Go Back   bit-tech.net Forums > Recreation > Gaming
Reply
Thread Tools
Old 9th Jul 2012, 09:51   #1
BLC
ARM Evangelist
BLC's Avatar
BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.BLC is a hoopy frood who really knows where their towel is.
Minecraft: YogCraft Server
Hey all
We have now migrated to YogCraft (part of Feed The Beast). You'll need the FTB Launcher in order to connect. PvP is still enabled, but there are now protection plugins installed.
As before, this is a private server, and the same conditions as the old Tekkit server apply: PM me your minecraft username to get access. I'm not likely to accept requests from people who have signed up very recently; this server is for the bit-tech community, it's not a free-for-all.
The whitelist from the tekkit server has been moved across; if you were already granted access then you don't need to do anything else.
Server Address: minecraft.yanoti.co.uk (in case the DNS changes haven't propagated yet, the IP is 5.45.180.66)
Plugins:
  • CommandBook
  • DeadMansChest
  • PermissionsEx
  • Residence
  • StarterKit
  • WorldEdit (max. area 256x256x256)
People who used the Tekkit server may remember this, but please see instructions here for creating protected areas in Residence. Don't forget to use "/res select vert" before creating your residence! The selection tool has been changed to a stick to avoid conflicts with WorldEdit.
IMPORTANT: Forestry uses a "fake player" in order for multifarms to work properly. By default the "build" flag for Residence is set to false - this prevents multifarms from properly planting crops (I noticed it with wheat/seeds, but saplings seemed to be OK). If you want a multifarm to work properly in your Residence zone you must set the "build" flag to true - this will allow other players to build/break blocks on your land however...
Commands Available:
  • /who
  • /motd
  • /intro
  • /rules
  • /time
  • /return
  • /home
  • /sethome
  • /warp
  • /warps
  • /say
  • /reply
  • /afk
  • /whereami
  • /getpos
Please note that many of these commands have aliases; please see the CommandBook Wiki for more info. You will only have access to the commands specified above, however.
Starter Kits:
New players will automatically receive a starter kit when logging in to the server; the contents are as follows:
  • 64x Stone
  • 64x Dirt
  • 64x Oak Wood Logs
  • 128x Oak Wood Planks
  • 64x Red Brick Blocks
  • 64x Stone Bricks
  • 64x White Wool
  • 8x Chest
  • 64x Glass Block
  • 32x Glass Pane
  • 32x Iron Ingot
  • 32x Copper Ingot
  • 32x Tin Ingot
  • 16x Bronze Ingot
  • 8x Gold Ingot
  • 8x Red Alloy Ingot
  • 8x Blue Alloy Ingot
  • 8x Brass Ingot
  • 64x Rubber
  • 32x Coal
  • 1x Iron Sword
  • 1x Iron Axe
  • 1x Iron Spade
  • 1x Iron Pickaxe
  • 64x Torches
  • 64x Apples
  • 1x Complete set of Iron Armour
__________________
What's that? You don't care about my site? I don't care that you don't care - I'm going to spam you with the link anyway.
Why yes, I do have a YouTube channel on which I put out Minecraft videos on a somewhat "regular" basis, thank you for asking.
BLC is offline   Reply With Quote
Old 9th Jul 2012, 12:04   #2
mat0tam
Mr I Dont Know What I Want
mat0tam's Avatar
mat0tam has yet to learn the way of the Dremelmat0tam has yet to learn the way of the Dremelmat0tam has yet to learn the way of the Dremel
Hi BLC,
YGPM
__________________
i5 2500K l P8Z68-V LX l 6870 l 8GB 1600MHz l OCZ Vertex 3 l 750W OCZ
Giff Gaff Monthly Sim Card - £10 a Month, 250Min, Unlimited Data and Text.
mat0tam is offline   Reply With Quote
Old 9th Jul 2012, 14:32   #3
JrRRr
Minecraft addict
JrRRr's Avatar
JrRRr has yet to learn the way of the Dremel
Thanks for the initiative! I was wondering, what are the requirements client-side? Do I have to download the Tekkit-mod or something?
I did get to "Technic Pack"-homepage and downloaded the launcher EXE. What that gave me, was a user interface that had all the blocks ready for my usage, but I don't want to cheat, is there some way to disable this?
Oh, and you got a PM..
__________________
So yeah, my english is not the best. In other words; please be patient with my grammar and other non standard way of writing things..
JrRRr76 on Minecraft..
JrRRr_nor on Steam
JrRRr is offline   Reply With Quote
Old 9th Jul 2012, 15:13   #4
BLC
ARM Evangelist
BLC's Avatar
That's the "Not Enough Items" mod, an extension of "Too Many Items". If you don't have operator/admin permissions in multiplayer, you can't use it to "give" yourself items though. I'm not sure if it's possible to disable it; it might be possible, but I have no idea whether the client-side mods for tekkit are stored in multiple jar files or whether they're all merged into one main jar file.
What it does do however is show you the crafting recipe for each block/item when you click on it, and allow you to search for specific blocks/items. If you did have operator permission though (or were using it in singleplayer), then you'd see a bunch of extra options for setting the time of day, turning on creative mode (for you only), changing the weather, etc.
__________________
Old 9th Jul 2012, 17:04   #5
JrRRr
Minecraft addict
JrRRr's Avatar
Hey, thanks for the info.. ..I'm now a fraction more enlightened than just two minutes ago..
The "recepies"-function will come in handy - saves a lot of alt-tab'ing to the wiki..
