Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 4th Jul 2012, 21:25   #1
Angel OD
Pump Killer
Angel OD's Avatar
Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!Angel OD - it's over 9000!!!!!!!!1!1!1!!!
Can't install OS on ssd. - Fixed!
I have an Acer Aspire 5520g, with the NVIDIA nForce 610M (MCP67-MV) chipset.
I decided to give it a boost so I bought a Vertex2 60gb ssd.
The problem is that I can't install XP nor WIN7 on it. It gives errors on both installations.
When installing XP I go through the partition and format. Then I get the error: "Windows could not start because of a computer disk hardware configuration problem"
When trying to install WIN7, I get to the partition tool and it just denies to continue as it can't use the disc. (can't remember the exact error message)
When entering BIOS, I see the Vertex fine.
Any ideas?
__________________
It's NOT a mac... http://forums.bit-tech.net/showthread.php?t=139635 - Motm nominee
WII - UNLimited Edition http://forums.bit-tech.net/showthread.php?t=179763 - Moty nominee
Liquid Cooled CarPC - Sponsored by Mushkin Enhanced & Centrafuse
http://forums.bit-tech.net/showthread.php?t=207889 - Motm nominee
The Theory of Everything http://forums.bit-tech.net/showthread.php?t=219504 - Motm WINNER!
Angel OD is offline   Reply With Quote
Old 4th Jul 2012, 21:36   #2
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
well first and foremost does your board support the SSD in question most laptops only support a limited number of SSDs
be on Acer forum some place.
http://www.tomsguide.com/us/netbook-...view-1481.html
my suggestion is you give this a read its for a netbook but it relates to an Acer mobo and id bet they are not that much dif
rollo is offline   Reply With Quote
Old 4th Jul 2012, 21:39   #3
dancingbear84
error 404
dancingbear84's Avatar
dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.dancingbear84 is definitely a rep cheat.
Is it a sata driver issue perhaps? I have had that in XP but not Win 7 yet?
__________________
It doesn't matter if you make a mistake, it only matters if you don't learn from it
dancingbear84 is offline   Reply With Quote
Old 4th Jul 2012, 21:43   #4
teppic
Ultramodder
teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.teppic is definitely a rep cheat.
XP doesn't support SATA configured for AHCI natively, but Windows 7 has no problems. This isn't the issue though because XP simply won't see the disk at all.
It sounds like a hardware incompatibility or a faulty drive. Can you test it on anything else?
__________________
i7 4770K | Gigabyte Z87X-UD4H | 16gb Corsair Vengeance | Samsung 830 256gb
Asus DirectCU II GTX 670 OC | Be Quiet! Dark Rock Pro 2 | Seasonic 760w | Fractal Design Define R3
teppic is offline   Reply With Quote
Old 5th Jul 2012, 09:13   #5
Angel OD
Pump Killer
Angel OD's Avatar
I've searched high and low, and I can't seem to find out.
I'll get reading on that guide, it looks like a good place to start no matter what.
Don't know. I tried finding a sata driver and thought I had found it, but I can't read the driver from a usb when I f6...
I'll see what I can do! I'll try it on another laptop, which is also a bit old. If that doesn't work, I can always give it a go on my gamer pc.
Thanks for the advice guys. I'll post back when I get further later today!
__________________
Old 5th Jul 2012, 09:28   #6
lysaer
Suck my unit! Kirk lazarus (2008)
lysaer's Avatar
lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.lysaer is definitely a rep cheat.
Could also try a bios update as well and if you can set the sata ports to IDE as opposed to AHCI
Sent from my HTC Sensation XE with Beats Audio using Tapatalk 2
lysaer is offline   Reply With Quote
Old 5th Jul 2012, 10:02   #7
badders
Neuken in de Keuken
badders's Avatar
badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.
You need a floppy drive if I recall correctly - XP won't read the driver off a USB stick.
I don't know if you can use a USB floppy, though I think that's the only option you'll have?
__________________
Originally Posted by Silver51 View Post
John Hanlon standing on an oil pipeline during a blizzard, punching an angry polar bear in the balls. I heard he really did that once.
badders is offline   Reply With Quote
Old 5th Jul 2012, 10:08   #8
Angel OD
Pump Killer
Angel OD's Avatar
I actually did a bios update. Latest "normal" version, not a modded bios.
Saw no change or any more options in bios after the flash. And I can't even change AHCI in there.
I kind of thought that as well. We have one at work I can take home, I might give that a try as well.
__________________
Old 5th Jul 2012, 16:34   #9
Angel OD
Pump Killer
Angel OD's Avatar
Well I'll be damned!
I flashed the bios from v1.03 to v1.31 yesterday.
I took the drive and put it in my gamer rig, and deleted the partition.
Then I put it back in the laptop, and started installing win7. It asked about making a partition, and said it might make a 100mb partition as well, and now it seems like it's installing. (Fingers Crossed)
If it works, I'll try putting xp on the same way later! I'll keep you updated!
__________________
Old 8th Jul 2012, 17:31   #10
Angel OD
Pump Killer
Angel OD's Avatar
Sooo... It was no problem installing WIN7 on the ssd. Good news!
Bad news; No audio at all. It won't even see the hardware.
I know this is a problem among many people going with WIN7 on this and other laptops. I've tried every driver available online, and still nothing.
The closest I get is a code 10 if I try to force what I think is the audio hardware.
I bought an external usb audio device, but that won't give me sound from the laptop speakers... Any ideas out there?
If I change the hdd to the one with XP on, it works perfectly. So it's not the hardware that is corrupt.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
