Reply
Thread Tools View Mode
Old 11th Jul 2012, 18:02   #1
Vandalo
Minimodder
Vandalo has yet to learn the way of the Dremel
Cosmos II "Vista"
Hello guys,
I wanted to show you my new project, I want to fun with a Cosmos II.
The work will be long and consists of a liquid cooling system that will handle all the cool components with a dual loop (loop classics separate CPU and VGA).
I will try to take some unusual solutions for component placement... lately I like to venture in this direction so I need your valuable advice and your support.
First of all I thanks to Cooler Master Italia for giving me kindly offered a Cosmos II case and a Silent Pro Hybrid PSU from 1300W.
Ah... sorry for my english
In a case of this size we would expect a MB large format with all that space available and instead I will use a mATX, an Asus Maximus V Gene.
The choice fell on this MB because I like a lot, but mainly because it is small just for keep two radiators. A loop with a 4x120 radiator for VGA and a loop with a 3x120 radiator for CPU/RAM.
The two loops will handle with two aquaero, then two loop totally independent.
To make room for the radiator, I move the PSU from his seat and I'm going to put on the front of the case ... what I've done on my TJ07 and for me this is a winning choice.
I started to remove "some" rivet
To insert a radiator from 480 in the bottom of the case, the psu must be moved. I could just put it next to the radiator in TJ07 style, but I never liked as solution... where can I prefer move to optimize the performance of system, and in this case I could.
The psu will be fixed directly on the sheet metal of the case instead of big fan that CM has provided to cool the HD. To do this I have prepared some 2 mm steel plates to fit the holes of the psu to the case.
See you soon for other photo.
Bye guys.
Vandalo is online now   Reply With Quote
Old 11th Jul 2012, 20:27   #2
krussellusaf
Modder
krussellusaf has yet to learn the way of the Dremel
It's got a lot of potential. I can't wait to see more.
krussellusaf is offline   Reply With Quote
Old 12th Jul 2012, 12:13   #3
Vandalo
Minimodder
I'm very glad that you like
Ok guys... today I put the power in his new position.
After I took the measurements for the holes I started to drill the sheet metal of the case.
Bye guys...
Old 12th Jul 2012, 12:26   #4
GamerIDGoesHere
Hi
GamerIDGoesHere's Avatar
GamerIDGoesHere has yet to learn the way of the Dremel
I like what you did with the PSU and this mod has HEAPS of potential, keep on updating!
I subbed too
- Dan
GamerIDGoesHere is offline   Reply With Quote
Old 12th Jul 2012, 12:37   #5
Dave2010_TA
Multimodder
Dave2010_TA's Avatar
Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!Dave2010_TA - it's over 9000!!!!!!!!1!1!1!!!
Hi Vandalo!!! Nice to see you there!!! Show us what you got!!!
Dave2010_TA is offline   Reply With Quote
Old 12th Jul 2012, 16:54   #6
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
Dude.. the psu mount is awesome. Excited to see whats coming
__________________
Project Carbon Apple
whyte is offline   Reply With Quote
Old 14th Jul 2012, 15:10   #7
Dagored
What's a Dremel?
Dagored's Avatar
Dagored has yet to learn the way of the Dremel
After the fantastic work on the TJ07, I can not miss this thread!
We're just beginning and already I see great things.
I follow Vandalo!
Dagored is offline   Reply With Quote
Old 14th Jul 2012, 17:38   #8
Owndapwn
Modder
Owndapwn's Avatar
Owndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run CrysisOwndapwn can run Crysis
I'd be careful with the PSU as it is. You'll be fighting convection (heat rises) when exhausting, and you'll be putting warmed air in the case.
If you reverse the PSU fan (Change polarity), then it won't be an issue (Unless it makes noise), but as it is right now, your PSU will always be warmer than a PSU with the traditional orientation.
Owndapwn is offline   Reply With Quote
Old 14th Jul 2012, 20:31   #9
Vandalo
Minimodder
I subbed too
- Dan
oh thanks Dan
Hi Dave... yesss but I need some time
Thanks whyte
I follow Vandalo!
Ciao Dago
thanks... more photos in a few days.
Old 14th Jul 2012, 20:42   #10
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Awesome PSU mount
Mankz is offline   Reply With Quote
Old 16th Jul 2012, 11:49   #11
Dot_Kappa
100% Puppet
Dot_Kappa's Avatar
Dot_Kappa has yet to learn the way of the Dremel
Subscribed!
I' am waiting for the next step
__________________
|||||| Modder Supercharged
Dot_Kappa is offline   Reply With Quote
Old 16th Jul 2012, 13:00   #12
Vetalar
*learning english*
Vetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the DremelVetalar has yet to learn the way of the Dremel
^^ i'm with this man ^^
i can't figure out any reason to pump warm air in the case... with current PSU placement i see only one way out: place PSU fan to blow air _out_ of the PSU... just my $0.02
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 16th Jul 2012, 18:46   #13
Vandalo
Minimodder
Originally Posted by Mankz View Post
Awesome PSU mount
Thanks Mankz
Originally Posted by Dot_Kappa View Post
Subscribed!
Hi Kappa thanks, to soon with some news.
For Owndapwn and Vetalar.
I could open the power supply to turn the fan to reverse the flow of air, suction from inside to push it off the front of the case... or I could leave the power supply fan in a conventional way but direct hot air under the case.
But I like to reverse the fan.
In the case not remain hot air.
Old 16th Jul 2012, 20:28   #14
Owndapwn
Modder
Owndapwn's Avatar
So you do have a plan for the PSU?
There are a couple ways you could fix it, but the best would be to either put the PSU where it was originally or to reverse the fan.
Old 16th Jul 2012, 20:49   #15
p0Pe
gief cake?
p0Pe's Avatar
p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!p0Pe - it's over 9000!!!!!!!!1!1!1!!!
That PSU mounts is just brilliant!
I will keep an eye on this
__________________
p0Pe is offline   Reply With Quote
Old 17th Jul 2012, 18:47   #16
Vandalo
Minimodder
I think I'll choose the easy way out, I will reverse the fan.
thanks p0Pe
Old 18th Jul 2012, 06:25   #17
Lehani
Multimodder
Lehani's Avatar
Lehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the Dremel
I have thought about buying this case myself following for some ideas
you started out pretty neat
Lehani is offline   Reply With Quote
Old 19th Jul 2012, 14:43   #18
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Wow nice build.
The Cosmos II has so much potential but I lack skill to mod mine.
Subscribed though to see how this turns out because it's looking like it will be amazing.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is online now   Reply With Quote
Old 19th Jul 2012, 19:29   #19
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for presidentmnpctech should be considered for president
Off to great start, agree about PSU location, pretty slick idea... I look forward to seeing the ending results
mnpctech is offline   Reply With Quote
Old 21st Jul 2012, 17:55   #20
Vandalo
Minimodder
Originally Posted by damien c View Post
Wow nice build.
Thanks guys, I'm very happy of your words
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
