raspberry Pi scratch build media centre update (11/07/12)
Sooooo, first proper case mod/build so something a little bit different.
Like many others i ordered myself a Raspberry Pi when they were first available. Mines here and ive been enjoying it since.
I decided i wanted it as a media centre as many have but more over i wanted it as a standalone media device hence this build
Now in true Rpi fashion ive been keeping the costs down most of the kit im using is stuff i had lying around or kindly donated by friends.
Kit wise (so far)
RPi
7 port USB hub + Power adaptor
60Gb 2.5" HDD
HDD caddy
40+60mm fan (more on that later)
An LED
lots of cables
PCB Rails
Lian Li case feet
switches and connectors
Perspex
Mesh from an old speaker
Stripwood
I'm warning you now, im rubbish at most woodwork etc and this will be a slow build im working close to 50hrs a week.
Now, plans, i dont generally do them i have one in my head but i cannot use google sketchup and drawing annoys me.
Basic idea is a box with a clear top meshed sides wit ha fan at one end for airflow.
But moving on, been playing with the layout for a little while and ended up with a stacked design and made some basic measurements so today between the downpours i attacked the stripwood with a saw and ended up with this
Which nicely folds into this
All the bits piled in
The mass of space down one side is for the cables so, being so small i wont really have any proper cable management so this is the next best thing.
Next job is chop up the perspex to make a shelf for the USB hub and Rpi. The HDD will be sat in the bottom as the image above shows. Then work out where to put the connector holes. We have the power in, HDMI two USB ports and a pair of phono outs, the 5V in and a power switch.
The finish for the wood is something im not sure on yet either being soft pine it dents easily so ill have to find something to help with that, any ideas would be much appreciated though!
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW
legoman is offline   Reply With Quote
Old 30th Jun 2012, 19:38   #2
Squigly
MODfiend.. ~twitch~
Squigly's Avatar
Squigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the DremelSquigly has yet to learn the way of the Dremel
been waiting for a Pi build, will be following with interest, good luck!
Squigly is offline   Reply With Quote
Old 30th Jun 2012, 20:19   #3
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Your choice of building material seems massive.
Cheapskate is offline   Reply With Quote
Old 30th Jun 2012, 20:59   #4
dancingbear84
Ultramodder
dancingbear84's Avatar
dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.dancingbear84 is a hoopy frood who really knows where their towel is.
Looking good. I'm keen to see how this one ends up
__________________
Intel i5 2500k * Corsair H50 * 2 x Gkill Ripjaw Z 4gb * Asus Maximus V Gene * Evga 560Ti * OCZ Vertex 3 * 1 TB Samsung F2 * Antec Truepower 650* Fractal R3 * Win 7 Home Premium 64bit * LG 27" w2753vc
upgrade list:Blu-ray drive
It doesn't matter if you make a mistake, it only matters if you don't learn from it
dancingbear84 is online now   Reply With Quote
Old 30th Jun 2012, 21:08   #5
Meelobee
< Your add here >
Meelobee's Avatar
Meelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run CrysisMeelobee can run Crysis
Gotta love a build where a 2,5" disk is the biggest part
And I agree with Cheaps, the material choise for the casing seems a bit odd, it's so massive compared to the other parts.
Meelobee is offline   Reply With Quote
Old 30th Jun 2012, 21:51   #6
ninjaplease
I don't know what I'm doing
ninjaplease's Avatar
ninjaplease can run Crysisninjaplease can run Crysisninjaplease can run Crysisninjaplease can run Crysisninjaplease can run Crysisninjaplease can run Crysisninjaplease can run Crysisninjaplease can run Crysisninjaplease can run Crysis
Subscribed, I've had very similar ideas to this and with my pi arriving in 2 weeks, it'll be very good to see how you get on with it
__________________
i7 2600 | ASRock Z77E-ITX | Asus Radeon HD5670 | 8GB Corsair Vengeance 1600MHz | Samsung F4 2TB | 120GB Corsair Force 3 |
ninjaplease is offline   Reply With Quote
Old 30th Jun 2012, 23:26   #7
legoman
breaker of things
legoman's Avatar
Thanks guys im not 100% sold on it myself it was a lump i had lying around doing nothing its 15mm thick as well, I may be able to get some 6-10mm deep strips.
If icant find anything thinner i suppose at least it will be solid
__________________
Old 30th Jun 2012, 23:37   #8
Carrie
Weren't me guv
Carrie's Avatar
Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.Carrie is the Cheesecake. Relix smiles down upon them.
