Reply
Thread Tools View Mode
Old 8th Jul 2012, 18:49   #21
patara
life is wonderful
patara's Avatar
patara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremel
Originally Posted by Shurika View Post
Welcome to bit-tech! As I said earlier your project is very cool!
Так скоро сюда пол моддинг-форума переедет
Шурика СПАСИБО, the first layer of spackling is fixed and so
patara is offline   Reply With Quote
Old 8th Jul 2012, 23:54   #22
craig - toyoracer
Supermodder
craig - toyoracer's Avatar
craig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysiscraig - toyoracer can run Crysis
Now thats a mod. REally great work.
Sanding fiberglass in the kitchen, your wife is going to shoot you.
__________________
octTower
Electrocutous Orchid
craig - toyoracer is offline   Reply With Quote
Old 9th Jul 2012, 08:11   #23
patara
life is wonderful
patara's Avatar
I do work then when not a who is present at home
Old 12th Jul 2012, 23:21   #24
patara
life is wonderful
patara's Avatar
new photos
Old 13th Jul 2012, 01:15   #25
RebootTech
Budget? What Budget?
RebootTech's Avatar
RebootTech has yet to learn the way of the DremelRebootTech has yet to learn the way of the Dremel
Man, nice work! I love the color choice with the deep red/maroon and silver. Just awesome.
RebootTech is offline   Reply With Quote
Old 13th Jul 2012, 23:42   #26
patara
life is wonderful
patara's Avatar
pair of fresh photos
Old 14th Jul 2012, 16:53   #27
patara
life is wonderful
patara's Avatar
Old 20th Aug 2012, 23:53   #28
patara
life is wonderful
patara's Avatar
Old 25th Aug 2012, 08:35   #29
patara
life is wonderful
patara's Avatar
Old 26th Aug 2012, 17:35   #30
patara
life is wonderful
patara's Avatar
Old 28th Aug 2012, 12:05   #31
Fuganater
Supermodder
Fuganater's Avatar
Fuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run CrysisFuganater can run Crysis
Wow pretty epic mod!
__________________
-Fugatech-mods-
-Facebook-
Fuganater is offline   Reply With Quote
Old 30th Aug 2012, 21:32   #32
patara
life is wonderful
patara's Avatar
new photos are everything hello
Old 1st Sep 2012, 07:24   #33
patara
life is wonderful
patara's Avatar
all hello I continue work on the project
Old 2nd Sep 2012, 16:14   #34
patara
life is wonderful
patara's Avatar
Old 2nd Sep 2012, 16:38   #35
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!
Originally Posted by patara View Post
^^ this reminds me of:
Which is a painting I have in my living room.
I like it!
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 2nd Sep 2012, 16:43   #36
patara
life is wonderful
patara's Avatar
thank you, I like also
Old 3rd Sep 2012, 11:35   #37
patara
life is wonderful
patara's Avatar
Old 5th Sep 2012, 09:13   #38
patara
life is wonderful
patara's Avatar
all hello, finished box coloring, now it was necessary to put two varnish coats
Old 7th Sep 2012, 01:56   #39
patara
life is wonderful
patara's Avatar
decided also radiators to paint tone with the case
Old 7th Sep 2012, 11:55   #40
patara
life is wonderful
patara's Avatar
cut out a cliche after I will paint with white paint
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
