Reply
Thread Tools View Mode
Old 24th Jul 2012, 22:15   #1
phinix
Say it! Who's your dremel?!
phinix's Avatar
phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!phinix - it's over 9000!!!!!!!!1!1!1!!!
*** PHINIX AURORA *** - 29/04/2013 - update time !!!
Aurora - (plural: aurorae or auroras) is a natural light display in the sky particularly in the high latitude (Arctic and Antarctic) regions, caused by the collision of energetic charged particles with atoms in the high altitude atmosphere (thermosphere). The charged particles originate in the magnetosphere and solar wind and, on Earth, are directed by the Earth's magnetic field into the atmosphere.
Hello everyone and welcome to my new project log!
This time I would like to show you something different. It won’t be a scratch build, like all my previous projects. This time I’m going to mod a case!
I hope you liked my Cube and Nano Tower and now I’m hoping you are going to like what I’m about to start. So let’s see what’s brewing shall we?
PHINIX AURORA
It will be a case mod, based on Lian Li A04, a micro ATX case. Reason I picked this case is that it is one of the smallest mATX cases on market – it doesn’t have any particular feature that I was after. It is simple and easy to mod - this is why you can do basically anything with it
I haven’t done any case mods before, so it is going to be a challenge for me, but also a good fun.
I have some ideas what I’m going to do to this little case and would like to share them with you guys... again!
Main ideas:
• Color scheme: white and blue, pure aurora
• Shape and size: very close to the size of the case itself:
(W) 188mm x (H) 386mm x (D) 460mm
• White powder coating and painting
• Blue and white acrylic elements
• Customised side panels and front panel
• Watercooled CPU and GPU
• Internal “power chamber” including PSU and all wires and power junction
• Custom made drive cage
• Custom Interior lighting
Hardware (may change during the project):
• i5 2500K OCed to the limits
• mATX motherboard
• 8GB of RAM
• GTX670 graphics card
• modular PSU
• 2x SSD and 2.5” HDD for storage
Watercooling:
• CPU block/pump
• GPU block
• Double radiator
• Reservoir
• Blue tubing
• Compression fittings
• Temperature sensor + lcd display
• Blue coolant
First phase has started - I'm gathering all hardware and items. It will take a while, but couldn't keep this project hidden any much longer
So again... JOIN ME IN THIS NEW CRAZY MODDING RIDE !!! :
My Phinix Aurora Project is sponsored by:
MAYHEMS
Mayhems kindly supported me with the following items:
COOLER MASTER
Cooler Master kindly supported me with the following items:
ENERMAX
Enermax kindly supported me with the following items:
MNPCTECH
Well known to all of us, professional modder Bill from MNPCTECH kindly supported my project again, by sending me these items:
HINDLEYS
Hindleys is a huge design and technology supplies shop, where you can buy all the kind of materials, tools, electronics, hardware and consumables and all the craft and design products.
They kindly supported me with the following items:
GIGABYTE
GIGABYTE kindly supported my Aurora project with their Z77 mATX motherboard - GA-Z77M-D3H.
EKWB
EKWB kindly supported my project with their nickel/acetal water block for GTX670 with a nice backplate.
SCYTHE
Scythe kindly supported my project with their newly announced Scythe Kaze Station II fan controller!
__________________
::: i5 2500K :: GTX670 :: 2x 840 PRO 128GB :: Gigabyte Z77 mATX :: 4GB Ballistix :: Hazro 27" :: CM QF Rapid MX Browns :::
projects: ::: “PHINIX CUBE” ::: "PHINIX nanoTOWER" ::: "PHINIX AURORA" :::
phinix is offline   Reply With Quote
Old 24th Jul 2012, 22:15   #2
phinix
phinix's Avatar
Shortcuts to all stages:
__________________
Old 24th Jul 2012, 22:15   #3
phinix
phinix's Avatar
LAST STAGE PHOTO
February 2013
__________________
Old 24th Jul 2012, 22:31   #4
AnG3L
Ultimate Modder
AnG3L's Avatar
AnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run CrysisAnG3L can run Crysis
Here (first as some guys in YT say) to express my enthusiasm and reserve a front seat with the best view. Oh wait I forgot the beers!!! Mod bro, MOD!!!!!
AnG3L is offline   Reply With Quote
Old 24th Jul 2012, 22:32   #5
Gtek
Supermodder
Gtek's Avatar
Gtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run CrysisGtek can run Crysis
Very good. subscribed.
__________________
***gtek-computerdesign.com***
Gtek is offline   Reply With Quote
Old 24th Jul 2012, 22:46   #6
Editor22
E22.BIZ
Editor22's Avatar
Editor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run CrysisEditor22 can run Crysis
ooo a new Phinix build... Subbed
__________________
Store: E22
Social: Youtube | Facebook
Projects: Evolution | K2 MK1
Editor22 is offline   Reply With Quote
Old 24th Jul 2012, 23:12   #7
Combatus
Custom PC/bit-tech modding sections
Combatus's Avatar
Combatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for presidentCombatus should be considered for president
Not many people of your modding calibre can say that! This should be interesting indeed!
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES! | Mod of the Month March 2013 is here! Vote now!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 25th Jul 2012, 00:03   #8
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
Very happy to catch one at the begining.
Mod on phinix.
Waynio is offline   Reply With Quote
Old 25th Jul 2012, 00:31   #9
Spreadie
No disassemble!
Spreadie's Avatar
Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.
After your last project, I can't help but watch this with great interest. Looking forward to it.
