Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Jul 2012, 07:52   #1
brumgrunt
Ultramodder
brumgrunt's Avatar
brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.brumgrunt is a hoopy frood who really knows where their towel is.
Open source alternatives to Windows Home Server
http://www.bit-tech.net/bits/softwar.../replace-whs/1
brumgrunt is offline   Reply With Quote
Old 19th Jul 2012, 09:22   #2
barrkel
Multimodder
barrkel has yet to learn the way of the Dremel
On backup: I recommend something like CrashPlan instead, if you can install it for your chosen server. It has installers for Linux and Solaris, but not FreeBSD last time I checked; I run the Solaris version on Nexenta.
The advantage it has is that, when running on your PCs, it can back up to multiple destinations; I have mine configured to back up to both my Nexenta NAS and the cloud. So I get off-site backups as well as very high speed restores.
barrkel is offline   Reply With Quote
Old 19th Jul 2012, 09:31   #3
Fingers66
Kiwi in London
Fingers66's Avatar
Fingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming SaiyanFingers66 is a Super Spamming Saiyan
There is one thing blatantly missing from this article - backing up your home server!
(In before Pookeyhead...)
All well and good putting your important files, backups and media on a home server, but if you don't backup the server, you are just moving the single point of failure from your PC to the home server.
Personally I use two...a Synology DS211j which backs up to a home built NAS via rsync (OpenMediaVault but used to use FreeNAS). The network backup options in Synology's DSM allows versioning and there are probably similar options available in the open source packages mentioned in the article.
You don't need another server to backup your home server, an external hard drive will do, but you must back it up or suffer the consequences.
__________________
Gaming: [Silverstone TJ08-E][Asus Z170M-PLUS ][i5-6600K][Tundra TD03][16GB 2666MHz][Asus 7970 DCUII TOP][Samsung 850 Evo 500GB][Corsair HX650][Dell U2412M][Corsair K60]
Main: [Lian Li PC-A04][Asus Z97M-Plus][i7-4770K][Corsair H55][16GB 1600MHz][iGPU][Samsung M.2 NVMe 256GB][Seasonic X-650 Gold]
Kids: [Silverstone SG05B][Asus H87I-Plus][i3-4330][8GB 1600MHz][Asus 6850 DirectCU][Crucial M4 256GB][ST45SF 450w][Dell E207WFP]
NAS 1:[Synology DS211j] NAS 2:[Homebrew OMV]
Fingers66 is offline   Reply With Quote
Old 19th Jul 2012, 09:34   #4
Anakha
Supermodder
Anakha's Avatar
Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.Anakha is the Cheesecake. Relix smiles down upon them.
For streaming, I have to say that you've really missed out on the best DLNA server out there, bar none.
Serviio is written in Java (but it's not that bad, honest), and supports most (if not all) streaming clients out there. It has built-in content recognition to sort your music, TV and movies correctly, including displaying covers and other fun DLNA features like resuming playback. But that's not the best part. It also has a built-in live transcoding system. So if you have a AVC High/AAC 7.1 video file, but your streaming box (TV, Xbox 360, HTiB, whatever you're connected to) doesn't support the format, Serviio will automatically transcode the file on-the-fly into a format that IS supported by your device. AppleTV won't play FLAC? Not a problem! X360 won't play VOB? Big deal!
Oh yeah, and thanks to the power of plugins and scripting, it'll also play streams from BBC's iPlayer (if you're in the UK), Youtube, and many many more. And while the DLNA service might be built in Java, all the transcoding and streaming is handled using FFMpeg, so it'll stay up to date and use all the features of your CPU.
Combine it with Transmission running in Daemon mode, and FlexGet to grab TV/Radio/Movies from RSS feeds, and you'll have no need of your TiVO anymore.
I'm running the above on a basic Ubuntu server in the basement (though it needs upgrading since I switched to HD), and while the interface for adding/changing hard-drives is very unintuitive (okay, it's LVM on the command-line) it's something that needs to be done so rarely it's a "set it and forget it" thing. One mountpoint exported over SMB, LVM handles the RAID (well, JBODing, but who's checking?) and you're set. Throw in an Apache install (just 'cause. It's not really needed at all) and you're set.
__________________
Robert "Anakha" Johnston
Going to Canada on Nov 28th! I'm going home!
