Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 18th Jul 2012, 17:56   #1
MSHunter
Mod Master
MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.MSHunter is definitely a rep cheat.
Is there any Freeware software like MakeMKV?
Like the title says is there a free ware alternative to MakeMVK.
MakeMVK says its free but all I get is a 30 day trial and then they want 40 euro.
Click Buy NOW to see price.
Either way going to use Make MVK to back up as many of My Blurays as I can. Mostly so I can play them an any of my PCs or Andriod phone. The digital copies (from triple plays) are a nightmare of DRM.
Any one know some good guides/tips for ripping and re-encoding?
straight rip has given me main movie at 13GB is that a good size or can I get is smaller while keeping 1080p and good quality video/audio?
__________________
Caved and bought a Gigabyte P35x V3 gaming laptop.
ex-PC: Silverstone TJ08B-E, 2500K, Corsair H80, 256 GB Samsung 830,GENE-Z , Corsair V. LP 16GB, Gigabyte 1.5GB GTX 580 Super Overclock. U2711
PC Audio: AKG 271 mk II + Samson Go mic. + Asus Xonar D2X
Amp: DENON PMA510AE, Speakers: TANNOY MERCURY F1
MSHunter is offline   Reply With Quote
Old 18th Jul 2012, 18:41   #2
digitaldunc
Hypermodder
digitaldunc's Avatar
digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.digitaldunc is the Cheesecake. Relix smiles down upon them.
While in beta MakeMKV is time limited; download the latest version and you'll be able to use it again.
__________________
Event-horizon: i7 2600K @ 4.5 @ ~1.3v | 16Gb Corsair Vengeance @ 1866 9-10-9-24-2T | 2 x 580 1.5Gb (SLI) 772/1002 | Asus P8P67 Deluxe | Crucial M4 256Gb | Spinpoint F3 1TB | Corsair HX1000 | ZM-MFC1 Fan controller | XSPC Dual res | 2 x DDC 18W | Black ice stealth 360 | ThermoChill PA120.4 | EK Supreme HF Nickel | 2 x EK 580 Plexi | 7 x Scythe Gentle Typhoon 1450RPM | Modded TJ07
digitaldunc is offline   Reply With Quote
Old 18th Jul 2012, 18:44   #3
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
I'm afraid I don't know a lot about the encoding process.
But 13gb should be ok for blu-rays.
With that kinda size I presume your overall bitrate will be 10-15mbps depending on the length of film?
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Will
My Parvum Systems build log - My flickr - My blog it'sfilmnotmovie - hwbot
I identify as mayonnaise-kin, think of it as white without the privilege.
GeorgeStorm is offline   Reply With Quote
Old 18th Jul 2012, 20:41   #4
MSHunter
Mod Master
I'm new to this so I just left it at default settings. Is there an easy way to figure out which file is the main movie without ripping all 20+ GB files?
what do you average on file size just main movie?
I got it direct from the web-page so I guess I have up-to-date version
__________________
Old 18th Jul 2012, 21:04   #5
GeorgeStorm
Well, depending on what kinda bitrate you're encoding to, you could end up with sizes varying from 6-40gb
I would recommend making sure it's atleast 10, and probably a little higher if possible (high teens)
__________________
Old 18th Jul 2012, 23:33   #6
MSHunter
Mod Master
I'm having a blind moment and can not find that setting any where in my version of makeMVK....
__________________
Old 18th Jul 2012, 23:34   #7
GeorgeStorm
I've never used makeMKV (I've personally never encoded a blu-ray), but I presume there must be quality options for encoding
__________________
Old 19th Jul 2012, 07:50   #8
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
MakeMKV is pretty dam good for pulling the video off the disc, however I then run it via Handbrake to drop the 20Gb file down to ~4Gb, just remember to select English Subs where applicable.
Keep the H.264 and MKV settings in Handbrake, and not the default standard of mp4. Mp4 might be more accepted at the moment but I've heard Raspberry Pi accepts H.264 a lot better. And it's only a matter of time before everyone has one! lol!
There is also an app called "ripbot264" but you'll need something like AnyDVD HD to bypass the security of the disc.
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 19th Jul 2012, 08:46   #9
Bumfluff101
Supermodder
Bumfluff101's Avatar
Bumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming SaiyanBumfluff101 is a Super Spamming Saiyan
Read this guide http://lifehacker.com/5559007/the-ha...ray-collection
I think the only real issue with MakeMKV is that it doesn't handle protected subtitles very well - I am trying to work this out at the mo
Bumfluff101 is offline   Reply With Quote
Old 23rd Jul 2012, 21:58   #10
MSHunter
Mod Master
thanks for all the help. wish Any DVD HD was not so expensive. will be using make MVK and that giud was great help with handbreak re-encoding
__________________
Old 26th Jul 2012, 18:00   #11
YEHBABY
RIP Tel
YEHBABY's Avatar
YEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming SaiyanYEHBABY is a Super Spamming Saiyan
PM'd
__________________
i7 2700K / Asus Gene V / 8GB Corsair Vengeance LP / Samsung 830 256GB / 2x4TB HGST & 4TB WD Red / Be-Quiet! E9 CM580W / Antec P182 / Thermalright Silver Arrow Cooler / Dell U2412M
Microsoft Surface Pro 4
NAS: QNAP TS-670 Pro (upgraded cpu i7 3770S and 16GB RAM). RAID 6 (6 x 4TB) WD RED
YEHBABY is offline   Reply With Quote
Old 27th Jul 2012, 01:12   #12
MSHunter
Mod Master
Thank you again for all the help. I had to format my PC the other day due to the Russian Virus and am rebuilding my bookmarks ATM. OMG so many little programs I took for granted. Still trying to find all my Rainmeter widgets like CPU and GPU temp monitoring. Yes there are other programs that can do that. But it is nice to keep it all in one system. Oh Google where art thou?
What settings do you guys use for things like Transformers and Avatar in Handbrake versus Old movies where the picture quality is much lower any way?
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
