#1 |
What's a Dremel?
Bloody - Lian Li V2120X Liquid Cooling by pociej
Hey!
Today I want to start share my work on LC build in Lian Li V2120X which I started around 1,5 year ago... Earlier it was simple build but with time I start to want more... So, let's start quick journey through previous revisions and what's goin' on now... Picasa album (all photos): https://picasaweb.google.com/103430404504931958914 My site: www.pociej-custom-lc.pl Revision 1: Hardware: Intel Core i7 920 Foxconn Bloodrage Corsair DDR3 3x2 gb 1600 mhz CL8 XMS3 Gigabyte Geforce GTX 580 OCZ Vertex 2 180GB Samsung HD103SJ be quiet! Dark Power PRO P8 750W Lian Li PC-V2120X LC parts: EK Water Blocks EK-Supreme HF Swiftech MCR 320 Quiet Power Swiftech MCP355 + Aquacomputer Aquacover DDC Bitspower Z-Multi 150mm Bitspower Black Matt Fittings Poweradjust 2 Revision 1 gallery: https://picasaweb.google.com/1034304...eat=directlink https://picasaweb.google.com/1034304...eat=directlink Revision 2: Hardware: Intel Core i7 920 @4,0ghz Foxconn Bloodrage Corsair DDR3 3x2 gb 1600 mhz CL8 XMS3 Gigabyte Geforce GTX 580 OCZ Vertex 2 180GB Samsung HD103SJ 4x ST2000DL003 in Lian Li EX-503 be quiet! Dark Power PRO P8 750W Lian Li PC-V2120X LC parts: EK Water Blocks EK-Supreme HF EK-FC580 GTX Swiftech MCR 320 Quiet Power EK Water Blocks CoolStream RAD XTC 280 Swiftech MCP355 + Aquacover DDC Bitspower Z-Multi 150mm Bitspower Black Matt Fittings Aquaero 5 XT + Poweradjust 2 Revision 2 gallery: https://picasaweb.google.com/1034304...eat=directlink https://picasaweb.google.com/1034304...eat=directlink https://picasaweb.google.com/1034304...eat=directlink Revision 3: Hardware: Intel Core i7 2600K Asus Maximus IV Extreme-Z Corsair Dominator GT 1866mhz nVidia Geforce GTX 580 OCZ Vertex 2 180GB Samsung HD103SJ 4x ST2000DL003 in Lian Li EX-503 be quiet! Dark Power PRO P8 750W Lian Li PC-V2120X Dell AW2310 & nVidia 3D Vision LC parts: EK-Supreme HF EK-FB ASUS Max4 Extreme Bitspower Galaxy Freezer DIMM4 EK-FC580 GTX+ Swiftech MCR 320 Quiet Power EK Water Blocks CoolStream RAD XTC 280 Swiftech MCP355 + Aquacover DDC Koolance TNK-200 Reservoir Bitspower Black Matt Fittings Aquaero 5 XT + Poweradjust 2 Revision 3 gallery: https://picasaweb.google.com/1034304...eat=directlink https://picasaweb.google.com/1034304...eat=directlink And now is time for revision 4!! My obsession of quiet forced me to modernize LC system to keep low temps after OC Core i7 and GTX580 under heavy load, quietly of course.Thus born idea for new revision. Revision of system which should cool Core i7 and SLI, which should look nice and clean. Project and parts list is ready, all parts are on the way to me. Part of it is already delivered. I know you like pictures so no more talking... Hardware: Intel Core i7 2600K @4,7Ghz Asus Maximus IV Extreme-Z Corsair Dominator GT 16GB 2133mhz 2x EVGA GeForce GTX 680+ 4GB Backplate OCZ Vertex 2 180GB Samsung HD103SJ 4x ST2000DL003 in Lian Li EX-503 Seasonic Platinum SS-1000XP Lian Li PC-V2120X Dell AW2310 & nVidia 3D Vision LC parts: EK-Supreme HF EK-FB ASUS Max4 Extreme Bitspower Galaxy Freezer DIMM4 2x Koolance VID-NX680 MO-RA3 4x180 LT 2x Swiftech MCP35X Koolance TNK-200 Reservoir Bitspower Black Matt Fittings Koolance Quick Disconnects Aquaero 5 XT + Poweradjust 2 And the best part: Last edited by pociej; 24th Oct 2012 at 15:39. |
#2 |
What's a Dremel?
