Reply
Thread Tools View Mode
Old 18th Feb 2013, 19:04   #81
Blooddrunken
In Flames we Trust
Blooddrunken's Avatar
Blooddrunken has yet to learn the way of the Dremel
It turned out awesome.
Blooddrunken is offline   Reply With Quote
Old 18th Feb 2013, 19:42   #82
AverageNinja
Almost an EpicNinja
AverageNinja's Avatar
AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.AverageNinja is definitely a rep cheat.
Originally Posted by Elenos View Post
The OCD in me dislikes that the circles don't line up with where the threads are so you intersecting circles. Plus I am not a fane of the circles really - which is shame as the overall design of a lot of the EK stuff is really nice - but without the circles it would be even better!!
I do agree with that, but when (90' or 45') fittings are in, those circles aren't as visible anymore. And I am actually starting to like those circles. Though they look horrible on the GPU blocks.
AverageNinja is offline   Reply With Quote
Old 18th Feb 2013, 21:58   #83
tekonivel
Multimodder
tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!
Pure awesomeness!
__________________
Completed : Bulky
tekonivel is offline   Reply With Quote
Old 19th Feb 2013, 05:24   #84
Boddaker
Still hangin around
Boddaker's Avatar
Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.Boddaker is definitely a rep cheat.
Thanks guys!
Originally Posted by wahoomcdaniel View Post
Lots of supplies, but you should probably add a respirator next time.
Didn't see one in use when you were adding resin.
Mod for the long haul.
I did have a respirator, in fact I was wearing it as I was applying the gelcoat. But I took it off shortly thereafter. I was working in the garage with the door wide open, so it was well ventilated. I just forgot to put the respirator back on.
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 21st Feb 2013, 03:36   #85
Nutman
Never stuck with stock
Nutman's Avatar
Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.Nutman is a hoopy frood who really knows where their towel is.
Homemade cast side panel = effin' aaaawesome!
__________________
Best regards, Nutman
Projects: Nutman - Hampen - F.O.B. T.C. - BabyShark - The Scratchbench
Nutman is offline   Reply With Quote
Old 21st Feb 2013, 17:01   #86
vanos
What's a Dremel?
vanos has yet to learn the way of the Dremel
I like those fittings and that panel is awesome.
vanos is offline   Reply With Quote
Old 26th Feb 2013, 02:16   #87
Boddaker
Still hangin around
Boddaker's Avatar
Thanks Nutman and vanos!
Spent a good portion of the weekend cleaning up the side panel. I had to remove quite a bit of fiberglass and resin around the edges where the panel mates up with the case. Small oversight on my part, as I should have taped those areas off so I wouldn't glass over them. Ah well, a few extra hours of work and it now fits back on the case. I also exposed all the bubbles just under the surface so I could fill them in with more resin paste. I should be able to do some filling at some point this week, as it is supposed to be warmer.
along with the cleanup, I managed to make a mold of side scoop I made a few months ago. If you recall, I carved the shape out of foam, then covered it with bondo.
I prepped the scoop in the same way as the side panel form, sanding to 1000 grit, polishing compound, 4 coats of wax, 2 coats of PVA. I glued it down to the back side of the same aluminum sheet I had the side panel form on. Using the epoxy dough, I covered the scoop and let it set up overnight.
The next morning, I popped it out of the mold. After a bit of cleanup and prep on the inner surface, it will be ready for fiberglass. I'll be able to make both scoops from this mold.
Work continues...
__________________
www.bods-mods.com
Old 3rd Mar 2013, 20:39   #88
Boddaker
Still hangin around
Boddaker's Avatar
Got the first side scoop done yesterday, as well as quite a bit of bodywork done on the side panel.
I prepped the mold friday night, so I was ready to go first thing on Saturday. Here's a shot after laying down the fiberglass. First layer was the strand mat, followed by two layers of woven roving.
Popped it out of the mold. Had one area where it stuck a bit, so I'll have to repair that before laying up the second scoop.
Side by side comparison between the original foam scoop and the fiberglass piece.
After trimming the scoop, I set it onto the side panel for a test fit. You can also see the bondo work, where I've been filling in the problem areas. I broke through all the bubbles near the surface and filled them back in with resin paste. After grinding them smooth, I went over the areas with bondo. I also went around the whole thing where the fiberglass meets up with the plastic panel and covered up the seam.
That large patch of bondo is where I noticed a minor low spot in the fiberglass. I thought I had that part of the form pretty flat, but I guess not!
I still have to trim the end of the scoop, and I'm thinking it's a bit too long so I'll take about an inch off.
Once I get it trimmed down to where I want it, I'll cut the fan holes in the side panel and glue the scoop down using some resin paste. Then I'll finish it up with some more bondo.
Looking forward to getting some primer on the whole thing so it's one solid color. Hopefully by next week! Thanks for reading.
