Reply
Thread Tools View Mode
Old 12th Jul 2012, 18:20   #21
legoman
breaker of things
legoman's Avatar
legoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for presidentlegoman should be considered for president
Thanks cheaps, think ive sorted the worst of it now compressed them under two large bits of wood and about 40Kg of weights
amazingly its been sunny today so i decided to make use of it by doing a few bits
holes drilled and occupied, so two RCA outs, power switch and power in. Power in is a tad grubby but i will be able to clean it up.
Put the "layers" of the Pi in place
Base
Filling
Topping
The mesh is rubbish im looking for a suitable replacement now probably not mesh more along the lines of wood with holes in it or something i can remove easily so i can get to the SD card and hard drive.
wanted to get more done but lots of other work to do on the house etc so its had to wait. Though as its now raining i may be able to get some more little bits done on this.
__________________
AMD Phenom X6 1605T @ 4.5Ghz |Corsair H80 |Gigbyte970A-UD3 | 2X4 GB Kingston HyperX Beast | ASUS AMD 6950 2GB DirectCU II | Corsair HX750 | Liteon DVD RW | Samsung HD103SJ 1Tb | Crucial M4 SSD 64GB | Phobya FanMax 6 | Edimax EW-7612Pln | Coolermaster Storm Trooper | Win 7 Pro 64it | Roccat ARVO | Logitech G500 | Bamboo 1 | Samsung SyncMaster 2033SW
legoman is offline   Reply With Quote
Old 21st Sep 2012, 09:20   #22
legoman
breaker of things
legoman's Avatar
Well update and a total change in direction as the lumber was annoying me no end warping after i had straightened it.
Fortunately this shouldnt warp (bad photo thanks to the phone) Its an old CD-R drive case so its a hell of a lot smaller than what i was going to be using.
Also you can see theres no Hdd so binned it off in favour of a USB thumb drive. Uses less power, produces less heat and is nice and silent so currently no moving parts
had to wait a while for a HDMI Cable to come from Hong Kong. It was meant to be 15cm, its actually 30cm but for less than the cost of a pint im not going to argue
Offered it all up in the case and i have enough room.
May drop the USB hub size down to a four port jobbie as I dont need seven ports now!
Going to focus on the rear panel first as it will have the I/O and power in also working on getting a 2X16 line display working over GPIO, apparently the build i have of Raspian has configs pre built in. Just waiting on the components to trial this
__________________
Old 8th Nov 2012, 18:07   #23
Canardwc
Gentel-Mod'R
Canardwc's Avatar
Canardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the DremelCanardwc has yet to learn the way of the Dremel
Hey RaspMan, saw you mod a Pi too. Use you a remote? I looking for one for mine PiMod
Suscribed...
Canardwc is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
