Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Jul 2012, 08:06   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Joystick reviews: Cyborg FLY 5 vs Thrustmaster T-Flight Hotas X
We put two of the best 30 joysticks head to head to see which you should buy...
http://www.bit-tech.net/hardware/per...flight-hotas/1
brumgrunt is offline   Reply With Quote
Old 4th Jul 2012, 09:26   #2
scott_chegg
Hypermodder
scott_chegg's Avatar
scott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on you
Bought the FLY 5 specifically for flying in BF3. It's great. A hint is to remove all the controls for the stick from within BF3 for flying and use the cyborg software to map the different controls from the stick to the relevant keys on the keyboard. You just have to be aware that when you bail out of a flaming jet make sure you return the throttle back to the middle position.
__________________
My System: i5 2500K @ 4.7Ghz | MSI P67A-GD65 (B3) | 16GB Crucial Ballistix Sport 1600MHz | Corsair H-50 Push-Pull with Silent Eagle 2000's | Silverstone Raven RV03 | EVGA 670 FTW | Dell SP2309W | Antec 750W TruePower Blue | Win 7 x64 | Crucial 64GB C300 for OS | Samsung 830 256GB for Active Games & a 1TB Samsung for Steam. Perphiperals: Roccat Kone+ Max V2 | CMStorm Quickfire Pro with Cherry Reds | Cyborg F.L.Y 5 stick for flying and a Logitech DF GT for driving.
scott_chegg is offline   Reply With Quote
Old 4th Jul 2012, 09:56   #3
Redsnake77
Useless Idiot
Redsnake77 has yet to learn the way of the Dremel
You really need to test these over several months. Because if the build quality of the FLY 5 is anything like the V1, you'll be asking for a replacement inside a year. It's a pity they stopped Saitek making the lower end sticks like the ST290 pro. My original ST290 Pro lasted over 5 years being used every day, until it started to feel a bit too sloppy. I bought a V1 as, like I said, they had stopped making budget Saitek sticks. The first V1 lasted less than six months before it completely failed, and second lasted another nine before deadzones started drifting and buttons started double clicking. I have just purchased a lightly used second hand ST290 pro, because even if it only last two years, it will have done better than the V1's did combined.
__________________
i5 6600K, Asus Maximus VIII Hero, Corsair Vengeance LPX 16GB 2666mhz (2x8GB), Palit GeForce GTX 1080 GameRock Premium Edition
Patriot Torch LE 960GB, Corsair HX850i, Corsair H100i
Toshiba E300 2TB, Asus ROG Swift Pg348q, Win 10 Pro 64-BIT
Last edited by Redsnake77; 4th Jul 2012 at 10:00. Reason: because I'm a waist of pace
Redsnake77 is offline   Reply With Quote
Old 4th Jul 2012, 10:17   #4
Cerberus90
I Mod, Therefore I Own
Cerberus90's Avatar
Cerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming SaiyanCerberus90 is a Super Spamming Saiyan
My original Cyborg has broken too. The left right twist in the handle (for rudder etc) either doesn't pick up the movement, or gets stuck at full right.
Tried taking it apart and cleaning everything, still broken.
I think it was just after two years too, and it hadn't had much use either, I noticed it was broken after getting it down off the shelf after probably 6 months of sitting there, and it was duff.
__________________
Steam: Cerberus90
| i3-4160 3.6GHz | MSI Z97S SLI Krait | 16GiB HyperX Fury 1866 |256GB Samsung 830 |
| Strix GTX980 WC'd | Thermaltake Armor |
Cerberus90 is offline   Reply With Quote
Old 4th Jul 2012, 10:25   #5
rpsgc
Multimodder
rpsgc's Avatar
rpsgc has yet to learn the way of the Dremel
Thanks for reminding me I can lock the yaw axis on the T-Flight Hotas X.
rpsgc is offline   Reply With Quote
Old 4th Jul 2012, 11:41   #6
mclean007
Officious Bystander
mclean007's Avatar
mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.mclean007 is the Cheesecake. Relix smiles down upon them.
Nice article, but the new advertising on bit-tech is infuriating - that flash video for "The Secret World" expands up and down, which shifts the text of the article with it. I have no objection to ads on bit-tech (I know that's how you guys get paid, and I want you to keep producing top quality content!), but, much like those awful inline ads that popped up if you hovered over a highlighted word, the new ads are obtrusive and make it a chore to navigate around the site. Please remove them, or I'll have to resort to removing bit-tech from my adblock whitelists.
