News Windows 8 File History backup feature detailed
Discussion in 'Article Discussion' started by brumgrunt, 12 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Looks good, as at the moment my backup is always out of date.
  3. SighMoan
    SighMoan What's a Dremel?
    29 Mar 2011
    Still not enough for me to even think about upgrading to W8.
  4. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    So.. Akin to "Previous versions" on their server environment?
  5. Gareth Halfacree
    4 Dec 2007
    Basically, yeah. You can also get the same basic functionality on other platforms using Dropbox - although you can only back up as many files as the amount of free space you've got, or pay for a Pro account.
  6. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Between this and Storage Spaces (the built-in multi-drive dynamic RAID type set-up thingy) Win 8 is looking very tasty for effective file management and backup.
    I'm still wary about Metro, even though I haven't used it. Definitely a try before you buy product.
  7. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    About bloody time!
    I've always been a Windows man, but as for mentioned i did the ACMT course a few months ago (Apple Certified Macintosh Technician). We did a whole module on the function of TIme Machine and the File Volt encryption and i though, **** me this is good Microsoft need to get their **** together..
  8. pbryanw
    pbryanw Minimodder
    22 Jul 2009
  9. fdbh96
    29 May 2011
    Pretty much everything important on my pc is in those folders. Maybe they'll add functionality for the whole drive at some point (hopefully :))
  10. Gareth Halfacree
    4 Dec 2007
    Actually, you can tell File History to track any drive or folder you want - it clearly says so in the blog post linked to from the article.
  11. MrJay
    20 Sep 2008
    Entire disk backup wouldn't be possible with a system like this. A weekly snapshot maybe, but constantly monitoring every single file for change, and then saving a copy if that change whilst keeping originals would take up a hell of allot of space!
  12. Gareth Halfacree
    4 Dec 2007
    One word: diffs. (One expansion: differential backups.)
  13. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    Thanks, after reading the blog post I can see the reasoning behind Microsoft not letting users backup the whole drive. I was just worried, after reading the Arstechnica piece, that in the case of hard-drive failure it might be harder to get a working system on a new drive (which it is to a slight degree).
    They've traded a few steps in the recovery process against a saving in hard-drive space and being able to reinstall the OS from scratch without the problem-causing system settings/apps. I think I'll still stick to my backup program, but I think this will be worth experimenting with when I get Windows 8.
  14. dolphie
    dolphie What's a Dremel?
    6 Jul 2012
    Sounds good, keep it coming MS.
  15. BurningFeetMan
    BurningFeetMan What's a Dremel?
    24 Feb 2006
    I use SpiderOak for important changing documents. Not only am I backing up my files via an automated means, but I'm also sharing them across multiple computers.
  16. Guinevere
    Guinevere Mega Mom
    8 May 2010
    But most people don't need a system that keeps every single version of every single file - no matter what.
    Having twenty different backed up versions of a document you worked on for one day a year ago is probably overkill for most people.
  17. Guinevere
    Guinevere Mega Mom
    8 May 2010
    This all sounds very very familiar. Maybe because it's unlike any backup system Microsoft has given us for the home before, and almost identical to Apple's 5 yo Time Machine.
    But why limit the locations backed up? (Hopefully these are the just the automatic settings and can be overridden).
    And how much control is there over it's behaviour to keep every single version of every single file? Surely like Apple they will provide some mechanism to assign higher priority to more recent versions?
    And can this be used during a system restore? Can you install windows and at the time of install point it at your backup disk and get all your PC back? Settings and all?
  18. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    Useless with no option to easily define what places I want to take backups of. Any good backup program should allow the user to say they want to back up any location to any other location. Any "backup" service that does not do this is a joke.
  19. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    I think this would explode with my 13 TB of media
  20. cornelius1729
    cornelius1729 What's a Dremel?
    28 Feb 2011
    File History isn't suitable for the whole disk. Files in media collections are unlikely to change, so a straightforward backup makes more sense than something that tracks changes. Similarly, many of the operating system and program files won't change. (Config setting might, but DLLs won't.)
    Also, you may want to forget some files. Do you really want that goat pr0n movie you donwloaded on the sly tracked forever?
Tags: Add Tags