Anakha is offline   Reply With Quote
Old 19th Jul 2012, 09:36   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
I'd disagree: if you're using your server as a backup server for client PCs, then there's no real need to backup the backup (aside from a desire to take a belt-and-braces approach.) You'd only need the backup if the client failed, and the chance of the client failing at the same time as the server (in a way that wouldn't also take out the backup server's backup server, such as a fire or massive electrical surge) is minimal. If you want to truly protect yourself, you'd want to combine a single on-site backup with an off-site backup. Having two on-site backups isn't the protection you'd expect...
If you mean backing up content that is *only* on the server - and not duplicated on client PCs - then you're quite right, that's something you need to do; I'd argue that's outside the scope of the article, which is simply looking at how to replace the most commonly-used features of Windows Home Server with open source equivalents.
Serviio is written in Java [...]
I could be wrong - I haven't used Serviio myself - but most Java-based transcoding-capable media streamers require X and a desktop environment to be installed - something I, personally, try to avoid on a server. (For the record, I use an ARM build of miniDLNA on a server which wouldn't be capable of real-time transcoding anyway, which is one of the reasons I haven't looked into that side of things since I ditched Windows and the excellent TVersity.)
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 19th Jul 2012, 09:38   #6
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
And for drive pooling, you can use Greyhole. There is a OpenMediaVault plugin (my experience was that some features worked and some were buggy in the UI) and it is already included in Amahi. That is if you need web GUI for pool configuration. If not, you can use any Linux distro.
faugusztin is offline   Reply With Quote
Old 19th Jul 2012, 09:42   #7
Fingers66
Kiwi in London
Fingers66's Avatar
Originally Posted by Gareth Halfacree View Post
...<snip>
^ This scenario is what I was referring to and you are probably right about it stretching the scope of the article although a health warning is still applicable.
With regard to important files, you are correct but I would of thought that when streaming media from the home server, would people keep the media on the PC, back it up to a home server then stream from the backup? Surely the inference is that the media is solely kept on the home server?
__________________
Old 19th Jul 2012, 09:45   #8
Gareth Halfacree
WIIGII!
bit-tech Staff
Very true - but remember, the article is just about replacing Windows Home Server features with open source equivalents. If they didn't have a backup of their Windows Home Server, then they're in the same boat when they switch to VortexBox (or whatever; ) if they did, then they can use the same backup with their shiny new Linux/FreeBSD/whatever server.
Now, if people would like to see a feature on backup best-practice, that's a whole new ballgame - and something I'd be happy to cover if there's a demand!
__________________
Old 19th Jul 2012, 09:48   #9
asura
jack of all trades
asura's Avatar
asura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyan
Please.
asura is offline   Reply With Quote
Old 19th Jul 2012, 09:53   #10
Fingers66
Kiwi in London
Fingers66's Avatar
An article on backup best practice would be great, if only to stop Pookeyhead ranting in the forum that "RAID is not backup", it might save his keyboard...
__________________
Old 19th Jul 2012, 09:58   #11
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
thank you
i shall be using this - for setting up a home file server later on today !
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 19th Jul 2012, 10:00   #12
scott_chegg
Hypermodder
scott_chegg's Avatar
scott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on youscott_chegg - may the hammer of Bindi be bestowed on you
Used FreeNAS back in the day then tried OpenMediaVault when it got released. Both superb but didn't give me the flexibility I needed. Luckily I've built up my Linux skills over the last few years to a fairly capable level so now use Ubuntu Server and Webmin for lights out management.
Backup my PC and the wifes laptop with RSYNC, Transmission handles the downloads and Plex Media Server installed on it for streaming media to my Android tablet and an Android 4 based TV set top box.
Great article though. Loving the inclusion of this kind of thing in Bit-Tech.
__________________
My System: i5 2500K @ 4.7Ghz | MSI P67A-GD65 (B3) | 16GB Crucial Ballistix Sport 1600MHz | Corsair H-50 Push-Pull with Silent Eagle 2000's | Silverstone Raven RV03 | EVGA 670 FTW | Dell SP2309W | Antec 750W TruePower Blue | Win 7 x64 | Crucial 64GB C300 for OS | Samsung 830 256GB for Active Games & a 1TB Samsung for Steam. Perphiperals: Roccat Kone+ Max V2 | CMStorm Quickfire Pro with Cherry Reds | Cyborg F.L.Y 5 stick for flying and a Logitech DF GT for driving.
scott_chegg is offline   Reply With Quote
Old 19th Jul 2012, 10:09   #13
mi1ez
Game Boy Modder
mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!mi1ez - it's over 9000!!!!!!!!1!1!1!!!
Great article. I'm about to get my hands on a couple of old PCs and might take a llook at turning one into a fileserver. Oh, and another yes to a backup article!