Hello
Quicks unboxing while waiting for blocks and putting cards on AC onto mobo... And few from draining and mounting new gpu's on AC to do some tests... |
#3 |
What's a Dremel?
Blocks for cards arrived.
Koolance did great job with them... |
#4 |
Modder
You just murdered my eyes D: ha ha ha, looking awesome already and by the looks of it... Fantastic
sub for the thread... I'll be watching from the shadows
#5 |
What's a Dremel?
Hello,
Need to prepare case to connect external radiator. Today I made holes for Koolance Quick Disconnects: And second: The final effect: |
#6 |
What's a Dremel?
Meantime I prepared new SLI bridge.
Typical bronze flexible bridge disgusts me. Last edited by pociej; 4th Sep 2012 at 21:35. |
#7 |
Supermodder
Holy... Looks like its going to be awesome.
Love that SLI bridge! Where did you get it or make it? |
#8 |
What's a Dremel?
Hi,
two things today: - new flowmeter - new cover for Aquaero 5 XT And with changed plug to fit Aquaero 5: Now playing with Aquaero 5. Aquaero 5 XT with old touch panel: Front panel taken off: PCB behind touch panel: New panel: And final effect: |
#9 |
S p i t F i r e
Looks awesome
__________________
Latest project ¦ Hidden living room gaming PC ¦ Awaiting time/space from kids ![]() UV . Silent . waterCooled - Vertex 4 256GB . i5 750 @ 3.1Ghz . 8GB DDR3 1600 . Gigabyte GA-P55M-UD4 .GTX 670
#10 |
Minimodder
Great job :
2 X 680
#11 |
What's a Dremel?
Hey!
Two new parts: Bitspower CPU Block Summit EF (Acrylic Top Version): Bitspower Water Tank Z-Multi 250 (Acrylic Version): |
#12 |
Modder
Great parts going into this one. Hope to see more soon.
#13 |
Flimbo's Quest?
Can't wait to see how you set up the external radiator!
#14 |
Modder
#15 |
What's a Dremel?
I can't compare it to used before EK Supreme HF, because in this revision I will use different radiator and new GPUs so temperatures will vary.
Anyway I think result should be not worse than before. Relating to CPU waterblocks test on other forum Summit EF is very close to Supreme HF in performance and maybe I will decide to use Indigo Xtreme which should make temperatures even better. |
#16 |
What's a Dremel?
Hey!
The work began. Came rest of parts, cables (except a few powering ones) so there is no reason to wait ... Among other things, Until then I started with one GPU, and installation of a new reservoir in the housing. Photos of this soon, because I have to drill through the midplate ... :] Last edited by pociej; 15th Dec 2012 at 11:28. |
#17 |
Rep whore/ Car lover/ Speed Junkie
*holleywood damsel screem* those first shots... it.... ITS MISSING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!! water cooling but no gpu?!!! blasphemy!!!!!!!!!!!!!!!!!!!!!!!!
/jokesriosly tho, looks good
__________________
Hard to explain to someone who has no clue. Or doesn't believe you. It's a daily struggle being in pain or feeling sick on the inside while you look fine on the outside. Please put this as your signature for at least 1 hour if you or someone you know has an invisible illness (Pancreatitis, Crohn's, PTSD, Anxiety, Bipolar, Depression, Diabetes, LUPUS, Fibromyalgia, MS,Lupus, ME, Arthritis, Cancer, Heart Disease, Epilepsy, Autism, etc.) " Never judge what you don't understand. |
#18 |
No power, no glory
Wow! Its looking amazing so far, can't wait for it to be finished! What kind of quick release fittings are those?
#19 |
What's a Dremel?
Thanks guys.
These are VL3N-MFG-P and VL3N-F10-16S. |
#20 |
What's a Dremel?
Hey,
few new photos ... |
| Thread Tools | |
| View Mode | |
