Reply
Thread Tools View Mode
Old 26th Jul 2012, 03:21   #1
Boddaker
Still hangin around
Boddaker's Avatar
Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.
Cosmos Cruizer - Final Pics!
Ok folks, time to get back in the modding saddle! Having completed all my commissioned obligations for the time being, I thought it would be a good time to start my next personal project. This time I'll be taking on the gargantuan "Ultra Tower", the Cosmos II. I've always wanted to do a hotrod-themed build, and I think the Cosmos II lends itself well to this theme with its sleek, aerodynamic lines, and beefy roll-bar type handles. I'll be playing off these features, moving some things around, and generally wreaking havoc on this poor case, but in the end you'll still be able to distinguish it as a Cosmos II.
The first thing you'll notice is the open-air design. I actually hated to get rid of those cool doors, but I wanted that open engine compartment feel. And with pretty much everything watercooled, there would be no reason to worry about airflow. Next is the watercooling manifold. I spent the most of my design time on this part, as it has to be functional, as well as look like an actual automotive component for fuel delivery. It will accommodate two separate loops: One for the video cards, and one for CPU, memory, and motherboard.
As far as hardware, there are still some items up in the air, but here's a short list of what I have already:
EVGA X79 FTW motherboard
EVGA GTX680 HC X2
Intel i7 3960X CPU
Cooler Master SPH 1050w PSU
I'll be updating this as I get stuff in.
Ok, I guess that is enough of an intro, I'll be posting my first progress update shortly. Thanks for reading, and I hope you'll be joining me on what promises to be another wild modding ride!
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 26th Jul 2012, 07:55   #2
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Damm!!! Looks awesome already. :O
Pranja is offline   Reply With Quote
Old 26th Jul 2012, 08:16   #3
SilveR_172
Supermodder
SilveR_172 has yet to learn the way of the DremelSilveR_172 has yet to learn the way of the Dremel
Like the looks of it =)
SilveR_172 is offline   Reply With Quote
Old 26th Jul 2012, 10:03   #4
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Sub'd
Look's like it's going to be a awesome mod.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 26th Jul 2012, 10:50   #5
CMos
Minimodder
CMos has yet to learn the way of the Dremel
Wow... how much time did you spend on the design alone?
Looking very good!!
CMos is offline   Reply With Quote
Old 27th Jul 2012, 01:05   #6
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Oh, man. That panel will be tricky. I'll assume you have a way to remove it without dismantling the loop.
-You gonna get bugs in your memory if you roll like that, ese.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 27th Jul 2012, 01:30   #7
Boddaker
Still hangin around
Boddaker's Avatar
Looking very good!!
Thanks CMos. I've been working on the design off and on for the last couple months. It's been through quite a few changes too!
I plan to use quick disconnects on the four lines going through the panel. And as for the bugs, I'm having a bra custom made for it.
__________________
www.bods-mods.com
Old 27th Jul 2012, 01:31   #8
Boddaker
Still hangin around
Boddaker's Avatar
Let's take care of the bottom bars first shall we? In order to make the headers, I need four ends per side which means I need another set of bars. And Cooler Master were kind enough to send me an extra set.
Here's a shot of all four ends lined up.
After marking where I needed to cut, I hacked off the ends. These bars are solid cast aluminum. CM does not cut corners when it comes to supporting their Ultra Tower!
Positioning the piece and rechecking my cut angle. The rest will need to be filed away.
One set of header pieces cut! Now for the other side.
Both sides cut. I want the headers to come even with the back of the case, which is why I made the fourth piece longer. It will make for a trickier weld to the first piece tho.
Filing one of the middle header pieces.
I clamped all the pieces upside down to a flat board to aid in the positioning. Once everything is filed down and fitted perfectly, this will be how it will get welded back together.
And finally a close up shot of how its fitting to the main bar. It's getting there!
I'll be doing a lot of filing over the weekend, but the aluminum is fairly soft so it should go quickly. I can bring out my die grinder to get the bulk of it if need be. I just don't want to remove too much material.
For attaching the pieces, I was eyeballing those Alumiweld brazing sticks at Harbor Freight. Anyone have any experience with them? I have seen the demo vids on Youtube, and it seems easy, but there's gotta be some kind of learning curve. I'll probably grab some and just experiment first and see how it goes.