Sent from my iPhone using Tapatalk
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60
Spreadie is online now   Reply With Quote
Old 26th Jul 2012, 09:22   #10
phinix
phinix's Avatar
Thank you guys!
I'm happy to see all you guys are going to watch it, all "usual suspects" are here, I can start then!
Cheers Antony - I'm not sure about that calibre, but if you say so, I trust your judgement
Originally Posted by Spreadie View Post
After your last project, I can't help but watch this with great interest...
Thanks - NOW I feel the pressure!
I hope you will like this one too
Thank you all again, I will be back with first photos this weekend.
The main "victim" is here, I will introduce "her" this saturday
__________________
Old 26th Jul 2012, 11:09   #11
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
2. Your first post must contain pics of the actual mod in progress. If all you have is an idea, you don't have a log. If all you have is some conceptual sketches, you don't have a log. If all you have to show is a heap of parts, you don't have a log. This forum is purely for concrete work in progress - the other modding forums are more appropriate for concepts and thoughts.
Move to modding for the time being, and subbed
Mankz is offline   Reply With Quote
Old 26th Jul 2012, 12:17   #12
stonedsurd
Is a cackling Yuletide Belgian
stonedsurd's Avatar
stonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for presidentstonedsurd should be considered for president
YES!
__________________
My Flickr
Originally Posted by specofdust View Post
You don't believe people can be trusted to be exposed to ideas, to thought, to expression. I choose to say that even if people can't be trusted, it's moral that they should be, because I have no right to elevate myself above them and decide on their behalf what they should be exposed to, because that is authoritarian, discriminatory, and wrong.
stonedsurd is online now   Reply With Quote
Old 26th Jul 2012, 21:38   #13
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Poink!*
*Typical cry after a instinctive one-shot kill in a FPS game.
I saw the name of the poster, and automatically "Poinked" as I clicked the link. I guess I'm trying to say there was no hesitation or thought about clicking.
Cheapskate is offline   Reply With Quote
Old 26th Jul 2012, 22:17   #14
Evenge
Hypermodder
Evenge's Avatar
Evenge has yet to learn the way of the DremelEvenge has yet to learn the way of the Dremel
Phinix modding Lian Li case? Quick! Where's popcorn!
__________________
Project: Discovery
Project: Strobe
Main: i5 2500K - 8GB - GTX570 - Win 7
Laptop: Asus U36SD - i5 2430M - 4GB - Win 8 Pro
Evenge is offline   Reply With Quote
Old 29th Jul 2012, 18:51   #15
Beriphent
What's a Dremel?
Beriphent has yet to learn the way of the Dremel
phinix, I loved nano tower so much. It was such an inspirational and top-notch project. I can't wait to see more work from you!
Beriphent is offline   Reply With Quote
Old 29th Jul 2012, 19:20   #16
SB-1991
What's a Dremel?
SB-1991 has yet to learn the way of the Dremel
Not seen your previous work, but judging from everyone's comments I'll sub and enjoy, might give me some ideas for a new build.
SB-1991 is offline   Reply With Quote
Old 30th Jul 2012, 19:27   #17
phinix
phinix's Avatar
Thank you all for a warm "welcome back"
I'm so happy you are going to watch this one too, hopefully it will bring you all as much fun as Nano Tower and Cube!
OK. As promised, here are the first photos.
The victim....
Victim's insides...;P
Internal drive cages must go, I won't be using them at all.
Those tool-less screws are pretty handy...
These needed a bit help with screw driver...
..aaaand they are out!
This support bit is going out as well, but I will use those holes for mounting power chamber cover...
On this photo you can see how deep the radiator will go. 60mm thick one of course, will be mounted verticaly.
Here you can see how high those 120mm fans go. As you can see top dvd bay bracket will also have to go. Radiator will take up a bit of that space later on. Rest of that are will be reveiled later
Those top switches are mounted to the dvd bay so I left the bay inside, till I'll be ready to rip those buttons out....
That is it for now.
__________________
Old 31st Jul 2012, 12:41   #18
Nanosec
absit iniuria verbis
Nanosec's Avatar
Nanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the DremelNanosec has yet to learn the way of the Dremel
Sub'd
I can't believe they actually build cases with top mount connections, with no dust cover in sight, have to think the unused ones would get full of dust in no time.
Nanosec is offline   Reply With Quote
Old 31st Jul 2012, 12:56   #19
matiss
Multimodder
matiss's Avatar
matiss has yet to learn the way of the Dremel
*squeezes in in the first row*
Now this one can only be good
matiss is offline   Reply With Quote
Old 31st Jul 2012, 13:06   #20
Mechh69
I think we can make that fit
Mechh69's Avatar
Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.Mechh69 is the Cheesecake. Relix smiles down upon them.
Well for once im not late to the mod party. This looks like it's going to be an interesting mod. Subbed and waiting for surgery.
__________________
Originally Posted by Deders View Post
What if you touch yourself with kittens?
I7 920@3.8Ghz,EVGA E760 Classified, Corsair XMS3 X 6GB 1600, Kingston Hyper X 12GB 1600, 240GB OCZ Agility 4, BFG 260 GTX Core 216 X3, BFG 9600 for PHYSX, Thermaltake Armor+, BFG EX1200 PS, Scythe Mugen 2 Cpu cooler, Samsung Syncmaster 2233RZ, Nvidia 3D Glasses
Mechh69 is offline   Reply With Quote
Reply
Tags
lian li case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