__________________
The Angel Delights?
mi1ez is offline   Reply With Quote
Old 19th Jul 2012, 10:43   #14
Risky
Risky's Avatar
Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.Risky is definitely a rep cheat.
I'm still running a WHS1 Box - It's not perfect, remote access isn't working and I have had to run some disk checks once or twice but it's been goign for a feew years and does the critical stuff (backup and filesharing) fine.
I'll replace it at some point but it has to be the last place I want to start trying things out.
For the record it is running on a HP Proliant ML110 G4 with some critical folders getting a cloudy backup from keepvault.
__________________
As a rule watercooling can be simple, affordable and effective... I guess I just like to break the rules.
Risky is offline   Reply With Quote
Old 19th Jul 2012, 10:56   #15
neocleous
Hypermodder
neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.neocleous is the Cheesecake. Relix smiles down upon them.
Thanks for writing the guide, but each distro seams to be good at one specific thing where as Windows Home Server seems to do them all pretty well.
Also I would imagine that installing any of these operating systems would involve formatting my WHS software RAID drives which I don't think is possible any more for me as I have too much data now
neocleous is offline   Reply With Quote
Old 19th Jul 2012, 11:15   #16
Gareth Halfacree
WIIGII!
bit-tech Staff
There is that, but the individual sections were picked specifically for people who use one feature more than another. It's possible, for example, to install a UPnP media streaming server on FreeNAS, if you need both a file and a media server; it's also possible to go the opposite way, and store your data - and backups - on an OpenMediaVault server alongside your media. Nagios, and similar, can also be installed on any server in addition to any other tasks it might carry out. All these options do, however, require a bit of work - some more than others.
That, right there, is the big problem. As you say, WHS fake-RAID drives are pretty much impossible to get working on any non-Windows OS. You'd need to back up the data first, or build a second server with one of the suggested distributions on it, copy the data from the old server across the network, then retire the old server.
'Course, if you don't have any backups of the data on the server now, you're risking a lot: RAID improves availability, but it's not a backup. If the WHS box dies on its backside, or decides - through glitch or malware - to wipe all your data, or there's a power surge that kills both hard drives... Bye-bye, data.
__________________
Old 19th Jul 2012, 12:08   #17
faugusztin
That is pretty much what am i doing right now. I got fed up with WHS2011 inside ESXi giving me ocassional pauses in the DVB stream, Drivebender sometimes switching to read-only mode because WHS hammered it with the backup system etc. So after a bit of looking around i replaced ESXi with Ubuntu 12.04, installed Amahi on top of it (solves the DHCP, Samba shares and drive pooling part of equation), manually installed lates vanilla kernel + DVB drivers + MythTV and later i will add all the remaining services i need.
I was thinking about OpenMediaVault, but being based on Debian means it still uses archaic 2.6.x kernel which is unfortunately issue for the drivers for my DVB-C card, plus the Greyhole plugin was buggy. So i choose Ubuntu + Amahi.
Now only i have to manually move all the data drive by drive (mount ntfs drive, copy data to the pool, unmount the drive, delete ntfs partition, create ext4 partition, format ext4 partition, add drive to Amahi, add drive to greyhole pool, repeat) .
Old 19th Jul 2012, 12:13   #18
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
I would also be interested in a backup article, something I still need to get around to doing...
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Will
My Parvum Systems build log - My flickr - My blog it'sfilmnotmovie - hwbot
I identify as mayonnaise-kin, think of it as white without the privilege.
GeorgeStorm is offline   Reply With Quote
Old 19th Jul 2012, 13:16   #19
Tattysnuc
Thinking about which mod to do 1st.
Tattysnuc's Avatar
Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.Tattysnuc is definitely a rep cheat.
Excellent to see more material that I'm interested in coming onto the site Gareth. I've an old machine from work that's found it's way home that I'm looking to re-purpose as a file server, and move my raid card into there. It'd be nice if you were to do a how to in the same light that you (or your colleagues - I'm not sure without checking) have done with the scratch build PC.
Thanks for feeding my home-geeking.
Tattysnuc is offline   Reply With Quote
Old 19th Jul 2012, 14:10   #20
VDPloeg
What's a Dremel?
VDPloeg has yet to learn the way of the Dremel
I'm surprised Amahi didn't make it into the article, as it's the closest to a complete WHS open source replacement.
I'm not terribly knowledgeable with Linux but would love to see a how-to about putting together a complete WHS open source competitor.
VDPloeg is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