__________________
www.bods-mods.com
Old 27th Jul 2012, 10:38   #9
Attila
still thinking....
Attila's Avatar
Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.Attila is the Cheesecake. Relix smiles down upon them.
Originally Posted by Boddaker View Post
For attaching the pieces, I was eyeballing those Alumiweld brazing sticks at Harbor Freight. Anyone have any experience with them? ..........................................
I just tried some similar stuff called 'Technoweld'. I had to strengthen some areas on a large assembly of parts. The problem I had was getting the area hot enough to use the material. The temp needs to be 350C to melt the rod but the large work piece acted like a heat sink and I just couldn't get it hot enough with a propane torch. The part would not fit into the oven so I put it into the barbecue. I ended up being too afraid to take the temp up past 300C as I didn't want the part deforming (thirty or so hours invested in this part). So I gave up and used another solution.
The parts you need to join here are thick and robust so it should work. The alu needs to be very clean, so that black finish will need to be removed around the weld area. The only problem I can see that you may encounter is that once you make one of the joins, heating the next one may cause the first to melt and fail. I say 'give it a shot', I'll be interested to see how you go. Good luck.
__________________
stillthinking
Attila is offline   Reply With Quote
Old 27th Jul 2012, 11:04   #10
jokkos
too busy to mod *sigh*
jokkos's Avatar
jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.jokkos is a hoopy frood who really knows where their towel is.
man oh man this is going to look awesome... just the render is pretty awesome already!
great ideas!
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 27th Jul 2012, 12:09   #11
SilveR_172
Supermodder
Love this so much now , would like to have done something like this myself ! well done ! great start
Old 27th Jul 2012, 14:10   #12
CMos
Minimodder
I would be very worried, this is one heavy case and there is gonna be a lot of stress on the backside of that bracket.
Cross my fingers you can pull it off though.
Old 27th Jul 2012, 16:27   #13
BOBDBONE
Owner at BS Mods
BOBDBONE's Avatar
BOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the DremelBOBDBONE has yet to learn the way of the Dremel
Just take those bars in and have them welded up. It will be strong, and will look like the real deal so it's a win-win.
__________________
_______________
www.bsmods.com
BOBDBONE is offline   Reply With Quote
Old 28th Jul 2012, 01:00   #14
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Yeah, but don't you know he's loco?
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 28th Jul 2012, 01:20   #15
Boddaker
Still hangin around
Boddaker's Avatar
Thanks for your input Attila, I'll do some experimenting with the stuff first and see how it goes.
great ideas!
Thanks guys!
Sure, I could just have someone else weld them for me, but what's the fun in that? Gotta at least fail five or six times before resorting to outside assistance.
Muy loco!
__________________
www.bods-mods.com
Old 28th Jul 2012, 01:22   #16
KayinBlack
Toxophile
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
If they're the same size as the bars from a regular Cosmos, I just scrapped one today and still have the bars. If you need them let me know.
KayinBlack is offline   Reply With Quote
Old 28th Jul 2012, 02:14   #17
mindfulone
What's a Dremel?
mindfulone has yet to learn the way of the Dremel
Amazing...my first Sub....
mindfulone is offline   Reply With Quote
Old 28th Jul 2012, 06:16   #18
Boddaker
Still hangin around
Boddaker's Avatar
Thanks for the offer Kayin, but the Cosmos II has much larger bars than the 1000 or the S, so they won't fit.
Thanks mindful one, glad to have you aboard!
__________________
www.bods-mods.com
Old 28th Jul 2012, 09:28   #19
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
i think that you should try with the techno weld, it isnt sure that it can be welded if it's molded alu =/ have some bad experience with yhat, just melted away when the tig heated it up =/
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 28th Jul 2012, 18:03   #20
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Subbed, looks good.
Cheesecake motherboard for the cheesecake
edit: saying it looks good is too weak, looks flipping awesome.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Last edited by Waynio; 28th Jul 2012 at 18:04. Reason: edit: saying it looks good is too weak, looks flipping awesome. :D
Waynio is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
