Old 4th Jan 2013, 02:11   #121
patara
life is wonderful
patara's Avatar
patara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremelpatara has yet to learn the way of the Dremel
and so I stopped to paint a pomp I put 2 pieces in a contour
__________________
patara is offline   Reply With Quote
Old 27th Jan 2013, 14:14   #122
patara
life is wonderful
patara's Avatar
I decided to do not big change of the project
while made a template on which it will be necessary to cut out,in plans platform replacement is a little new things
__________________
Old 27th Jan 2013, 14:47   #123
CombatMods
What's a Dremel?
CombatMods has yet to learn the way of the Dremel
That is an epic build....
CombatMods is offline   Reply With Quote
Old 9th Feb 2013, 22:10   #124
patara
life is wonderful
patara's Avatar
Thanks friend
Now I wanted to begin with sad news, the motherboard an asrok burned down, the company the producer completely declined all responsibility according to guarantee certificates, for itself drew a conclusion that an asrok a **** full, more in life I won't look towards purchase of this producer, the company not serious, on replacement bought motherboard ASUS and now will be only ASUS, soon I will continue to finish work on the case
__________________
Old 9th Feb 2013, 22:53   #125
patara
life is wonderful
patara's Avatar
__________________
Old 17th Feb 2013, 18:17   #126
bugaga1100
What's a Dremel?
bugaga1100 has yet to learn the way of the Dremel
Hi, Patara
I still following your project and I wish everyone else
Where are updates!??
bugaga1100 is offline   Reply With Quote
Old 18th Feb 2013, 20:53   #127
patara
life is wonderful
patara's Avatar
Originally Posted by bugaga1100 View Post
Hi, Patara
Hello, as soon as there will arrive the order from Overhard, will continue assembly, it will be necessary to look in a place distance of a fitting, work on proceeds, recoloured the lower part pomp, tops will be others, decided not to put tanks
__________________
Old 9th Mar 2013, 15:52   #128
patara
life is wonderful
patara's Avatar
it isn't a lot of updating : Naughty:
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