__________________
JrRRr_nor on Steam
Old 9th Jul 2012, 17:10   #6
JrRRr
Minecraft addict
JrRRr's Avatar
The Dynmap is fine the way it is.. - good that the Server has more resources focusing on the game, rather than the dynmap!
__________________
JrRRr_nor on Steam
Old 9th Jul 2012, 18:11   #7
BLC
ARM Evangelist
BLC's Avatar
Sorry, I kinda forgot to answer your first question...! You do need the technic pack; select Tekkit from the drop down on the main menu. It keeps everything separate from your regular minecraft client though, and doesn't modify your normal minecraft.jar file.
__________________
Old 9th Jul 2012, 18:21   #8
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for presidentBloody_Pete should be considered for president
Liking my land clearence?
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Sapphire Radeon HD 5870, 128GB Crucial M4, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 9th Jul 2012, 18:42   #9
deathtaker27
System Support Specialist
deathtaker27's Avatar
deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.deathtaker27 is the Cheesecake. Relix smiles down upon them.
Just a warning to you guys, I am running 2 servers on separate systems and they are very Memory intensive, also when you start using things such as quarrys to get your items you may find some serious issues with stability and lag due to the number of item objects there are
__________________
If someone has helped you remember to + Rep them (:
deathtaker27 is online now   Reply With Quote
Old 9th Jul 2012, 19:39   #10
BLC
ARM Evangelist
BLC's Avatar
Yes, I think I'm already seeing lag issues due to memory. I know one person is having issues connecting, which could be related. Going to look into an upgrade ASAP.
EDIT: Apologies if anyone is having any issues due to server capacity...
__________________
Old 10th Jul 2012, 05:02   #11
Malvolio
Keep calm and canter on.
Malvolio's Avatar
Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.Malvolio is a hoopy frood who really knows where their towel is.
From what I've read, for a vanilla SMP server for a single world with 25-odd people, you should expect to dedicate about 3 gig's of RAM for a smooth experience. I can only imagine that Tekkit would be even worse of a memory hog due to automation.
__________________
MC and Ellie FIX it!
It's a comic I do. With dolls.
Occasionally it's funny.
Malvolio is online now   Reply With Quote
Old 10th Jul 2012, 06:15   #12
Bloody_Pete
On my server, when it was just me and a couple of mates mine used about 1.5GB of RAM usually...
__________________
Old 10th Jul 2012, 12:02   #13
BLC
ARM Evangelist
BLC's Avatar
I've just posted this in the server also, but don't be alarmed if you are booted unexpectedly or the server becomes unreachable this afternoon. I'm requesting a memory upgrade for the server, and the SLA is 2-4 hours to complete the upgrade. I'll post back here when it's been completed.
With three users logged on, the memory usage hit 100% and it's been pegged there ever since... With bukkit (and plenty of plugins), I rarely hit 60% usage with up to 8 concurrent users. Tekkit does seem to be a server killer.
Edit: Because I'm paying for this myself, I don't really want to keep ramping up the server capacity unless it's warranted. Once the upgrade is complete I will be restricting the number of player slots to 16 to try and keep things running smoothly for everyone; I noticed some really bad lag last night, and was killed by creepers several times because of it.
If there's enough demand however, I will review the capacity at a later date.
__________________
Old 10th Jul 2012, 12:22   #14
BLC
ARM Evangelist
BLC's Avatar
Updated and cleaned up the first post... I like walls of text, but that doesn't mean that everyone else does
__________________
Old 10th Jul 2012, 12:25   #15
Votick
CHMOD bit-tech 777
Votick's Avatar
Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.
If memory is an issue I can stick on up on the same server as the survival.
8gb of ram to play with on it.
EDIT: in fact the host is using 18/24GB so i could possible throw more ram at it.
__________________
| AMD FX 8350 @ 4.0GHZ | Gigabyte GA-990FXA-UD5 | 16GB Corsair Vengeance DDR3 1600mhz |
| Corsair Force 3 120GB SSD X 2 RAID0| Corsair H100 | Samsung F3 1TB HDD | MSI GeForce GTX 680 SLI |
| Silverstone 1200W | Corsair 650D | LG IPS225V X 2 |
Votick is offline   Reply With Quote
Old 10th Jul 2012, 12:32   #16
BLC
ARM Evangelist
BLC's Avatar
I'll PM you. I've got a meeting shortly which will consume the rest of my afternoon, so if I don't get chance before then it'll be when I get home.
__________________
Old 10th Jul 2012, 19:25   #17
mat0tam
mat0tam's Avatar
Hi BLC, just a note on your to do list - Lockable chests can be removed as personal safes are already an in game item
__________________
Old 10th Jul 2012, 19:26   #18
BLC
ARM Evangelist
BLC's Avatar
...Well bugger me, so they are! http://thetekkit.wikia.com/wiki/Personal_Safe
One less plugin to clog up the place then...
__________________
Old 11th Jul 2012, 05:38   #19
BLC
ARM Evangelist
BLC's Avatar
Forgot to post this yesterday. The RAM upgrade has been completed.
__________________
Old 11th Jul 2012, 10:25   #20
JrRRr
Minecraft addict
JrRRr's Avatar
sounds good. The only problem I can see, is that MrsFio and I share chests, with LWC you can solve that whith the /cmodify command. But is this possible with Personal Safe?
..or we could simply trust each other..
__________________
JrRRr_nor on Steam
Reply
Tags
block, easily broken, even more lost time, hadron collider = bad!, minecraft, tekkit, what is a social life?, who needs a social life
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
