Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Jul 2012, 08:06   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Be Quiet! Dark Rock Pro 2 review
Be Quiet has launched a new range of coolers. We take a look at the biggest.
http://www.bit-tech.net/hardware/coo...pro-2-review/1
brumgrunt is offline   Reply With Quote
Old 12th Jul 2012, 10:35   #2
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
What I don't understand is why so much heat is held in by the 'heat pipes'. I mean there can't be much difference in the actual contact blocks of air coolers and closed unit water coolers, nor with the fans used. The radiator fins are usually a lot smaller on a water cooler so why is so much more heat being transferred by the liquid than the heat pipes?
__________________
SchizoFrog is offline   Reply With Quote
Old 12th Jul 2012, 11:34   #3
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
I think it's to do with the specific heat capacity of water being lower (or maybe higher? can't remember) than air - or that water is a better conductor of heat rather than the fins / heat pipes etc.
GeorgeK is offline   Reply With Quote
Old 12th Jul 2012, 12:01   #4
tad2008
Supermodder
tad2008 has yet to learn the way of the Dremel
Article Quote: "it was still far quieter than our graphics card - in fact we had to momentarily stop our case and graphics card fans to actually gauge the Dark Rock Pro 2's fan noise at all"
BitTech why aren't you using quiet case fans and a graphics card with a quiet cooler or even one of the passively cooled ones for tests like this? Surely that would be a far more subjective test overall?
tad2008 is offline   Reply With Quote
Old 12th Jul 2012, 13:02   #5
Petrol head
Modder
Petrol head's Avatar
Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!Petrol head - it's over 9000!!!!!!!!1!1!1!!!
With air coolers you are relient on the hot air in the pipes to rise to the cooler. With water cooling the pump moves the water round meaning greater capacity to take the heat away. Not much difference to car cooling system really.
__________________
2500K at 4.5GHz MSI Z68A-GD55 8G of Corsair Vengance 256GB Samsung 830 Seagate 1TB MSI GTX670 Power Edition Antec 1200 case. Never peaks more than 45 degrees
That took me a lot of saving with a wife and 4 young boys!!
Petrol head is offline   Reply With Quote
Old 12th Jul 2012, 14:11   #6
SchizoFrog
I *am* a Dremel
Yeah that would make sense. Didn't think of forced heat exchange rather than a thermal one.
__________________
Old 12th Jul 2012, 14:30   #7
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
We spent a fair amount of time tuning the systems to be able to obtain some useful results with overclocked hardware. While passively-cooled graphics cards and low-cfm fans will allow for a quieter system, emphasising the noise the CPU cooler makes, these machines are run flat out for hours on end and get quite toasty as a result, even as they are. In our experience, this would simply lead to more frequent hardware failure - something that isn't workable with a test system like this. Our LGA2011 system in particular needed an additional case fan just to keep the motherboard cool and stop it throttling the CPU.
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 12th Jul 2012, 16:59   #8
dolphie
Banned
dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.dolphie is a hoopy frood who really knows where their towel is.
I still feel a bit uneasy about the quality of the all in one water coolers, so these uber air coolers are nice for me. I have the Dark Rock Pro 1, and it's great. Although this will probably keep me happy at least another year or two and by then, I'm assuming the all in one water coolers will be too good to pass up.
dolphie is offline   Reply With Quote
Old 13th Jul 2012, 02:44   #9
SolidShot
Supermodder
SolidShot has yet to learn the way of the DremelSolidShot has yet to learn the way of the Dremel
Surely this just shows that all in one coolers will replace fan cooling, in a similar way SSD's will replace HDD?
SolidShot is offline   Reply With Quote
Old 13th Jul 2012, 10:43   #10
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
I was going to go for the cool look on my cooler choice for my next & the Zalman CNPS12X was a likely candidate for me but...
Seen the difference between the noctua D14 & this & for the less noisy fans on this I'd say this is the best air cooler available & it is so asking to be modded to become an even better air cooler performance wise & looks.
As noted in the review of other system noise, it pretty much voids the point of it being nice & quiet so I'm keen to find out what kinda temps I can get this beauty to.
I'll be using this but not as it is, a mod is definitely in order to bring it's full potential to surface I think.
But the pesky awesome steam sale has a hold on me at the moment but I must buy this cooler so I can get all the important measurements ASAP.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 13th Jul 2012, 10:53   #11
SchizoFrog
I *am* a Dremel
People have said that before about air coolers... Then they released new models with heat pipes and breathed new life in to the system. I don't think they are dead just yet. Fingers crossed that a new design/tech will soon be launched. We still haven't seen Vapour Chamber cpu coolers as far as I know and they have done a lot for AMD's GPU units.
__________________
Old 13th Jul 2012, 11:35   #12
freeclout
Modder
freeclout has yet to learn the way of the Dremel
It is kinda big though. 1.25kg (hopefully including fans). . . So how much weight can a motherboard take? Wouldn't want to be moving my pc much with this inside.
freeclout is offline   Reply With Quote
Old 14th Jul 2012, 11:53   #13
stuartwood89
Please... Just call me Stu.
stuartwood89's Avatar
stuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpitstuartwood89 is almost as Godly as yodasarmpit
I suppose you could secure it to the case itself somehow. That's probably the approach I would take.
__________________
My new blog Stu-Topia.com: because stutopia.com was already taken
Project - Storm Scout Restoration
Originally Posted by Joey Propane View Post
I thought Dragonforce were like a joke/troll rock band? Ya'know, like Nickelback?
stuartwood89 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