If you decide you want to downscale on the timber, I have some 9mm birch hardwood ply (cabinet quality S+/BB so no knots at all) I'll have spare from a build I'm currently planning if you'd like it.
__________________
MountainMods H2GO - the little case, i7-860, ROG Maximus III Forumla, 2 x 2gb GSkill Trident F3-1600 @ 2k, Coolermaster RS700-80GAD3-UK Silent Pro Gold 700W, Noctua NH-C14 dual fan, Gigabyte GeForce GTX 460 OC 1GB, 1 x 500GB Seagate 7200, Samsung 830 SSD, 500Gb WD, Samsung 12x B/ray, AeroCool F/C, E'max Apollish/Cluster fans.
Now building a scratch build HTPC
Carrie is offline   Reply With Quote
Old 1st Jul 2012, 10:26   #9
ninjaplease
Quick question, what was the USB hub you chose?
__________________
Old 1st Jul 2012, 12:11   #10
legoman
breaker of things
legoman's Avatar
thinner wood anyone?
6mm instead of 15mm. Carrie thanks for the offer i didnt see your message till after id got the wood
Ninja, it was according to its case it was in its a Belkin F4U018-BLK Its not on the list of supported devices but shares the same chips as the other Belkin 7 port hub so works perfectly
__________________
Old 1st Jul 2012, 18:43   #11
Cheapskate
Cheapskate's Avatar
That should solve the bulk issue. Sorry about that, but it seemed more like a RP bomb shelter.
Old 1st Jul 2012, 19:13   #12
slipperyskip
Seemingly Disinterested
slipperyskip's Avatar
slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.
My recommendation is to work on your I/O solution first and then work your way out from there. I'm not sure what you have in mind but using thick wood that doesn't end up interfering with plugging stuff into the ports is very tricky business. Good luck.
slipperyskip is offline   Reply With Quote
Old 2nd Jul 2012, 12:54   #13
legoman
breaker of things
legoman's Avatar
Not a problem cheaps, it was all i had available. I may use the 15mm on the base but for now ive left the wood to straighten .
Skip, already taken into account i will simply make a hole for the HDMI as the boss will be anchored on the PCB rails the power in and RCA outs on the back usb on the front and switch on top or the front. II think ill have to do a rough/rubbish sketch of the layout will make more sense. Can't do anything right right now as im at work.
__________________
Old 2nd Jul 2012, 13:32   #14
slipperyskip
OK. From my experience, the Ethernet port will be your biggest issue. Allowing room to work the latch on the connector is the thing that seems to bite everyone the first time (including me). A piece of wood (or acrylic) with a perfectly cut square for the Ethernet port won't work.
Old 2nd Jul 2012, 17:52   #15
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
Looking forward to this
__________________
Project Carbon Apple
whyte is offline   Reply With Quote
Old 5th Jul 2012, 20:10   #16
Dragonphreak
Multimodder
Dragonphreak has yet to learn the way of the Dremel
I can't wait to see your build. I've just gotten my RaspPi and I'm trying to figure out where I'm going to go with my build.
Dragonphreak is offline   Reply With Quote
Old 5th Jul 2012, 23:19   #17
legoman
breaker of things
legoman's Avatar
Thanks guys, ive hit a bit of a problem annoying problem in that the 6mm wood has decided to warp, not sure why its been laid down out of the light. Im trying slowly to re straighten it with some steaming but it slow work as im trying not to over wet the wood. To be honest its peeing me off royally i may resort to seeing if i can get some more 6mm wood and do it again if i dont get anywhere by the weekend.
slip, I decided against the Ethernet port mainly because i knew how hard it would be to make a suitable port for one. Also i have a diddy wifi dongle which will serve for the networking functions for now.
__________________
Old 6th Jul 2012, 02:05   #18
HybridCore
Multimodder
HybridCore's Avatar
HybridCore has yet to learn the way of the Dremel
First time I've seen a Pi case that's not built out of legos.
HybridCore is offline   Reply With Quote
Old 11th Jul 2012, 21:54   #19
legoman
breaker of things
legoman's Avatar
finally got some time to my self so thought id make some shorter cables.
This was a 1.8M Micro USB lead
spiral wraps there to help hold it in place at the moment, i chopped out the data lines as this is just going to power the Pi
Also did some terrible braiding for the audio cable, dont worry i put labels on the ends
Sorry about the quality im using the phone
__________________
Old 12th Jul 2012, 16:53   #20
Cheapskate
Cheapskate's Avatar
Wet lumber will warp if still wet and placed on a flat surface. The side on the ground can't dry, so the side facing up shrinks faster.
I'd store it clamped inside the bits of bigger lumber for a while.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