__________________
www.bods-mods.com
Old 3rd Mar 2013, 20:50   #89
whyte
Multimodder
whyte's Avatar
whyte has yet to learn the way of the Dremelwhyte has yet to learn the way of the Dremel
simply amazing...
__________________
Project Carbon Apple
whyte is offline   Reply With Quote
Old 5th Mar 2013, 17:00   #90
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Looking...Well, it's still pretty rough, but awesome.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 6th Mar 2013, 00:11   #91
Dragulax99
Minimodder
Dragulax99 has yet to learn the way of the Dremel
more!!
Dragulax99 is offline   Reply With Quote
Old 6th Mar 2013, 20:31   #92
Nutman
Nutman's Avatar
Maybe Brian likes it rough?
Ahem... I just stole an obvious one from you there, Cheaps.
__________________
Old 14th Mar 2013, 17:17   #93
Boddaker
Still hangin around
Boddaker's Avatar
Originally Posted by whyte View Post
simply amazing...
Thanks whyte!
Well, all projects are pretty rough until finished right? Unless you're Attila I suppose lol.
Anyway, on with a brief update... Last weekend was more family time than modding time, but I did get some additional work done on the side panel, filling, sanding, and trimming. Was having difficulties fitting it back on the case. The fiberglass must have distorted or shrunk the bezel, so I had to trim most of the stock mounting tabs off and add new ones.
But now it fits on the frame again, so I can start marking areas that need to be cut away, like the side scoop hole.
Then I also brought the motherboard in and did a test fit so I could mark all the cable holes.
Roughed out the IO plate and video card holes.
I also started on the motherboard mounting, marking those holes. I'll be using some T-nut inserts from the back that will accept the stand-offs, which I will epoxy in place. I should have another update tonight on that. 'Til then!
__________________
www.bods-mods.com
Old 14th Mar 2013, 18:46   #94
AverageNinja
Almost an EpicNinja
awesome job! Have some Rep!
Old 14th Mar 2013, 22:39   #95
Boddaker
Still hangin around
Boddaker's Avatar
Thanks!
__________________
www.bods-mods.com
Old 14th Mar 2013, 22:49   #96
White-Fox
Multimodder
White-Fox's Avatar
White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.White-Fox is the Cheesecake. Relix smiles down upon them.
oh god i really can't wait to see how it turns at the end.... the best of luck for you!!!
__________________
My Mods:
Kaamos - Polar night : http://forums.bit-tech.net/showthread.php?t=256710
Reincarnation : http://forums.bit-tech.net/showthrea...67#post3394367
White-Fox is offline   Reply With Quote
Old 15th Mar 2013, 01:19   #97
siliconfanatic
Johny-come-Lately
siliconfanatic's Avatar
siliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyansiliconfanatic is a Super Spamming Saiyan
EPicness is happening here
__________________
Do not let anything good in life pass you by. Cherish it with all of your heart, because before you know it even life will have passed you by. And if you let all those things pass you by? The only thing filling your heart will be deep sadness and regret. So whatever you do, hold on, and never let go.
siliconfanatic is offline   Reply With Quote
Old 18th Mar 2013, 18:40   #98
Boddaker
Still hangin around
Boddaker's Avatar
Motherboard mounting progress...
After marking the holes with a template, I drilled them out, then routed out a wider area for the T-nuts so they would sit flush.
The T-nuts had barbs sticking up that needed to be flattened since they wouldn't be able to penetrate the fiberglass. I also drilled some holes around the outer base to have something for the resin to grab onto when I permanently set the T-nuts in place.
A shot of the motherboard side with a standoff...
I also got a bit more work done on the access hole cutouts, trimming and filing the edges down, and got another layer of bondo on the low spots of the panel. Which means more sanding grunt work in the very near future. yay!
In other news, I picked up more of the pink stuff from Home Depot (had to drive 20 miles to the next town for it since the local HD doesn't carry it :x ).
No, I won't be insulating my house with it. ;-) Got more pieces to fabricate, namely the top, front, and back panels. I might even start shaping the top panel this week, as I'm in need of a change of pace after all the work I've been doing on the side panel.
__________________
www.bods-mods.com
Old 18th Mar 2013, 20:25   #99
Marquee
Mac Pro Modder
Marquee's Avatar
Marquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming Saiyan
Loving the fiber glass work. how many layers of filler do you think you are going to need to make it smooth?
Marquee is offline   Reply With Quote
Old 18th Mar 2013, 21:01   #100
Boddaker
Still hangin around
Boddaker's Avatar
I think maybe one more go-round after this one. The panel is pretty straight overall, just the one angled side ended up being concaved for whatever reason, so I'm having to add more filler to bring it up to level. This time I used a straight edge that spanned the length of the area and screeted the bondo across the whole thing, so it should be perfect now. After I attach the side scoop, I'll need a bit more filler around the edges to blend that in, and I'll take care of any small holes I find anywhere else, then it should be primer time.
__________________
www.bods-mods.com
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