__________________
mclean007 is offline   Reply With Quote
Old 4th Jul 2012, 13:01   #7
D B
Supermodder
D B's Avatar
D B has yet to learn the way of the Dremel
Looks like I'll be getting the X to replace my old Thrustmaster Afterburner Force Feedback stick , after years of use (IL2) it has a dead spot in the stck movement ... too bad I really liked it
I second restricting the flash ads ... It's anoying as all heck to have an ad pushing it's self over everything
__________________
You keep those pink gloves up & swinging, Kimber
Think Pink Scuba
D B is offline   Reply With Quote
Old 4th Jul 2012, 14:50   #8
Crunch77
Modder
Crunch77 has yet to learn the way of the Dremel
The main reason for the Hotas X being able to separate the throttle from the stick is not to more easily hide it away, but rather to get a more authentic feel with a greater distance between the two, rather than small fiddly throttles attached to the stick, as seen on many small flightsticks.
"The T-Flight Hotas X is can be partially dismantled - just as well as it's a big lump to try and hide away in a cupboard. The throttle section detaches from the rest of the joystick, but isn't completely separable"
Crunch77 is offline   Reply With Quote
Old 4th Jul 2012, 14:58   #9
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.fdbh96 is the Cheesecake. Relix smiles down upon them.
Bit unfair to ask them to test them for several months, as while that does indicate build quality, I think its more important to have a review sooner.
fdbh96 is offline   Reply With Quote
Old 4th Jul 2012, 15:02   #10
rpsgc
Multimodder
rpsgc's Avatar
How is asking them to keep using them "over several months" after the review is done, unfair?
Old 4th Jul 2012, 15:42   #11
McVittees
What's a Dremel?
McVittees has yet to learn the way of the Dremel
Tried to read article but got dizzy from it slidding up and down...I will not be the Secret World.
McVittees is offline   Reply With Quote
Old 4th Jul 2012, 15:44   #12
McVittees
What's a Dremel?
Buying...meant buying the Secret World...oh god the page is moving by itself again... :-(
Old 4th Jul 2012, 16:45   #13
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
These things are completely impractical to use as sold, the damn things are never heavy to stop them sliding all over your desk when in the middle of a dog fight for a start, and are too uncomfortable to use with both hands holding them.
Do you guys make custom mounts for them or something, placed at the right height and angle and locked into some sort of rigged up 'locking' base?
Hustler is offline   Reply With Quote
Old 4th Jul 2012, 16:52   #14
rpsgc
Multimodder
rpsgc's Avatar
Are you talking about the T-Flight Hotas X?
If so, either your desk is made of ice or you play like an angry badger.
Old 4th Jul 2012, 18:06   #15
Redsnake77
Useless Idiot
Blu-Tac
Old 4th Jul 2012, 19:39   #16
SaNdCrAwLeR
Multimodder
SaNdCrAwLeR has yet to learn the way of the Dremel
these should be tested on a proper joystick game...
Starlancer
SaNdCrAwLeR is offline   Reply With Quote
Old 5th Jul 2012, 13:29   #17
Dr Dark
Minimodder
Dr Dark has yet to learn the way of the Dremel
+250 on the annoying advertage....
On the subj of sticks, I'm using my olde worlde X35f and x35t.. still work great, even though the rubberised feel has kinda gone tack... they take up a huge amount of real estate but are so solid I won't change em!
...and using a serial to usb adapter makes it easy (had to get a double serial port thing back in the days)
Bargain, picked up the pair for 35.00 in Virgin Birmingham in the dark ages!
__________________
Proud to be part of Virtual Normality
If it works... mod it.... if it stops working - mod it with a hammer till it works... and repeat......
Dr Dark is offline   Reply With Quote
Old 5th Jul 2012, 17:36   #18
MachineUK
Minimodder
MachineUK has yet to learn the way of the Dremel
Starlancer
Star lancer......what a great game!!
and Redsnake, I remember using blu-tac on a zip stick back in the sensible soccer days!!! :-)
Truth for me is that since the wing commander, star lancer and free lancer games came out. Nothing has inspired me to buy a joystick.
__________________
The truth shall set you free......
MachineUK is offline   Reply With Quote
Old 6th Jul 2012, 00:13   #19
Scootiep
Multimodder
Scootiep has yet to learn the way of the DremelScootiep has yet to learn the way of the Dremel
Oh Lucas Arts, what do I have to do to convince you that "Fly by Wire" does NOT constitute anything remotely close to a good flight simulator! FOREVER BURN IN HELL! And then revisit the X-Wing/Tie Fighter series as redemption...with gusto.
__________________
"Out of order?!? F&$% Even in the future nothing works!" - Dark Helmet
Scootiep is offline   Reply With Quote
Old 6th Jul 2012, 00:14   #20
Scootiep
Multimodder
Starlancer
Oh man, that takes me back. I remember loosing hours of study time in college with the other 4 guys in my apartment. Really fun game. Wish they had expanded on it.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
